MacBook Air A1932 2019 display remains black after reopening the lid
  • MicroSMD Lab
    • Sep 2018
    • 145
    • Trinidad and Tobago
    Hi, I'm bumping this topic because I have a similar situation but the one I'm working on, the display remains black after reopening the lid. If I disconnect the battery and boot with the charger everything works until I close the lid. If I shut down with the lid open and press the power button everything works. It came in for liquid damage with a burnt audio board. I think the hall sensor in the right speaker is faulty, but I didn't do any tests yet. I'm interested in having the sleep function work with one sensor until I get the replacement speaker (assuming the speaker hall sensor is defective. I will conduct tests as suggested in this post to confirm, but I'm asking for assistance to operate the sleep function with one sensor... if possible...
  • mon2
    • Dec 2019
    • 14262
    Re: MacBook Air A1932 2019 No Sleep Mode
    Carefully measure the voltage to ground of the highlighted signals with the lid open.
    Post each measurement. If the lid is OPEN, each signal pin should be a logic '1'.
    • MicroSMD Lab
      • Sep 2018
      • 145
      Re: MacBook Air A1932 2019 display remains black after reopening the lid
      Finally got around to this unit again
      SMC_LID_LEFT - R4804 - Open - Pin1 = 1.79V, Pin2 = 1.79V
      Close - Pin1 = 0.00V, Pin2 = 0.01V
      SMC_LID_RIGHT - R4805 - Open - Pin1 = 0.14V, Pin2 = 0.14V
      Decided to replace right speaker since the audio board was damaged from a liquid spill.
      R4805 now reads - Open - Pin1 = 1.46V, Pin2 = 0.99V
      Close - Pin1 = 0.02V, Pin2 = 0.03V
      https://logi.wiki/index.php?title=M1...e_view_desktop states "Low PP1V8_AON (1.5 or 1.4v due to bad cap near regulator) would cause partial LID problems like disabled touchscreen on Toucbar, random no haptic click" not sure if this is related. Also on another page https://logi.wiki/index.php/DFU_Mode_Restore_(Macs) under the "scenarios for restore" section describes a similar issue but the voltage was 1.1V.
      As always any advice on how I should proceed is much appreciated, thanks in advance.
      • mon2
        • Dec 2019
        • 14262
        You have a few choices on this fix.
        When you open the lid, what is the voltage to ground of IPD_LID_OPEN ? This is the output of the dual input OR-gate (U4802).
        This logic level should be ~1v8 when the lid is OPEN; ~0 volts when the lid is CLOSED.
        Next, remove all power -> meter in resistance mode -> measure the resistance of R4805. This resistor may be defective and/or U4802 is defective and causing a larger voltage drop. That is, when the lid is open, the same voltage of ~1v8 should be present on the SMC_LID_LEFT and also at SMC_LID_RIGHT.
        From the posted voltage measurements, the SMC_LID_LEFT is working properly.
        The parts in this region of the board are extremely tiny (0201) and not simple to solder / desolder.
        Confirm the voltage to ground of IPD_LID_OPEN to continue this review.
        • MicroSMD Lab
          • Sep 2018
          • 145
          IPD_LID_OPEN is 1.79V with the lid open, 0V when the lid is closed and 1.79V when the lid is reopened but there is no display. R4805 measures 7.67kohm while R4804 measures 9.99kohm.
          The first time I measured IPD_LID_OPEN, I took the reading from pin 32 of J6700 with the connector disconnected, the voltage was 1.79V with the lid open and closed and the display didn't come off.
          • mon2
            • Dec 2019
            • 14262
            When the lid is open - shine a flashlight / phone in torch mode onto the front face of the display.
            Can you see any of the usual graphics on the display? That is, only backlight is missing?
            Your caps key led is able to toggle on/off ?
            • MicroSMD Lab
              • Sep 2018
              • 145
              Yes only backlight is missing and caps key led is able to toggle on and off
              • mon2
                • Dec 2019
                • 14262
                Confirm that the backlight IC receives an enable signal to enable the backlight.
                Also, with no power, measure the resistance to ground of the actual backlight power rail.
                Post the measurements.
                • MicroSMD Lab
                  • Sep 2018
                  • 145
                  Just to confirm, are you referring to pin 17 of U8400 (LP8548) and PPVOUT_S0_LCDBKLT
                  • mon2
                    • Dec 2019
                    • 14262
                    Yes.
                    • MicroSMD Lab
                      • Sep 2018
                      • 145
                      PPVOUT_S0_LCDBKLT to gnd is in the order 100kohm. Backlight enable is tricky since it on the top side of the board and this board is not booting without a battery. Any suggestions? should I run a wire?
                      • MicroSMD Lab
                        • Sep 2018
                        • 145
                        I ran a wire and backlight enable is 3.28V. I saw a thread with a similar issue on the rossmann forum but in that case the facecam did not work (can't seem to find it now) so I turned on facetime and got no camera detected.
                        • MicroSMD Lab
                          • Sep 2018
                          • 145
                          Just checked the microphone is not working also... maybe related to U4850? The first time I checked the backlight enable I got the voltage after reopening the lid but all other times after the enable has been 0V. I also noticed that after reopening the lid, the caps lock takes about 3 or 4 presses to respond, at first I thought it was just a sticky key but when it does light up, that's when I see an image with no backlight, this image goes away after a couple seconds though and seems to return only when I press the caps lock until it lights up again.
                          • MicroSMD Lab
                            • Sep 2018
                            • 145
                            Finally got my donor board, replaced U4850 and everything works. I did a diode mode check on J6100 while I was waiting for the donor and pin 27 (SMC_LID_RIGHT) gave a reading of 0.167. It should be closer to 0.643, thanks to logiwiki. When I replaced U4850 the diode mode reading went up to 0.593.
                            Thanks Mon2 for all your guidance!
                            • bouch
                              unlock macbook air A1932 2019
                              by bouch
                              hi
                              i whant unlock macbook pro A1932 2019 whit ibridge 9,3 ;
                              i change efi files find on files mina T2 activator 1,4 and use for activation mina T2 activator 1,3 , but fault ssh?
                              i use mina T2 ramdisk activator 1,0 and 3,0 . but whon t work ?
                              have you other programme or method compatible whit this macbook ibridge 9,3 for bypass ?
                              I need help or information?
                              Does anyone have the minat2 activator 1.4 software?
                              Or did they use it for bypass macbook air 2019 a1932 with new ibridge 9.3?
                              Thank yo...
                              03-12-2025, 10:14 AM
                            • nikolayu
                              MacBook Air A1932 internet recovery loop
                              by nikolayu
                              I have A1932 that is going to internet recovery every time.
                              i tried nvram and smc reset but it looks that MacBook is not reacting to that.
                              i tried to restore it through DFU but it restarts in the middle of process and Apple Configurator does not show any error, just stays like in progress.
                              keyboard is working because I can connect to WiFi but internet recovery always fails with 2100 or 2003 error.
                              also won’t open option to boot from usb device.
                              and I noticed that is not possible to turn off the MacBook. It’s always turning on by itself.
                              07-22-2025, 02:55 AM
                            • TOMÁŠ
                              MacBook Air A1932
                              by TOMÁŠ
                              Hi, I've never worked with a MacBook before, so I need some advice.
                              I have a MacBook Air A1932 (820-01521). When I plugged in the charger with an amp meter, it showed 19.7V and 1.9A, which indicates that it's charging, but when I press the power button, it doesn't turn on. So, I disassembled it, disconnected the battery, and plugged in the charger again. It showed 19.6V and 0.04A, and pressing the power button had no effect—no current draw at all. Then, I removed the motherboard, connected the charger again, and got the same results. I took a multimeter and checked all the coils, and everything...
                              05-20-2025, 11:19 AM
                            • Arshad alam4659
                              macbook air a1932 sign out of find my
                              by Arshad alam4659
                              Today I receive a MacBook Air A1932, its apple ID has been deleted but when I am resetting it is showing a message(sign out of find my ) customer's have no apple id he bought this MacBook from someone else can someone help me remove this message...
                              04-09-2025, 12:37 AM
                            • astroboypaul
                              Macbook A1932 Some Keys Not Working
                              by astroboypaul
                              Macbook A1932 had completely dead keyboard. I found liquid damage on circuitry on keyboard itself, and repaired it by replacing what i think was a 10k 0201 resistor (here's my post requesting schematic for keyboard circuitry where I included a photo of the resistor: https://www.badcaps.net/forum/troubl...ic-820-01294-a)
                              Now most of the keyboard works and I can login, but the following keys don't work: Delete, "/', left...
                              06-10-2024, 05:32 AM
