T2 and DFU firmware reflashing
  • mon2
    • Dec 2019
    • 14316
    Hi. Have a logic board (820-01958 from A2179 chassis) that is not booting.
    Adapter voltage is 20v @ ~70-80mA consumption.
    PPBUS_G3H @ 12v29 (should be 12v6). The SMBUS lines on U7000 (ISL9240) are stuck low but there is no short circuit and the level shifters are fine.
    Based on the assorted voltage rail review, this board is similar to a case on the Rosmann forum where a DFU is recommended.
    At this time, we do not have such a current macbook to perform this DFU process.
    Q: What exactly does the DFU process do with respect to the firmware upgrade? That is, which device holds this corrected firmware?
    U3060 = TBT ROM storage but we are negotiating fine @ 20V. So we can ignore this device.
    U4770 = Is this the T2 rom? (SOC)
    Respectively - can the T2 rom (U4470) be applied from a donor board to mimic the DFU process? If only to test if this logic board is capable of working or not, wish to transplant from the donor board.
    Do not want to lose any potential data on the non-working target board in this process.
    Welcome all suggestions.
  • spidertnt
    • Jul 2016
    • 34
    Re: T2 and DFU firmware reflashing
    You can use any Macbook to restore using DFU mode ....I use a Mac Pro 5.1 from 2010.
    I use this cable
    https://www.amazon.ca/gp/product/B01...?ie=UTF8&psc=1
    You will need a working chassis to place the logic board in...so you can use keyboard commands to get into DFU mode
    Programming the T2 chip manually with another rom backup can work to just show if power on AKA screen comes on etc. ...but it won't actually load or allow restore etc.
    I have tried this using T2 USB programmer
    • mon2
      • Dec 2019
      • 14316
      Thanks so much for the guidance. Did know that an older MacBook could be used as the host.
      To confirm, the T2 firmware is stored on an external flash rom device and is not internal to the T2 controller?
      Will consider to apply a ROM from a donor board to see if the board can consume > 80 mA.
      • Stephen
        Meow Meow MEOW!
        • Apr 2020
        • 667
        Yes you can use an older macbook to do a DFU restore. Just make sure the usb 3.0 is usb 3.0 to usb c to communicate with the device.
        The internal rom is stored on the rom. The ROM chip has a lot of important information. For it to boot. Such as serial info etc. EFI etc. when doing the DFU make sure you are using the second port closest to the bottom on the left side. Hold down right shift alt option and control. Then press power button let go power button and continue holding until you see DFU in AC2.
        Also yes U4470 is the rom chip that is correct. I suggest having a T2 programmer ROM tool. You can extract info. Worst case you can copy bin files from myself if you need a clean EFI bin file but the serial will not match but I can manually change it to match your board. Let me know
        Alsooooo keep in mind when copying a new bin file the computer won't boot so a DFU will be required.
        sigpic
        MEOWING IN THE IMPOSSIBLE UNIVERSE!
        • piernov
          • Jan 2016
          • 4437
          • France
          T2 has an internal boot ROM that cannot be updated (same as on iPhone and hence why checkm8 cannot be patched), it handles the DFU feature and hands off the boot process to the bootloader. A small part of the bootloader is stored on the external SPI ROM, this does contain the serial number, but it does no contain EFI and many other firmware modules required to boot. Everything else is stored inside a hidden partition on the SSD. EFI is read from the SSD and sent to the PCH by T2 through eSPI.
          DFU restore can repair many firmware modules but it's not able to rebuild everything from scratch (e.g. blank SPI ROM and blank SSD ICs).
          • spidertnt
            • Jul 2016
            • 34
            yes ..i forgot you will need to do DFU restore after swap . it should also fail but possible the the screen will post before failure .
            also possible voltage stays at 5v needing DFU to restore back to 20v
            • nelusab
              • Aug 2022
              • 27
              • România
              Hi Stephen!
              I have an issue with an MBP 15' - A1990, it boots when battery flex cable is unpluged but when I plug in the cable it runs in kernel panic, the fans are running at max for a second and the machine reboots over and over again, in loop, until I disconect the flex cable.
              First I thought is something about current sensing, and I replaced the current sense rezistor, after that the ISL chip (U7000). Result - same behavior. I've dumped the ACPI tables and I found that one of them SSDT SmcDppt.aml is empty, has nothing written on him. If this table is responsible of SMC behavior, could be an explanation. I have a reflashing tool, but no genuine A1990 I7 2,6Ghz bin file to reflash SPI ROM. Could you help me?
              • Stephen
                Stephen commented
                Editing a comment
                Usually when you plug in battery and fans run at max speed is a clear indicator of a faulty battery in most cases. I would suggest trying another batter and seeing if that is the issue then proceed further.
            • nelusab
              • Aug 2022
              • 27
              • România
              Hi Stephen,
              I already tried with 2 other batteries. this one has 168 cycles. I could boot with the battery pluged in but with trackpad cable disconected. It booted slow, and the fans where running noisy, and that's how I found information about the battery.
              I've performed a new DFU Restore, this time with last version of macos Sonoma on both macs, and with the last iBridge. The same result. Please tell me this, DFU Restore operation is reflashing the entire T2 ROM file?
              I have some KP messages looking like this
              • nelusab
                • Aug 2022
                • 27
                • România
                I forgot to mention the fan where running fast but nothing was heating on the board, I've checked the CPU, GPU, Nands, memory, T2 chip, they where at max 40 degrees(Celsius)
                • nelusab
                  • Aug 2022
                  • 27
                  • România
                  When I read the KP message - about a namespace error, I thought there's something about ACPI namespace and the ACPI tables are part of T2 ROM bin file. That's why I've asked you to help me with a clean T2ROM bin file.
                  The old battery had over 750 cycles, and I experienced something with an A1989 model, wich was working normal until the battery percentage was drawing down to 60% - 70%, when suddenly the system was crashing, rebooting by itself with KP message. So my explanation is that could be the same with this A1990, perhaps it was performed a major update, without the addapter pluged in and during the process, the system crashed and the bios was corrupted.
                  I have another macbook in the same stage, an A2251 one. At this one I have no info about the battery, but I let it to charge at full, and after few hours I measured the voltage - first 8V, after 7V -decreasing, with the battery flex cable un plugged. I think this one also had a broblem with the T2ROM bin file corrupted, probably the same cause. I could be wrong but I have no other explanation. So could you help me?
                  • Stephen
                    Meow Meow MEOW!
                    • Apr 2020
                    • 667
                    You will have high fan spin when trackpad is disconnected and it will act slow with these machines. This also happens with m1 machines. You should always have the trackpad connected. If the fans are off when it is connected and it boots normally and the battery holds a charge you have an issue with the board and need to diagnose the board for repair.
                    sigpic
                    • nelusab
                      nelusab commented
                      Editing a comment
                      Ohh yeah, it helped me very much!
                      Thanks, anyway!
                  • phantomEVO
                    • Mar 2013
                    • 488
                    Hi Stephen stephen! just a question! i have a dead macbook pro a2179 (motherboard 820-01958) stuck on 5v
                    i've tried to fix it flashing tbt t2 soc rom with this dump
                    https://www.badcaps.net/forum/troubl...rogrammer-tool
                    (post 7)
                    with no luck...
                    then i have found the real problem on the mainboard and fixed it.
                    now the motheboard is directly recognized in DFU mode, but when i try to revive it, i receive this error
                    Unexpected device state 'DFU' expected 'Recovery' (Probably forced into DFU mode externally) [com.apple.MobileDevice.MobileRestore – 0xFAE (4014
                    with battery only, with charger only and with both conencted:
                    could it be a problem of the t2 rom?
                    thanks
                    • mon2
                      • Dec 2019
                      • 14316
                      Try different cables:
                      https://discussions.apple.com/thread...k#259741517022
                      • phantomEVO
                        • Mar 2013
                        • 488
                        HI Stephen ! do you know if backuping soc rom, eresing it and reflashing original backup, mac will go directly in dfu mode?
                        • ugamazing
                          • Jun 2013
                          • 166
                          • usa
                          Heads up about the 820-01958 boards specifically:
                          We have found several cases of the CPU controller (U7100) being improperly soldered. So far we've ONLY found this issue to affect the 820-01958. Symptoms are almost always power and DFUs OK but no video or chime ever. Reflow U7100 and make sure you're not dealing with that issue before you mess with T2.
                          Also, something else worth noting: If you're DESPERATE for the data, you can swap the nands and T2 to a working board to retrieve the data. We've done it a hundred times.
                          • H34TO
                            ITE IT8390 (IT8390E-256) programmer "ITE Download Board 4" user manual + firmware, flashing ITE ECs on the cheap
                            by H34TO
                            Recently I've gotten into EC flashing due to my broken laptop(s) and started frantically searching methods for flashing the IT5571E-128 chip on the cheap(due to me beaing a student and not having a job) and noticed that ITE newer chips can be flashed via ISP (In-System Programming) either via SMBus or the KBC (EPP - Enhanced Parallel Port) interface. While these can be achieved with programmers like SVOD4/3 or the RT809H/F those options are WAYYY out of my budget so I was horrified. But recently I stumbled uppon some programmers on aliexpress that claim they can program a variety of ITE chips...
                            06-17-2025, 07:17 AM
                          • howardc64
                            by howardc64
                            07-24-2025, 05:17 PM
                          • macabook
                            by macabook
                            🧩 Initial Issue
                            07-24-2025, 02:17 PM
                          • rookieme
                            lenovo thinkpad L15 Gen 2 board NM-D271 usb firmware request
                            by rookieme
                            I'm searching for a usb firmware for the notebook of the title.
                            The issue is that it stays at 5V only input from both usb c ports and the controller TPS65994 has been replaced.
                            The firmware should be the U5502 and I upload the dump of it.
                            Lenovo provides firmware updates but I was unable to find the appropriate file inside.
                            s/n: PF33180Q
                            Thank you....
                            04-09-2025, 04:44 AM
