iPad A2378 dead no charging
  • kingskie
    • Oct 2014
    • 249
    • indonesia
    i have an iPad A2378 dead no charging.
    disassembled and found out that 343S00389-A0 ic was hot so i took it out. after that i measure but the caps ( you can see in the picture i attached) still short to ground.
    does anyone has a clue?
  • elecsoluces
    • May 2020
    • 66
    • France
    Re: iPad A2378 dead no charging
    It is a Vcc High short first check Vcc main (tantal cap near the ic you have removed)
    • kingskie
      • Oct 2014
      • 249
      • indonesia
      do you have boardview for this type? i checked these 3 tantalum caps not shorted.
      i tried inject 1V 3amps but nothing's get hot
      • elecsoluces
        • May 2020
        • 66
        • France
        Boardview is available with paid software.
        You can find schematics for this board.
        Vcc main is not shorted it is a Vcc high short.
        Many IC are connected to this line, inject voltage to find the shorted component
        • kingskie
          • Oct 2014
          • 249
          • indonesia
          already tried inject voltage but nothing is hot.
          • elecsoluces
            • May 2020
            • 66
            • France
            Have you removed the two top shields? There is a lot of connection in this area.
            What tool are you using for heat detection?
            • kingskie
              • Oct 2014
              • 249
              • indonesia
              do you mean the shields that i circle in the picture?
              • elecsoluces
                • May 2020
                • 66
                • France
                No Vcchigh in you red circle.
                • kingskie
                  • Oct 2014
                  • 249
                  • indonesia
                  nothing getting hot here also..
                  • waterchill
                    • Sep 2021
                    • 33
                    good day, I have same iPad which is dead. Current draw is 0,5A@5V when battery is connected and 0,1A without battery. Didn't found a short, I can measure 3,7V and 5V around the PMIC. With IR cam the PMIC gets slightly hot about 30°C with battery connected. Checked a lot of caps, no short. What do you think is it worth to change the PMIC or other ideas? Thanks
                    • mon2
                      • Dec 2019
                      • 14065
                      Check to be sure the charge port contacts are clean and without debris.
                      review this video which may help:
                      https://m.youtube.com/watch?v=ErzWDwPmZnU
                      • waterchill
                        • Sep 2021
                        • 33
                        Thank you. Contacts are very well the iPad is like new. Just measured the battery voltage, it's at 3,66V. I charged the iPad the whole night but it hasn't charged the battery. I don't know if this Generation iPad can show the Apple Logo for short time without battery connected like the older models? I found schematics for this iPad but missing boardfile. Anyone have it?
                        • mon2
                          • Dec 2019
                          • 14065
                          The current draw is too low for this logic board to be booting. Would you know of the history of this board? Alex (Northridge) has a number of good videos on ipad repairs - so does Ben from Germany (he is the one with the manbun). You should be ok to just power from the external power adapter but as noted, at 0.5A, not enough to power the board.
                          Q1: Upon attaching the power adapter, does this current draw spike immediately to 0.5A or climbs up slowly? If immediate, you have a shorted part.
                          Q2: What is the logic board # on the board? Should be 820-*** format.
                          Personally, ipads really test my patience and often decline their repair but do review the details. Check the video from YT which shows a blown ferrite bead for the LCD display and a defective backlight diode.
                          • waterchill
                            • Sep 2021
                            • 33
                            Can you point me where I can find the # of the logic board? Actually cannot find it. This iPad died over night for some reason with plugged in charger. With battery connected, current goes immediately to 0,5A. With no battery connected it goes to 0,1A. Actually I have connected an iPad boot cable and the iPad is booting into system. So it looks like the battery is faulty?
                            • mon2
                              • Dec 2019
                              • 14065
                              • waterchill
                                • Sep 2021
                                • 33
                                Sorry but I got this idea occasionally. Normally an iPad starts up for seconds without battery. It seems that an M1 iPad cannot do tzhis. I thought battery is ok because it have over 3,6v. I will try now with new battery
                                • waterchill
                                  • Sep 2021
                                  • 33
                                  Today I tried new battery and the iPad is booting into system. Can use it like normal. But in the moment I plug in the charger iPad is freezing and goes black. Unconnect and connect battery again same game. The battery is charging for some seconds with about 30W but after some seconds it goes to 0,5A and stuck. I reflowed the PMIC without result. So the only thing I can do here is change the PMIC. Other ideas? Thank you
                                  • waterchill
                                    • Sep 2021
                                    • 33
                                    I changed the PMIC today with same result. It works on battery, if charger plugged in iPad freeze and goes black.
                                    • mon2
                                      • Dec 2019
                                      • 14065
                                      So this is a USB Type C charger port? Have not seen these in the shop yet. You have a CD3217 power delivery controller onboard so the same investigation as the macbooks will apply.
                                      Remove all power -> meter in DIODE mode. Locate and review connector J3700. Lift off the charge port cable which should be removable. Then measure each signal on this J3700 connector in diode mode. Red meter probe to ground; black meter probe to pin to test.
                                      Post each measurement. Checking for a defective signal line. Something between the chargeport and the CD3217 is to blame.
                                      • waterchill
                                        • Sep 2021
                                        • 33
                                        Thank you for the hint. I have checked all pins, all values looks ok. I have here an iPad Pro 11" 2nd gen which have same chip. The values are all the same. Also checked with usb-c tester, also everything is ok.
                                        • GeirAndersen
                                          iPad .pcb file collection
                                          by GeirAndersen
                                          I tried searching the forum for whether this has been uploaded already, but couldn't find them (as a collection).
                                          Here's a dump of a bunch of iPads, I've split into 2 archives to get under file limit
                                          IPAD COLLECTION 1
                                          +---iPad mini1 820-3400(A1432) 820-3243(A1454?A1455)
                                          +---iPad mini2 820-3683(A1489) 820-3684(A1490?A1491)
                                          +---iPad mini3 820-00008(A1599) 820-00002(A1600)
                                          +---iPad mini4 820-00180(A1538) 820-00177(A1550)
                                          +---iPad mini5 820-01591(A2133) 820-01495(A2124?A2125?A2126)
                                          +---iPad Pro 12.9-4-820-01797(A2229) 820-01798(A2069?A2232?A2233)...
                                          12-09-2024, 09:28 AM
                                        • flat-earther
                                          ASUS X54H laptop thinks it's always charging even with charger unplugged
                                          by flat-earther
                                          The charging indicator light on my ASUS X54H laptop is always on even when the charger is disconnected.
                                          Windows also shows ''Plugged in'' when charger is not connected.
                                          This problem started year ago gradually, when unplugging the charger the charging light took several seconds to disappear, then minutes, and now almost always on even when unplugged for an entire day.
                                          Strangely, before sometimes immediately when plugging in the charger the charging light went away, and later came back with it connected.
                                          If I let battery run out and say it has 3% Windows will...
                                          06-24-2025, 09:32 AM
                                        • badboyzzz
                                          A2229 ipad pro 12.9 4gen strange problem Logic Board related charging but no usb data
                                          by badboyzzz
                                          I have a strange problem with my iPad Pro 12.9 4Gen / A2229. When I start the device, it stays on the Apple logo, but when I heat the back of the device with a hair dryer, the device boots, but this time there is an interesting problem. The iPad is charging, but there is no USB data on the computer. The USB charging port has been changed and the chips seem normal, but I have given it to 2 different Apple services in Latvia, but the repair could not be done. Is there anyone who can help with this? Can someone support the repair by sending only the motherboard within Europe? Thank you.
                                          12-28-2024, 02:11 PM
                                        • esqmooo
                                          HP Elitebook 845 G8 dead, only caps lock flashing 7 times. Charging light always on
                                          by esqmooo
                                          Hello everyone.
                                          This is my development machine. I've been using it since two years and half without any problem except sometimes it wouldn't wake up from sleep.
                                          Lately the issue became more frequent and powering it up would take few seconds to show the POST screen.
                                          Then the computer refuses to power on at all. Now only the caps lock button flashes 7 times then stops. The charging light is always on whenever a power source is connected (battery or charger).
                                          I tried long pressing on the power button, after several seconds it would go off then when the button is released...
                                          03-11-2025, 03:57 PM
                                        • waterchill
                                          Apple iPad Pro 12,9" 4Gen no charging, but working fine
                                          by waterchill
                                          Hey folks, I have this iPad Pro 12,9" 4Gen A2232 here with no charging issue. The main fault was a crossed pins / faulty USB charging port due a bad cable.
                                          So I started to replace this parts:
                                          - replaced usb-c port -> no result
                                          - replaced battery -> no result
                                          - replaced usb-c chip CD3217B12A -> no result
                                          - replaced 343S00326 -> no result
                                          - replaced 343S00327 -> no result
                                          - replaced 343S00328 -> no result
                                          I have no more ideas for this issue. There is no short on the whole board, and the iPad is working fine...
                                          04-30-2024, 05:37 AM
