MacBook AIR 1466 [ 820-00165-A] = Missing "PM_SLP_S5_L"
  • Lgolebio
    • Feb 2021
    • 9
    • Polska
    Hi
    MacBook AIR 1466
    MB: 820-00165-A
    I followed the power scheme https://logi.wiki/images/a/af/G3_-_S...ell.drawio.png. I have all voltages up to "PM_SLP_S5_L" = 0V. When I plug the charger it tries to power on, goes to 0,250A then goes to 0,023A and does nothing. No fan spin.
    I'm confused, board looks good under microscope. No corrosion.
  • mon2
    • Dec 2019
    • 14663
    Re: MacBook AIR 1466 [ 820-00165-A] = Missing "PM_SLP_S5_L"
    You may have a shorted part on the part which causes the current sensors to power down the logic board.
    Remove all power. Meter in resistance mode.
    Measure the resistance to ground of each coil on the board.
    Each coil is linked to a local buck regulator power rail. Checking for low resistance readings.
    • Lgolebio
      • Feb 2021
      • 9
      • Polska
      Sure.
      Board is a little bit dirty with flux, because I replaced a capacitor and a TPS22924 switch.
      • mon2
        • Dec 2019
        • 14663
        The damaged cap in the last pic looks interesting. Check the resistance across this cap.
        • Lgolebio
          • Feb 2021
          • 9
          • Polska
          It was replaced as I mentioned. And resistance is high.
          • mon2
            • Dec 2019
            • 14663
            What is the exact voltage to ground of PPBUS_G3H ?
            Update:
            Remove all power -> meter in resistance mode -> check the resistance to ground of PPBUS_G3H @ fuse F7140.
            • Lgolebio
              • Feb 2021
              • 9
              • Polska
              F7140 = 8,574V, as I said all voltages are fine up to PM_SLP_S5_L based on https://logi.wiki/images/a/af/G3_-_S...ell.drawio.png
              Even the battery charging works.
              • mon2
                • Dec 2019
                • 14663
                Are the voltages stable? The battery is able to charge at 23mA?
                Remove all peripherals. No lcd, no trackpad, etc.
                From the first post, you peak at 250mA and then immediately down to a rest of 23mA. Is this correct?
                Check your current sense resistor loop values on each power rail. Remove all power for these checks. If there is an open leg in the current sense circuit, the unit will power down.
                • reformatt
                  • Feb 2020
                  • 1497
                  With these boards, check if you get a single or double pulse on the power rails up to the CPU.
                  Double pulse is often a no fix and is specific to 00165 boards as I've never seen this on a 3437. I have quite a number of boards in my dumpster pile with double pulse. When I've troubleshooted them, it always comes back to the PCH.
                  • Lgolebio
                    • Feb 2021
                    • 9
                    • Polska
                    Yes, nothing is connected to the board, only power supply. Then it cycles two times and go to 0,023A
                    • olegi
                      • 63
                      Hi Can you remove U8130 and see what is the voltage on pin 6
                      • Adogabriel100
                        Macbook A1278 (820-2936) No power. missing SMC_BC_ACOK
                        by Adogabriel100
                        Hey! This is a A1278 macbook 2011.
                        Problem: Not turning on / No green light
                        Im using by3200s charger.
                        Voltajes:
                        PPBUS_G3H = 12.26v
                        SMC_RESET_L = 3.3v
                        PP3V42_G3H = 3.42v
                        U7000 =
                        Pin 1 CHGR_AGATE = 0v
                        Pin 2 CHRG_DCIN = 19v
                        Pin 3 CHRG_ACIN = 4.6v
                        Pin 10 SMBUS_SMC_BSA_SDA = 3.3V
                        Pin 11 SMBUS_SMC_BSA_SCL = 3.3V
                        Pin 12 PP3V42_G3H = 3.42v
                        Pin 13 CHRG_RST_L = 3.3V
                        Pin 14 SMC_BC_ACOK = 0.8V
                        Pin 19 PP5V1_CHRG_VDD = 5.05V
                        Pin 20 PP5V1_CHRG_VDDP = 5.03V...
                        04-01-2024, 01:02 PM
                      • ahmarzo
                        MacBook Air a 1466 keyboard and touch not working
                        by ahmarzo
                        Have a MacBook Air a 1466 with part no 820-00165-a with keyboard and touchpad not working.have tried another working keyboard and touchpad.have check the cable to board and it's good
                        The voltage on connector j4800 is following
                        Pin no 1-3.3v
                        Pin no 10 3.3v
                        Pin no 14 - 5v
                        Pin no 15-20 all pins have 3.3v
                        Have reballed the ic u 5000. And tried another ssd with working os .
                        10-18-2025, 10:40 AM
                      • envym
                        MacBook Pro 2018 with Activation Lock
                        by envym
                        Hi everyone!
                        I have a 2018 MacBook Pro (with Sequoia OS) that I've been using for years with no problem. I recently received an M2 MacBook Pro so I'm mostly using it and not the 2018 one, but since a friend of mine needs a computer, I thought I could restore my 2018 and give it brand-new-like to my friend.
                        I tried using the built-in tool to restore the MacBook (Settings > General > Transfer or restore > Delete) but it got stuck when trying to remove the Find Device configuration (it asked me for the password for my old Apple ID -now I use the same account but...
                        06-27-2025, 08:54 AM
                      • Yosua
                        MACBOOK AIR 1466 DEAD
                        by Yosua
                        HELLO FELLOW COLLECTORS, How are you doing, I hope GOD always gives us good health, I'm here asking for help to work on this MacBook Air, to be honest, this is the first time I'm dealing with a MacBook machine, and I immediately decided that the ISL 6259 IC and after I replaced it it still didn't work and I found that the CHGR_CSO_N & CHGR_CSO_P pins had a short circuit.
                        can anyone help me guys?​
                        02-17-2025, 02:07 AM
                      • salopian
                        Macbook Pro Retina 13” 820-3476-A (A1502) - missing PM_SLP_S4_L
                        by salopian
                        Hello. I would need some advice please.
                        My son's MBP suddenly stopped working and is now only getting the green-then-orange light on Magsafe and no fan spin.
                        He brought the MBP into the house (22 deg C) from a very cold conservatory (-3 deg C) and turned it on straight away. The Mac suddenly died a few minutes later.
                        I examined the logic board and couldn't find any signs of water damage, corrosion, blown up components etc. Nothing was ever spilt on it, and the logic board looks immaculate.
                        I have already replaced the logic board with another...
                        02-27-2021, 07:30 AM
