Macbook A1466 - no backlight
  • survivalbloke
    • Aug 2021
    • 307
    MacBook Air A1466 board 820-000165 - I've got no backlight. Backlight fuse is fine, and I've got 8.5v on that one. I replaced the backlight driver with one from a donor board but no results. I've also swapped the screen but still no backlight. What else can be checked?
  • dellxps15
    • Feb 2014
    • 1598
    • italy
    Re: Macbook A1466 - no backlight
    check voltage on d7701 both side.
    check lvds connector pin 3-4 if are ok or have oxidized and move from place.
    edit: u sure no backlight ? ( u can see folder icon or os loading )? if screen is totally black can be also braindead.
    check if usb pendrive led blink when ocnnected if ur not sure if its backlight poroblem only.
    • reformatt
      • Feb 2020
      • 1491
      Try a new backlight IC rather than a donor. Reballing these is a pain, they are pretty cheap so I don't bother. 8.5V shows that at least the BL is enabled, just the 25V boost isn't working. Also check pin 5 under the IC for continuity to D7701.
      • piernov
        • Jan 2016
        • 4439
        • France
        https://logi.wiki/index.php/Backlight_Troubleshooting
        • Stephen
          A1466 MacBook Air 13" 2017 Backlight issue works but then turns off
          by Stephen
          Hello, got a weird MacBook Air here
          board looks fresh and no water damage, backlight works and turns on and stays on when installing OS etc. However, when the os is installed and when the system files are loaded before the login page the backlight goes out. I have wiped it, NVRAM reset, etc and even took some other instances and this blows my mind, never seen this before. Backlight just turns off once the OS is loaded. Anyone come across this and if so what would be the cause? I am certain its a board issue since I tested the LCD on another board and it stays on. Again the backlight works...
          08-23-2023, 09:12 AM
        • Comp_Pro
          No Backlight Macbook A1990 820-01041
          by Comp_Pro
          Hello all,
          Am trying to figure out this backlight issue with this A1990 Macbook Pro.
          Tests performed:
          There is no backlight even with a good screen.
          Backlight IC is receiving the correct support voltages.
          Fuse F8400 ok
          Current sense resistor R8400 ok
          Backlight IC is receiving 3.3V on enable pin.
          Backlight IC receiving voltage from PPBUS_G3H, aprox 12.5V.
          Backlight IC receiving 5V from PP5V_G3S
          Backlight IC BKLT_SCL and BKLT_SDA both measure 0.545V diode mode to ground
          I2C_BKLT_SCL and I2C_BKLT_SDA both measure...
          05-06-2024, 10:23 PM
        • imcool
          Macbook Air A1466 no backlight no image
          by imcool
          On this Macbook Air A1466 with 820-00165
          I have only 8V on backlight line but no high voltage in boost circuit, I have checked all components like caps and diode and they seems to be ok.
          I have noticed that when macbook chimes after turning on there is no image at all even with flash light,
          I have tried 2 different OEM LCD and still there is no image,
          I see the LCD fades out when i remove power or turn off the macbook.
          I have 2 problems
          1 No image
          2 No backlight, but i have 8VDC on backlight circuit.
          12-14-2020, 02:18 PM
        • francescoranchi
          MacBook Pro A1909 LCD (no backlight)
          by francescoranchi
          Hello Everyone,
          I'm looking at purchasing a used LCD from ebay for my macbook A1990 2018 15inch which LCD I cracked. Since new / used but working displays cost around 500$ , I found a Grade A+ LCD display for A1990 which has a good price of 110$ but has no backlight.
          I would need just to make sure that what I know/my reasoning is correct:
          - No backlight means flexgate issue, therefore changingthe flexcable would be enough (I can microsolder to fix the flexgate problem, done it a few times already)
          - Seller confirmed its a LCD issue, and not an issue with the...
          12-04-2023, 06:46 AM
        • psdavid65
          Macbook Air A1466 820-3437-B Booting Problem
          by psdavid65
          I received a 2013 Macbook Air A1466 820-3437-B motherboard with serial number C02L6GQ9FSV8 that came in WITHOUT a bios chip. I got a new bios chip and reprogrammed it. Macbook now powers on but doesn't boot the SSD. I've flashed a ton of bios but still same problem. Windows installation works with this Macbook but never a mac installation. Unfortunately, since I didn't receive this macbook with a bios chip, I don't have the original bios. What can I do now?...
          06-20-2024, 12:27 AM
