Macbook Pro 13" M1 bootloop
  • Roll
    • Mar 2022
    • 36
    • Czech Republic
    Hello there.
    A2338 820-02020 13" Pro M1 came to me with small water damage near JF200 and JF201. After cleaning and replacing few capacitors (CY140, CY141 and CF400) it tries to boot, but after few seconds of Apple logo it makes a ticking sound and reboots.
    I don't see any more corrosion on the board, some test points were damaged, so I scratched them clean.
    I tried the board in other body, but it's the same, so it's not issue with peripherals.
    I have reballed both USB controllers and UC300 (in case there would be hidden corrosion), but there is no change.
    Any ideas? Thanks
  • mon2
    • 14671
    Re: Macbook Pro 13" M1 bootloop
    Boot with a SMC bypass. Any difference?
    • mon2
      • 14671
      Also review this to confirm against your motherboard:
      https://blog.rewa.tech/detail/how-to...-won-t-turn-on
      • Roll
        • Mar 2022
        • 36
        • Czech Republic
        M1 macs do not have any SMC, so there is nothing to reset or bypass.
        It gets into 20V mode, charges battery etc. but it's rebooting on Apple logo.
        • mon2
          • 14671
          Check the voltage to ground of the I2C / SMBUS lines (SDA / SCL) - confirm their parked voltage levels match the schematic. That is, 1v8, 3v3, etc.
          • mon2
            • 14671
            To me, ticking sound is the switching power supply entering the audible zone. Do check the power inductors for a short.
            • Clarify4082
              Macbook Air 2018 A1932 Bootloop
              by Clarify4082
              I have a A1932 Macbook Air with Bootloop.
              I already replaced the battery with a new one and reset NVRAM and SNC.
              When I start the Macbook the Screen is coming on (no Logo) and switches of after a few seconds. If I start without the trackpad and keyboard it stays on longer.
              If I use diagnostic (Option+D), recovery (Option+R) I always get the Apple logo and it go into online-Recovery. Even if I boot the installer from a USB-stick it ends up in online-recovery. Sometimes it crashed short after entering the wifi password, sometimes it loads the recovery...
              01-07-2025, 09:41 AM
            • envym
              by envym
              Hi everyone!
              06-27-2025, 08:54 AM
            • Flasman90
              Macbook Pro DFU Restore Issues
              by Flasman90
              I have a 2020 Macbook Pro A2289 and after many attempts managed to get it into DFU mode, using my older 2017 A1706 Macbook Pro (Running Ventura 13.7.8). However, when attempting 'Restore', it fails at step 4 of 4, showing the following error:
              - "The operation couldn’t be completed. (AMRestoreErrorDomain error -1 - Failed to handle message type StatusMsg (Generic error)) [AMRestoreErrorDomain – 0xA (10)]
              - "The system cannot be restored on this device. Failed to create new state machine for restore [com.apple.MobileDevice.MobileRestore - 0xFB1 (4017)]
              08-30-2025, 10:27 AM
            • tobeend
              Bypass mdm macbook m2 ventura
              by tobeend
              1. RESET MACOS WITH IPSW
              a. Power off MacBook, press and hold the power button to enter Recovery
              b. Open Disk Utility, remove Macintosh HD
              c. Reboot, connect to the network to Activate Mac.
              d. Plug the C cord in the first port of the MacBook into the other Mac, then power off the MacBook
              d. Hold down the Control (L) + Option (L) + Shift (R) + Power key combination for 10 seconds
              e. Release the other keys, but keep holding the Power key for another 10 seconds
              f. MacBook is returned to DFU, open Apple Configurator 2 on the other Mac, right-click...
              05-26-2023, 07:18 AM
            • SarcasticOP
              General question about MacBook power rails for repair.
              by SarcasticOP
              I am looking at an A2337 and found this for the order of power rails and what they do. Can this be confirmed before I dive into hunting down power rails that do not exist or are not neccisary?
              • PPBUS_G3H (12.6V-12.8V)
                • This is the main power rail that supplies power to the entire system. Check this rail first, as it must be present for other power rails to work.
              • PP3V42_G3H (3.42V)
                • This power rail is derived from PPBUS_G3H and is used to power the SMC (System Management Controller) and other essential circuits. It should be present if PPBUS_G3H is working correctly.
              • PPVRTC_G3H (3.3V)
                • This
              12-12-2024, 05:50 PM
