Macbook A2179 820-01958
  • Instafixx
    • Jul 2022
    • 374
    • India
    Have a Macbook A2179 with liquid damage. Customer showed it some shop which has done an ultrasonic cleaning of the board.
    The board pulls 0V but doesnt turn on. No Fan SPIN. NOT IN DFU.
    I checked the Power Sequences below and found this -
    Once a valid external power source (Charger or battery) is connected, the following rails will come online.
    PPBUS_G3H: Normal voltage is ~12.6v on the charger with the battery disconnected. Produced from the ISL9240 (U7000, which uses PPDCIN_G3H as its VIN.
    PP3v3_G3H_RTC: Normal voltage is ~3.3v. Produced from U6960, which uses PPBUS_G3H as its VIN.
    PP3v3_G3H: Normal voltage is ~3.3v. Produced from U7650/Q7680.
    Once the PMU (U7800) receives power from PP3v3_G3H, it will initialize and begin producing rails to power the T2 chip.
    Important note! DDR/CPU rails here are referring to the T2 chip, which is basically a CPU with its own RAM in a package on package design. These rails are not referring to the Intel CPU or system RAM.
    PP1v8_SLP_S2R: Normal voltage is ~1.8v. Produced from U7800.
    PP1v8_AWAKE: Normal voltage is ~1.8v. Produced from U7800.
    PP1v8_SLPS2R_PMUGPIO: Normal voltage is ~1.8v. Produced from U7800.
    PP1v1_SLPS2R: Normal voltage is ~1.1v. Produced from U7800.
    PP0v8_SLPS2R: Normal voltage is ~0.8v. Produced from U7800.
    PP0v82_SLPDDR: Normal voltage is ~0.82v. Produced from U7800.
    PP3v3_AWAKE: Normal voltage is ~3.3v. Produced from U7800.
    PPVDDCPUSRAM_AWAKE: Normal voltage is ~1.06v. Produced from U7800. [Getting 0.8V]
    PP0v9_SLPDDR: Normal voltage is ~0.9v. Produced from U7800.
    PP1v1_SLPDDR: Normal voltage is ~1.1v. Produced from U7800.
    PP1v2_AWAKE: Normal voltage is ~1.2v. Produced from U7800.
    PPVDDCPU_AWAKE: Normal voltage is ~1.06v. Produced from U7800. [Getting 0.5v]
    Once the T2 is powered from the above rails, it will read its ROM (U4770.) The T2 will then begin to start its boot up process, in which we will initialize the below rails.
    PP3v_G3H: Normal voltage is ~3.0v. Produced from U7800, powers some PCH functions.
    PP5v_G3S: Normal voltage is ~5v. Produced from U7650/Q7660.
    PP3v3_G3S: Normal voltage is ~3.3v. Produced from U8210.
    PP1v8_G3S: Normal voltage is ~1.8v. Produced from U8220.
    The SSD power is then enabled to allow the T2 to boot BridgeOs.
    PP1v8_VCCQIO_SSD0: Normal voltage is ~1.8v. Produced from U7800.
    PP0v9_SSD: Normal voltage is ~0.9v. Produced from U7800.
    PPVCC_NAND_SSD0: Normal voltage is ~2.5-2.7v. Produced from U9060.
    Once the SSD is powered, and BridgeOs boots, the T2 will signal the device to power on if the power button is pressed. The 820-01958 will assert the pwrbtn signal if the charger is plugged in with the battery disconnected and auto start given the device is in functional condition. We will then expect the following rails once the machine is at this stage in the power up sequence. These rails will primarily power the PCH section of the CPU. NOTE: BridgeOs failing to boot will result in the following rails to be missing.
    PP3v3_S5: Normal voltage is ~3.3v. Produced from U7800.
    PP1v8_PRIM_PCH: Normal voltage is ~1.8v. Produced from U7700.
    The PCH will then de-assert (pull low) PM_SLP_S4_L and PM_SLP_S5_L momentarily to enable the next stage in the power sequence.
    PP1v8_S3: Normal voltage is ~1.8v. Produced from U8250. (Powers system RAM.)
    PP1v1_S3: Normal voltage is ~1.2v. Produced from U8100/Q8100. (Powers system RAM.)
    PP0v6_S3: Normal voltage is ~0.6v. Produced from U8150. (Powers system RAM.)
    The PCH will then de-assert (pull low) PM_SLP_S3_L and PM_SLP_S0_L momentarily to enable the final stage in the power up sequence.
    PPVCCIN_AUX_PCH: Normal voltage is ~1.8v. Created from U7400/Q7401. Incidence in power sequence unknown, likely comes online before the rest of the PCH rails. Likely powers internal level shifting in the PCH.
    PP1v05_PCH_CPU*: Normal voltage is ~1.05v. Likely internally created within the PCH, sourced from another rail generated from U7800. May explain "clicking" sound when these boards experience CPU failure.
    PP1v1_S0SW: Normal voltage is ~1.0v. Produced from U8240.
    PP1v8_S0SW_CPU: Normal voltage is ~1.8v. Produced from U8245.
    PPVCC_S0_CPU: Normal voltage is ~1.8v, but can drop when the CPU is under load. Produced from U7100/U7210/U7220/U7230. [Getting 0.1V]
    Only 2 Rails show lower Voltage. Getting clicking sound from the board as well. is it repairable ?
  • Instafixx
    • Jul 2022
    • 374
    • India
    Re: Macbook A2179 820-01958
    PPVCC_S0_CPU = 45 ohms
    PP1V1_S3 = 4.72 ohms
    PP1V8_S0SW_CPU = 1.27 k ohms
    PP1V05_S0_CPU_VCCST = 540 ohms
    PP1V05_S0_VCCSTG = 321 ohms
    Resistance of the CPU Power Rails
    • bobtib
      • May 2018
      5 ohms is a fault condition here, did you ever get to the bottom of the problem?
      I have the same board with the same problem.
      • Instafixx
        • Jul 2022
        • 374
        • India
        No. I couldnt.
        • crnimrki
          MacBook Pro 820-2327-A, have green light, charge, have normal voltage, no chime
          by crnimrki
          MacBook Pro 820-2327-A, have green light, charge, have normal voltage, no chime. On power on fan spins 5 seconds then stop and again spin and stay spinning.
          CPU Warm, DVD Drive not spinning, Mouse on USB Port inactive. No beeps without RAM DIMM-s.
          PPBUS_G3H - 12.55V without battery, 11.99 with battery charging
          PP3V42_G3H3.39V
          PPVCORE_S0_CPU - 0.98
          RAM VOLTAGE 1.49
          Where to search...
          01-02-2025, 12:51 PM
        • alro7779
          MOSFET? Is its voltage reading normal?
          by alro7779
          Hello, guys!
          Got this 8-pin MOSFET (I presume) on the motherboard that I'm still trying to repair (HP Stream 11-ah117wm DAY0HGMB6C1 REV:C), close to the DC IN connector, and when I read voltage on Drain (5-8 pins) and Source (1-3 pins), I got the 19.81 VDC of the DC IN on each, but on the Gate (pin 4) it's 25 VDC. Is it normal? Now, I'm not quite sure the component is a MOSFET, but it looks like, and since it has the printed code on it totally unreadable, I can't try to find the datasheet. Can anyone give me a hand on this? Or maybe ff there's some MOSFET tutorial or something that you can...
          06-19-2025, 08:19 AM
        • rddube
          Lenovo L490 Ram voltage circuit malfunction
          by rddube
          Hello friends,
          Looking for some guidance here. The RAM voltage circuit on this motherboard keeps burning out PU301 which is a RT8231AGQW. Copy of the board with the burnt chip attached with some voltage measurements and copy of the schematics also included.
          I think I've checked almost every component in the circuit, but when I change the RT8231, the laptop starts I have 1.2V on the inductor for about 10 seconds and then the RT8231 goes south and no more voltage on the inductor. All other voltages on the laptop are good, this is the only one conking out for a reason I...
          07-15-2025, 04:41 PM
        • Fernon@Repair
          Gigabyte Z490 Gaming X Motherboard No VCORE Voltage
          by Fernon@Repair
          i have Gigabyte Z490 Gaming X Motherboard .it has a power on no display fault .. no vcore voltage and debug led stuck CPU LED .
          VCCIO voltage ok
          VCCSA Voltage OK
          VCCPLL Voltage OK
          Ram Voltage ok
          RamVTT OK
          VPP 2.5 OK
          But No Core Voltage
          and i want to this vrm ic datasheet or pinout (ISL69269)
          anyone have this ic pinout voltages?...
          06-25-2025, 07:19 AM
        • electron_jj
          Panasonic TH-L42D25A checking the PSU output voltage
          by electron_jj
          Hi Everyone, I am new to this forum. I have a Panasonic LED TV which doesnt turn on and is blinking 4 times repeatedly when I turn on the switch. The TV does not respond to the remote control so I had to turn on using the physical switch on the side of the TV. When I turn on the switch the 4 x blinking starts and repeat itself until I turn off the TV. There is a black screen. I turned off the light in the room to check the panel and I think there is no backlight as far as I can tell.
          I have been inspecting and testing the capacitors and diodes in the power supply board to try to...
          08-29-2021, 08:13 AM
