HP Specter DA0X36MBAE0 REV: E - Shorted TPS65988CE
  • AJ847.63e
    • Aug 2020
    • 171
    • Africa
    Hi All,
    We've got a HP Specter DA0X36MBAE0 REV: E in last week with a no power no charge light presentation. Device at first would pull 20V .6A and you could see the TPS 65988CE getting quite hot. But before I could complete checking all USB C ports and both sides of the cable it seems like the TPS has died out as now I'm only getting 5V .2A. I found there was a short on most of the caps around the TPS so I decided to remove it and retest which removed the short.
    I've done some googling and have found a lot of people posting about this chip and after they replaced it the system still did not power on, and there seems to be some uncertainty as to whether the TPS65988CE requires programming or not. Has this been discovered yet?
    Also how do you differentiate between the variants of the TPS65988? It seems like there are 3 variants, but it seems like all 3 have different datasheets and they all have the same package type/size so I'm having difficulty differentiating between the variants. Ali Express seems to be the only one listing them as TPS65988CE, id rather order them from digikey or even better someone locally like RS components or element 14 if I can but there labeling them as TPS65988 DH,DK,or DJ, RSHR.
    Thanks for the assistance.
  • mon2
    • 14636
    Re: HP Specter DA0X36MBAE0 REV: E - Shorted TPS65988CE
    Yes, this power delivery controller requires firmware to function.
    This firmware is perhaps injected by the external smbus master using the I2C interface as per attached document.
    Lenovo brand, for example, offers a dedicated firmware file to reflash this controller for their logic board.
    See attached on a firmware document.
    • AJ847.63e
      • Aug 2020
      • 171
      • Africa
      Ok thanks for the confirmation. In that case I'll order in a new board. I haven't ordered any programmers yet and I've got a bad feeling the board has further faults other than just the TPS as it was originally getting 20V but still wouldn't boot/give a charge light. For instance one of the resistors next to the thunderbolt controller (at least I think that's what it is, looks like Titan Ridge on the Macbooks, the large chip Alex from Northridge always has to replace) is reading as if it has the outside leg away from the chip is on ground which I've never encountered before.
      • piernov
        • Jan 2016
        • 4437
        • France
        TPS65988CE is not available at electronics retailers, datasheet is not available either.
        It's a different chip from the other (publicly available) TPS65988 variants, footprint is not the same.
        Only available on eBay/Aliexpress, and the amount of fake/dead ICs on there is very high.
        I think it can be taken from any donor board with that IC, but at the same time it's possible the donor board is a donor because this IC is bad, would need a donor with just a dead CPU for example… Also hard to find a donor for cheap.
        • AJ847.63e
          • Aug 2020
          • 171
          • Africa
          Fair enough, thank you Piernov. I thought it was a customized version since the data sheet was nowhere to be found. Nice to see the trend of manufactures copying literally everything Apple does is still going strong
          I've ordered a replacement board instead to be safe. As I mentioned above, I've got a strong suspicion there is more wrong with the board apart from the TPS so I would rather order a new board and wait 3 weeks than order a replacement chip and find out A it does not solve the problem, B is a fake, C requires programming and I do not have the tools let alone god knows where you get the firmware from.
          I'll put the board aside to have a play around with when I get some free time. I've also got a Dell Inspiron with what I suspect is another fried USB C controller, (original owner plugged it into a USB C power bank and that instantly shut off the machine and refused to turn back on) so I'm guessing that shorted the USB C controller as when I did a IPA test the IC was literally boiling. Hopefully two easy fixes when I get some free time to look at them.
          • AJ847.63e
            • Aug 2020
            • 171
            • Africa
            Fitted the new board seems to be working ok, just wanted to ask is it normal for bitlocker recovery key having to be entered multiple times? Last time I did a board swap every time I rebooted the laptop I had to enter the bitlocker recovery key like 5 times each after a reboot than it eventually went away.
            This one I've entered the key, and windows has disabled the login pin so I have to wait till the customer comes in so she can reset that up. I'm assuming you have to enter windows and reboot a few times before it removes the bitlocker requirement?
            • binoyroy
              • Sep 2017
              • 51
              • bangladeah
              HP Specter DA0X36MBAE0 any one please help me, Please uplode Usb type C controller firamware file.
                • 21692
                Bios/firmware requests go here -> https://www.badcaps.net/forum/forumdisplay.php?f=40 .Did you read this whole thread,see posts 2 and 4.
                Go to HP support,enter the laptop serial number to find drivers.Firmware downloads are sometimes listed seperately.
                • binoyroy
                  • Sep 2017
                  • 51
                  • bangladeah
                  thankyou for your replay but there are no any type c controller firamware listed in hp site.
                  • reessi
                    Acer Alienware Nitro 5 (GH51G LA-L181P Rev: 1C) & Dell Alienware M15 (GDP50 LA-k452P Rev:1) - Both Shorted PCH (SRKMA)!
                    by reessi
                    Hello:
                    I have both these laptops that appeared to have the same fault so I thought I would have a go at replacing the PCH as something to learn, they both are using the same PCH.
                    I started on the ACER:
                    Up on connecting power no signs of life but current is consumed from the bench power supply and the PCH is hot.
                    All the caps on the top of the PCH are showing 0 ohms and the 3.3v rail is shorted.
                    I followed the videos from Sorin, Electronics Repair School on Youtube heating from the bottom to install. I practised on around 10 scrap...
                    10-29-2024, 11:31 AM
                  • Yanleb
                    Panasonic TC-P50S1 shorted TXNSC1EDUU (TNPA4782AB) SC Board
                    by Yanleb
                    Hi every one. I just want to share the successful repair of my shorted Panasonic TNPA4782AB SC board.
                    I don't usually do it but so many parts were shorted that I decided to buy the ShopJimmy repair kit instead of sourcing each components individually. Here is the list of components the kit contained, with a remark indicating if I needed that part or not :
                    D608, good
                    D618 RF101L4S, good (See warning 1 below)
                    D619 RF101L4S, good (See warning 1 below)
                    D865 RF101L4S, shorted (See warning 1 below)
                    IC464 Inverter HA MC74HC1G14, shorted...
                    03-09-2020, 12:00 AM
                  • modtool
                    HP Victus 15-FA1025NL , board DAG3PAMB8D0 REV:D, shorted CPU DrMOS and n-mos
                    by modtool
                    Hi to all,
                    the owner of this machine gave it to me after having opened it to take off the dust from the inside, telling me that after that it didn't start anymore.
                    I found that one of the DrMOS (AOZ5016QI) on the CPUCORE was shorted between VIN and VSWH, and that one of the two n-mos connected to the power jack was shorted aswell.
                    I unsoldered the two shorted components and verified that there were no other short circuits, then decided to power the mainboard, firstly with the lab power supply, then with its original HP 200w charger, but the behaviour is the same, the board starts...
                    04-01-2025, 08:22 AM
                  • BalkanBoy
                    Dead Razer Blade 14 2022, shorted CPU?
                    by BalkanBoy
                    today I got Razer Blade 14, Ryzen 9 6900HX and RTX 3070Ti.
                    Laptop was completely dead. I found shorted CPU VRM mosfet, shorted 19V mosfet and blown battery fuse.
                    I replaced it all, but still on CPU coil where mosfet was shorted I got very low resistance, near 0 ohms. On other CPU coils I got around 3 ohms.
                    Laptop now raises voltage on whole board, but still nothing comes on the screen. CPU gets 0.7V on all coils except the shorted one. CPU gets only slightly hot, below 40 C.
                    I removed coil and injected 0.7V, it draw around...
                    09-27-2024, 12:44 PM
                  • barry101
                    Apple 820-3662 VCore shorted to ground.
                    by barry101
                    Hi, Would appreciate some help.
                    I have an Apple Late 2013 15" A1398 MacBook Pro with Logic Board 820-3662.
                    Get charger light but no fan spin or chime. No liquid damage.
                    Found PPBUS and VCORE both shorted to ground. Other rails were ok.
                    Removed VCORE MOSFETS U7310, U7320 and U7330. Found U7330 was in fact shorted.
                    With the 3 MOSFETS removed, get PPBUS and fan spin. VCORE is still hard shorted to ground (0 ohms).
                    Attempted voltage insertion on VCORE to locate short using bench supply set at 1.0 VDC and 4.95 Amps (max current for my...
                    06-24-2025, 07:34 AM
