Strange Battery Problem on A1466 820-00165
  • Mufasa
    • Nov 2022
    • 26
    • usa
    Hello Everyone,
    I have a 2017 MacBook Air A1466 that will not charge the battery but will run off the battery outside of MacOS. If the charger is removed while in MacOS the screen immediately goes dark, but the fan will spin for another 30-45 seconds before turning off. I replaced Q7155, R7151 and R7152 but the issue remains.
    Ideas?
    Thanks in advance
  • mon2
    • 14657
    Re: Strange Battery Problem on A1466 820-00165
    Try a pram / SMC reset.
    How old is the battery? Test with a known good battery.
    • reformatt
      • Feb 2020
      • 1488
      Known good battery first, then check in MAC OS;
      About this Mac, System Report, Hardware, Power. What info is reported for the battery? Cycles, charge current, etc?
      • Mufasa
        • Nov 2022
        • 26
        • usa
        I've tried 3 known good batteries with 315 cycles or less. All do the same thing. I usually reset the PRAM twice and reset the SMC once when doing any battery replacements or motherboard work.
        • mon2
          • 14657
          Measure the voltage to ground of each pin on the battery connector.
          Post the measurements and pin numbers.
          • Mufasa
            • Nov 2022
            • 26
            • usa
            Pin 1 8.42
            Pin 2 8.42
            Pin 3 8.42
            Pin 4 2.54
            Pin 5 0
            Pin 6 227.3
            Pin 7 0
            Pin 8 0
            Pin 9 0
            • mon2
              • 14657
              Pin #6 cannot be right. Can you confirm the right value?
              Also, confirm again the voltage to ground of pins #4 and #5 of the battery connector.
              These must be ~3v42 for each.
              Measure the voltage to ground on each side of R5380.
              Then also R5381.
              • Mufasa
                • Nov 2022
                • 26
                • usa
                Pin 4 2.54
                Pin 5 3.42
                pin 6 ??? still getting wacky result
                R5380 both sides 14.62
                R5381 14.62 and 0
                • mon2
                  • 14657
                  As per post #3, do you see the correct information about the battery? If you swap in a different battery, does the report change?
                  We are checking to see if the smbus lines on the battery pack are working correctly or not.
                  If the battery reporting is ok then the smbus lines are not the fault as they are used to extract this report.
                  • ahmarzo
                    Acer TMX314-51 laptop battery problem
                    by ahmarzo
                    I have acer laptop tmx314-51 with part no 6050A3020501.
                    The laptop is working fine on adapter and battery is also charging and when adapter is disconnected in on state the laptop gives backup on battery and gives good backup.
                    But when laptop is powered on through battery only the laptop does not power on and there is 0 voltage on battery connector.
                    I have not not tried another battery as it is not available locally could this be a battery problem.have checked discharging mosfet and there is no shorting to ground on any pin of battery connector.
                    The schematic is not available...
                    04-11-2025, 09:14 AM
                  • NConstantinou
                    LENOVO YOGA 7 14ITLS 15 BATTERY REPLACEMENT PROBLEM
                    by NConstantinou
                    Dear all,
                    i have the above laptop which had a problem with battery. i replaced it with a compatible one..
                    the laptop DOES NOT POWER ON..
                    with it old battery it does power on.
                    i left the new battery disconnected and i powered on the laptop and i reconnected battery while laptop was on. it shows that the battery is charging.
                    when i shutdown the laptop does not power on.
                    does anyone have any solution!
                    when is not power on the usb c voltage tester shows 5v 1.3A
                    when i disconnect battery and power on and then connect battery the tester...
                    12-10-2024, 04:52 AM
                  • mferna14
                    MacBook Air A2681 battery problem after Screen Replacement
                    by mferna14
                    Hi, my dear friends., Maybe this might be a stupid question or something I missed or do not know. I have 2 MacBook Air A2681 (Indentical color & EMC #), both LCD screens broken. Before ordering the LCD Screens I confirmed both worked with their respective batteries & AC Adapters, & they did 100%. The LCD Screens came in today & I replaced LCD for the 1st A2681. (Removed Battery Terminal cable for both Laptops before installation of LCDs). Perfect Screen & Booted up fine. But it did not work with battery. I checked the battery connector & it was seated in well/perfectly....
                    12-06-2024, 08:10 PM
                  • String2016
                    ACER V3-472 Battery charging problem
                    by String2016
                    I have this acer V3-472 laptop with board id DA0ZQ0MB6E0 REV:E , With battery charging problem, At first I thought it was a bad battery so, I bought new battery but the problem still the same,cannot turn on with battery only and when battery and charger plugged in no orange light indicator but the laptop is working properly with charger only plugged in. here is the measurement.I noticed when battery and charger both plugged in the voltage on current sense resistor PR1 is fluctuating form 19v go down but when charger only plugged in its working fine here is the measurement of PU1 BQ737 when battery...
                    02-14-2023, 08:31 PM
                    NVDC charger configuration...
                    11-05-2024, 03:28 PM
