iPad Pro 11 A2230 won't boot up - stuck at logo
  • mon2
    • Dec 2019
    • 13835
    Re: iPad Pro 11 A2230 won't boot up - stuck at logo
    Post the details of these parts with their values, size, voltage.
    Chinaphonefix is a good vendor we have used for ipad parts.
    • martyjelen
      • Mar 2023
      • 127
      • Czech republic
      D8710 Finally found it on Mouser.com https://cdn.badcaps-static.com/pdfs/...2c4536cde1.pdf
      C8073 - 1uF / 35V (0402)
      • martyjelen
        • Mar 2023
        • 127
        • Czech republic
        This is real hell to dissasembly this PCB.
        • mon2
          • Dec 2019
          • 13835
          Yes, it will be. Find a good youtube video and take your time in the disassembly.
          • martyjelen
            • Mar 2023
            • 127
            • Czech republic
            So, I finally disassembled PCB. Changed broken diode (I found donor - iphone XSMAX - same value). Removed C8073.
            But with no effect. Still the same.
            • mon2
              • Dec 2019
              • 13835
              What is the current draw?
              I think your case will be similar to this iphone:
              https://blog.rewa.tech/detail/how-to...-on-apple-logo
              • martyjelen
                • Mar 2023
                • 127
                • Czech republic
                #27
                With or without battery connected?
                Should I disconnect everything except USB-C?
                • mon2
                  • Dec 2019
                  • 13835
                  Disconnect the battery and using only the USB-C as a power source, does the ipad boot to the same stuck logo?
                  • martyjelen
                    • Mar 2023
                    • 127
                    • Czech republic
                    #29
                    So, now battery is disconnected, there is only USB-C connected.
                    Still stuck at logo. Current draw is about 120mA.
                    • fallenapples
                      • Jan 2016
                      • 4
                      • United Kingdom
                      #30
                      unplug all flex apart from charge port and screen.
                      • martyjelen
                        • Mar 2023
                        • 127
                        • Czech republic
                        #31
                        Like I said, there is nothing connected except USB-C port and LCD.
                        • mon2
                          • Dec 2019
                          • 13835
                          There appears to be very little on this model and topic on the internet.
                          Remove the USB-C port cable so there is no power to the logic board. Meter in resistance mode.
                          Measure the resistance to ground of each coil you can probe. Review the coil(s) against the schematic to confirm if they are linked to a local switching power supply rail.
                          If the resistance is low, there may be a shorted capacitor on that power rail.
                          Other suggestions are to review the I2C bus devices. It is possible that the OS is stuck waiting on some I2C bus slave device to respond and there may be a disconnect.
                          • martyjelen
                            • Mar 2023
                            • 127
                            • Czech republic
                            #33
                            Well, I think this is impossible, beacause there is no visible pads. See photo.
                            • mon2
                              • Dec 2019
                              • 13835
                              Understood. Trick is to find a nearby capacitor that can be probed and is on the same power rail. Since power is removed, all safe to check each such coil.
                              You are sure the ipad was not dropped? This will result in fractured coils or caps.
                              • elecsoluces
                                • May 2020
                                • 66
                                • France
                                #35
                                C8073 and D8710 shorted, those 2 components have connection to U8000.
                                This IC has I2C bus you should check this IC and components around.
                                • martyjelen
                                  • Mar 2023
                                  • 127
                                  • Czech republic
                                  #36
                                  There is no short. Already checked it.
                                  • elecsoluces
                                    • May 2020
                                    • 66
                                    • France
                                    #37
                                    Ok no short around U8000 but the IC itself can be the problem
                                    • martyjelen
                                      • Mar 2023
                                      • 127
                                      • Czech republic
                                      #38
                                      Maybe, but I don't have spare parts. So it's better be sure what really cause this behaviour before I'll order it.
                                      • martyjelen
                                        • Mar 2023
                                        • 127
                                        • Czech republic
                                        #39
                                        I started measuring and found that on C812F (PPVDD_S1_SOC) is only 30ohm to ground.
                                        • elecsoluces
                                          • May 2020
                                          • 66
                                          • France
                                          #40
                                          You have an image SOC power rails should be good.
                                          • GeirAndersen
                                            iPad .pcb file collection
                                            by GeirAndersen
                                            I tried searching the forum for whether this has been uploaded already, but couldn't find them (as a collection).
                                            Here's a dump of a bunch of iPads, I've split into 2 archives to get under file limit
                                            IPAD COLLECTION 1
                                            +---iPad mini1 820-3400(A1432) 820-3243(A1454?A1455)
                                            +---iPad mini2 820-3683(A1489) 820-3684(A1490?A1491)
                                            +---iPad mini3 820-00008(A1599) 820-00002(A1600)
                                            +---iPad mini4 820-00180(A1538) 820-00177(A1550)
                                            +---iPad mini5 820-01591(A2133) 820-01495(A2124?A2125?A2126)
                                            +---iPad Pro 12.9-4-820-01797(A2229) 820-01798(A2069?A2232?A2233)...
                                            12-09-2024, 09:28 AM
                                          • q2v5
                                            Lenovo T480s, what's up with this Bios, modded boot logo, reflashed now bricked
                                            by q2v5
                                            Lenovo T480s
                                            Model 20L8-S3TE00
                                            Board ET481-U10
                                            Chip MX25L12873F
                                            Hi, I have a few of these & they came with a custom bios boot logo, no passwords etc.
                                            2 x were brand new unused but with custom boot logo, 1 I installed Windows/ran updates then it bricked itself. 1 wouldn't get past the custom bios boot logo.
                                            The third I loaded windows, took a backup of the bios chip, then tried to flash several different clean bios's via programmer which all caused it to not boot. I tried to reflash the original bios both using clip & desoldering but...
                                            08-15-2024, 10:40 PM
                                          • DynaxSC
                                            MSI PRO Z690-A DDR4 (MS-7D25) - stuck during boot every second time - debug code 16 & A1
                                            by DynaxSC
                                            Hi Folks
                                            I have an MSI PRO Z690-A DDR4 (MS-7525) which underwent LGA1700 replacement and had a missing resistor in the VRM section. The missing resistor RV170 (49,9Ω) has been resoldered, and I have also replaced a demaged LGA1700 socket.
                                            Generally the board does boot to Windows, but not always in the first attempt, but after the second attemp to boot the board with Power Button. Also restarting the board from Windows ends up with stuck boot process, but restarting the board again (long push Power Button or switching off and on PSU). Under Windows etherything works
                                            09-29-2024, 04:27 PM
                                          • x_orange90_x
                                            Vizio V555-G1 stuck on wallpaper; now stuck on V logo
                                            by x_orange90_x
                                            I just got this tv today and it's getting stuck on the wallpaper. When I first power it on it goes to the V logo, then a black screen for about 15 seconds, then a Chromecast error for just a few seconds, and then finally to a wallpaper. It stays frozen on this wallpaper and does not respond to anything on the remote besides power on/off. Likewise the buttons on the tv do nothing either (besides power). I did the "reset" by holding the volume down and input buttons together for 10 seconds. It showed a message at the top of the screen saying it was Wiping Data and would restart soon. After...
                                            12-28-2023, 06:26 AM
                                          • minhduc18
                                            suface pro 6 stuck on logo boot loop
                                            by minhduc18
                                            Surface Pro 6 stuck on logo boot loop , help me .
                                            06-10-2022, 07:15 PM
