DV6000 GPU reflow issue
  • port27374
    • Sep 2010
    • 7
    Hi guys -
    I have today recieved a DV6000 (Intel chipset) with the infamous Power but no video signal...
    We usually have these in our workshop and for the most part, do the basic tests such as CPU/RAM checks cables external monitor etc... if none of these work then we assume its a GPU reflow which normally works and we have machine up and running in no time, We have 2 infrared machines, one of them uses a Preheater and Upperheater and one is an IR oven.
    On this particular machine we reflowed the chip and semi assembled the machine into a bootable state, the machine powered on but we only recieved a white screen, with thin white lines running down vertically... we susppected a bad reflow and tried again, but the same result...
    There is no signal on external, even when switched with Fn/F4 on keyboard, but there does appear to be post and hard drive activity.
    We have tried a known working LCD and cable in the system and have had the same result with no progress.
    the next step for us is to consider a reball on the GPU which we can do, but before we do, do any of you folks have any suggestions before we lift the GPU? any other tests or tricks we can try to fix this situation?...
    Tools wise, i dont currently have a scope, only a decent DMM and Analogue MM.
    Thank you
  • Quasar
    • Sep 2010
    • 132
    Re: DV6000 GPU reflow issue
    Nvidia chip. Fault could be internal to chip (manufacturing flaw) and not fixable by reballing which would fix a failure in the board assembly process. The blame game has been played between the 2 for a while now.
    • jacklord
      • Sep 2010
      just reheat all your motherboard components... hopefully it will help
      • port27374
        • Sep 2010
        • 7
        thanks for the help - i have reflowed the motherboard completely in my IR oven and to no avail....
        looks like its a beyond economical repair system in this case as i dont have any spare GPU's sitting around for this
        anyway - thanks to all for sharing and looking
        • meanderer
          • Jul 2010
          • 50
          usually, beyond this reflow thing the motherboard is beyond reasonable repair. Might as well gut it for parts.
          • mockingbird
            • Dec 2008
            • 5484
            As Quasar stated, reflowing doesn't always fix nVidia chips, and most reflowed nVidia chips after the FX series until the 9xxx series will fail again even after reflow.
            • primoz1
              • Oct 2010
              • 270
              • Italy-Slovenia
              Hi. I got same problem with DV6000, I do reball, and no help, I must say this dv6000 hp or Compaq series is one big pain in the ass. I think is not bad BGA, but is some thing around power part, maybe mosfet but Im not 100% I got 5 of this motherboards diferent types, Intel and AMD, with nvidia and intel gpu chips and all got same problem power up but no video on LCD and external monitor. So has anyone been able to fix this motherboard ?
              Thank you.
              • brethin
                • Dec 2008
                • 1907
                DV6000 is crap hell, just toss in trash, they no fix, not worth trouble. (my best world speak)
                • mockingbird
                  • Dec 2008
                  • 5484
                  I reflowed a DV6000 a few days ago...
                  The symptom was when the laptop was turned on, the power lights flashed briefly and then turned off.
                  Result after high temp rohs reflow: Same thing.
                  If you're going to go to the length of reballing, buy a brand new chip... That will almost certainly guarantee a partial success (Partial in the sense that the new chip might also fail).
                  • Joun
                    • Jul 2011
                    • 191
                    • Greece
                    It will fail for sure..Heatsink's design is so bad it is a matter of time before it fails again..
                    • primoz1
                      • Oct 2010
                      • 270
                      • Italy-Slovenia
                      I fix this sucker. I reball all 3 chip's and laptop work OK. Before reball all 3 chip's has overheated, after the temp is normal. I do 24h video test, use BS player and set playlist, in 24h no overheated or freez or any other defect.
                      So I think I fix this crap.
                      • infringer
                        Badcaps Member
                        • Sep 2009
                        • 244
                        • United Frickin States
                        I am having this same issue I am going to replace the main board after another shot at it but I almost wonder I had a laptop like this with the CMOS battery so I'm going to give that a shot as well as another processor cause I used a processor I wasn't sure if it was a good one or not ... I'll post results if I remember I have lots of projects but info gathering is nice.
                        Please note: I am not responsible for any harm caused to you anything discussed is just discussion. Before you try anything discussed be sure that you have the appropriate knowledge and safety gear for the job. Like with anything education and safety are first! Do not try anything @ home without it.
                        • Soulzink
                          Samsug washing machine. Power supply DC41-00189a board issue
                          by Soulzink
                          I am trying to fix a samsung washinmachine power supply main board.
                          I already replaced it with another one to fix the machine but i want to try understand the issue with the old board.
                          Therefore i hope to be able to get some help to explain what to check in order to troubleshoot.
                          The power supply board reference is the following: DC41-00189a
                          I have followed one thread (https://www.badcaps.net/forum/troubl...ingmachine-rel...
                          04-19-2025, 06:26 AM
                          ALIENWARE Steam Machine R2 i7-6700T Specification for Upgrade or Repair
                          This specification for the ALIENWARE Steam Machine R2 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Steam Machine R2 boardview and Steam Machine R2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                          09-12-2024, 03:28 PM
                        • ugamazing
                          Three 820-01700 32GB Logic Boards Same Issue: Won't Wake From Hibernate
                          by ugamazing
                          I have three identical-spec 820-01700 boards (2.6/32/512), and ALL THREE boards came to us with the same fault, from different sources: The boards don't wake from hibernation with the keyboard or lid, they ONLY wake when you press the power button. I understand this is a very minor issue, but the boards must be fixed!
                          We will of course begin with the obvious (checking lid signals), but I couldn't help but notice these three boards were all 32GB variants. Has anyone noticed an issue relating to these 32GB boards in particular? I of course don't think it's a RAM issue, but it's bizarre...
                          12-17-2024, 07:05 PM
                        • CG2
                          Janome DC3050 Sewing Machine Pedal Resistance
                          by CG2
                          OK, this is a long shot. I got this sewing machine cheap because it's end of line, ex-display, and had no pedal. The genuine pedal costs £60, while Ebay knock-offs go for around £15. So I went for the knock-off, it doesn't work, and I'm not sure whether it's the pedal or the sewing machine that has the problem.
                          Now this is an electronic machine, unlike the old fashioned sort where the pedal was a big resistor in series with the power to the motor. Here, the pedal is just (I think) a variable resistor fed with a 5 volt supply, and limited to a current of 5 milliamps. Assuming that...
                          04-14-2023, 07:53 AM
                        • shahnld
                          Lenovo legion 5 pro startup issue
                          by shahnld
                          Good day Experts
                          I have a lenovo Legion pro 5 16ACH6H with AMD RYZEN 7 5800H and RTX3070,.
                          A weird issue has troubled me. If i power on off the laptop 20 times then only power LED will lit but no fan spin no display. At this stage gpu, vram. DDR voltage. 5v 3.3v 1.8v and the rest are present and cpu core is stuck at 0.84v.
                          And sometimes lets say the 21st time it will boot perfectly and there is image and everything is working perfectly and at this stage i see cpu core...
                          08-24-2025, 12:31 PM
