Macbook Air a1466 no keyboard and no touchpad
  • mon2
    • Dec 2019
    • 14342
    Re: Macbook Air a1466 no keyboard and no touchpad
    The STM32 microcontroller is now damaged. Do not attach a fresh trackpad at this time since this trackpad at one time was working and now has a hole in this controller IC.
    There must be a leaky component that is stopping the use of both the adapter and the battery from working together.
    Leave the trackpad off the logic board and review the power path flow using only the adapter / then only the battery and then finally, both together.
    Start with the dual common cathode diode that powers the 3v42 power rail.
    Be sure that diode is not leaking. Check this dual diode in diode mode.
    You should be able to have both power sources be connected without conflict - without the trackpad being attached.
    • koby058
      • Jan 2017
      • 384
      • israel
      Will do.
      do you mean D7005?
      • mon2
        • Dec 2019
        • 14342
        Yes.
        • koby058
          • Jan 2017
          • 384
          • israel
          Hi
          after measuring 3.42 rail with only power, only batt, and both it looks like power is stable.
          I have connected the fresh touchpad and all works good.
          @mon2 Thank you so much for your help and for knowledge and time sharing.
          laptop is back to life
          • mon2
            • Dec 2019
            • 14342
            Good job.
            • B2L_Repairs
              Macbook A1706 touchpad and keyboard not working. Please help
              by B2L_Repairs
              Hi guys i am new to macbook repairs (i mostly do microsoldering on iphones and android devices. I need your assistance with macbook a1706 (touchbar edition) that came in without touchpad and keyboard functionality. External keyboard and mouse does work but the keyboard and touchpad on the macbook does not work. I changed the touchpad flex, also replaced the touchpad but the issue persisted. I then measured voltage on the board and found that PIN 44-50 of the touchpad connector (J4501) got 11.2V instead of 12.6V. Those pins required 12.6v and they get their 12.6v from PPVIN_S4-TPAD_FUSE . I measure...
              10-09-2023, 04:56 AM
            • User555111
              A2338 13" 2022 MacBook Pro M2 820-02773 Touchpad/Keyboard/Display not working
              by User555111
              Currently Im trying to get this A2338 13" 2022 MacBook Pro M2 to function properly, Right now the trackpad and keyboard are not working but the power button and keyboard backlight are working. the Touch Bar shows display but does not respond to touch. I bought it on eBay and it was described as having a bad lcd. When I received it however I found that it was also missing the wifi and bluetooth antenna along with most of the screws hardware. it was also showing picture on the LCD but no backlight, I could also see some lines on the screen indicating the lcd was also somewhat damaged. on top...
              02-05-2024, 08:16 AM
            • playit
              ps/2 port keyboard dead ? p5ql pro / ethernet cable light
              by playit
              my system is p5ql pro asus mobo , logitech keyboard ps2 keyboard (more than 10 years) .
              my place use to get some power drip for a second ,at that time , pc shuts and restarts itself , it dint cause any problem till now , once or twice i noticed , i am not sure if it was exactly at power drip time or normal time - both keyboard and ethernet lan stopped working , the keyboard would lose power i mean led lights-num lock caps lock would not stay on , no light at etherbet cable too..then i would restart the pc - then its all good .
              few years back ps2 mouse stopped working, but ps2...
              12-23-2024, 06:05 AM
            • Vliegenier04
              Macbook A2338 M2 (EMC 8162) keyboard not functioning, trackpad is working
              by Vliegenier04
              Hi! This Mac has been an headscratcher for me, I can't seem to figure out the issue. The Macbook has gotten water damage to the front of the keyboard connector and battery connector. The keyboard connector was dead, by which I mean it was completely corroded and I have replaced it with a brand new one.
              I have verified all the pins are connected to the main board and the main voltages (PP1V8_AONSW_KBD_ISNS and PP3V3_AON_KBD_CONN) are both present, with and without keyboard attached.
              Unfortunately, the keyboard does NOT want to work, caps lock LED not functioning as well as any...
              06-16-2025, 12:03 PM
              HP ProBook 450 G5 + Essential 15.6-inch Case, Keyboard & Mouse Notebook 400 Specification for Upgrade or Repair
              This specification for the HP ProBook 450 G5 + Essential 15.6-inch Case, Keyboard & Mouse Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 450 G5 + Essential 15.6-inch Case, Keyboard & Mouse boardview and 450 G5 + Essential 15.6-inch Case, Keyboard & Mouse schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users...
              09-06-2024, 06:21 AM
