Macbook Air a1466 no keyboard and no touchpad
  • koby058
    • Jan 2017
    • 382
    • israel
    Hi Gentleman's
    usb keyboard and mouse works
    board: 820-00165-A
    schematic for this board can be found here
    Done power reset with external keyboard works, with internal not working.
    i saw no sign of liquid on MB
    tried a pad and cable from another same laptop did not worked, also tried to run it only with touchpad with the keyboard disconnected and still not working
    Can you please help me start debugging ?
  • mon2
    • Dec 2019
    • 14237
    Re: Macbook Air a1466 no keyboard and no touchpad
    Hi. In order of importance:
    1) finally have Orri Jaffa oranges at our local store Mrs. Mon2 cannot stop eating them.
    2) When you connect the trackpad & keyboard, can you power the logic board on/off with the keyboard ?
    • koby058
      • Jan 2017
      • 382
      • israel
      Hi mon2
      1. LOL, i am happy for you that your Mrs. is happy
      2. yes, the laptop powers on and boot to OS, the arrow remains in the top left and no keyboard button is responding.
      • mon2
        • Dec 2019
        • 14237
        Remove all power. Meter in DIODE mode.
        Connect your keyboard / trackpad.
        Red meter probe, yes red, to ground.
        Black meter probe to point to test.
        Measure the diode mode reading of each pin on the trackpad connector J4800.
        Post each measurement with the pin # being tested.
        • koby058
          • Jan 2017
          • 382
          • israel
          OK here it is
          pin #1 0.503
          pin #2 0.554
          pin #3 0
          pin #4 0.459
          pin #5 0.461
          pin #6 0
          pin #7 0.569
          pin #8 0
          pin #9 0.568
          pin #10 0.376
          pin #11 0.714
          pin #12 0.670
          pin #13 0.496
          pin #14 0.466
          pin #15 0.686
          pin #16 0.652
          pin #17 0.655
          pin #18 0.496
          pin #19 0.326
          pin #20 0.682
          I guess pin 8 will bother you
          • mon2
            • Dec 2019
            • 14237
            I think pin #8 is ok due to R4844 being mated with ground.
            Now apply power and check the voltage to ground of each pin. Measure with caution as the power is active.
            The diode mode readings look ok to me and do not show a short.
            • koby058
              • Jan 2017
              • 382
              • israel
              Ok here it is
              pin #1 0V
              pin #2 0V
              pin #3 0V
              pin #4 0.001V
              pin #5 0V
              pin #6 0V
              pin #7 0V
              pin #8 0V
              pin #9 0.002V
              pin #10 0V
              pin #11 0V
              pin #12 0V
              pin #13 0V
              pin #14 5V
              pin #15 0.6V
              pin #16 0.05V
              pin #17 0.05V
              pin #18 3.36V
              pin #19 3.36V
              pin #20 3.36V
              • mon2
                • Dec 2019
                • 14237
                Pins #16 and #17 are not the correct voltage. Remove the interconnect cable and review the voltage to ground of these 2 pins again.
                These pins must return to a logic '1' due to local pull up resistors required on all smbus interfaces.
                Confirm it. If still missing, locate the pull-up resistors for this pair and check if the pull up voltage is present or is missing.
                • koby058
                  • Jan 2017
                  • 382
                  • israel
                  Hi, i can see now that i have 3.3v on pin 16 and 17
                  should i repeat all 20 pins measurements ?
                  • mon2
                    • Dec 2019
                    • 14237
                    Yes. Are these pins the correct voltage with the cables attached?
                    • koby058
                      • Jan 2017
                      • 382
                      • israel
                      both, cable connected and not connected
                      so i will reply here when i re measure
                      • reformatt
                        • Feb 2020
                        • 1413
                        Make sure you have PP3V3_S4_IPD present on pin 10. Absent in your readings. Have seen this open circuit to J4800 on one occasion and needed to run a jumper.
                        BTW, trackpad on these have two interface modes and depends on what you are booted to. TPAD_SPI is only used when you boot to MAC OS, USB_TPAD is used during recovery or other OS like Linux.
                        TPAD_USB_IF_EN_CONN is high for recovery, Windows/Linux etc
                        TPAD_SPI_IF_EN_CONN is high for MAC OS
                        • koby058
                          • Jan 2017
                          • 382
                          • israel
                          Hi
                          Here are the new measurements when the os is in the login screen
                          pin #1 3.42V
                          pin #2 0V
                          pin #3 0V
                          pin #4 0v
                          pin #5 0v
                          pin #6 0V
                          pin #7 0V
                          pin #8 0V
                          pin #9 0v
                          pin #10 2.05V
                          pin #11 2.66V
                          pin #12 2.05V
                          pin #13 2.35V
                          pin #14 5V
                          pin #15 0V
                          pin #16 3.3V
                          pin #17 3.3V
                          pin #18 3.40V
                          pin #19 3.42V
                          pin #20 3.42V
                          should the output of Q4800 (to pin 13) be 3.3 ?
                          @reformat, can you please elaborate on what you written ? about the TPAD_SPI or explain what should i measure ?
                          • mon2
                            • Dec 2019
                            • 14237
                            Measure the voltage to ground on each side of R4830.
                            • koby058
                              • Jan 2017
                              • 382
                              • israel
                              it is 2.47 on both sides
                              • mon2
                                • Dec 2019
                                • 14237
                                That is a low voltage and it should be 3v3.
                                Measure the voltage to ground @ U8000, input pins A2 / B2.
                                What is the voltage?
                                See attached. If the voltage is 3v3 then proceed to remove all power.
                                Meter in resistance mode.
                                Measure the resistance to ground of PP3v3_S4 rail.
                                What is the resistance?
                                Suspecting that the loadswitch @ U8000 is defective but will wait on your checks.
                                • koby058
                                  • Jan 2017
                                  • 382
                                  • israel
                                  I can see that U8000 is having a bit of corrosion on it, and i cannot measure it
                                  but i can see 3.3v on pin#1 of c8000.
                                  forgot about the resistance, i will do it tomorrow since it is late at night now
                                  Will reply with results in the tomorrow
                                  Thanks a lot Mon2
                                  • koby058
                                    • Jan 2017
                                    • 382
                                    • israel
                                    Hi
                                    It is 3.7K ohm
                                    • mon2
                                      • Dec 2019
                                      • 14237
                                      The resistance is ok but suspecting this load switch is now defective and should be replaced.
                                      Assuming the enable pin is active (pin C2), the load switch is faulty.
                                      • koby058
                                        • Jan 2017
                                        • 382
                                        • israel
                                        Ok, i have replaced it then turn laptop on (magsafe no batt) the mouse working, 3.24 v on pin 10
                                        Then i have powered it on battery and the mouse not working, so i connected the magsafe and felt the tpad is very hot , now i see this hole on the chip on tpad.
                                        Attached.
                                        I have avreplasement tpad but i am afraid to use it, what do you think?
                                        • B2L_Repairs
                                          Macbook A1706 touchpad and keyboard not working. Please help
                                          by B2L_Repairs
                                          Hi guys i am new to macbook repairs (i mostly do microsoldering on iphones and android devices. I need your assistance with macbook a1706 (touchbar edition) that came in without touchpad and keyboard functionality. External keyboard and mouse does work but the keyboard and touchpad on the macbook does not work. I changed the touchpad flex, also replaced the touchpad but the issue persisted. I then measured voltage on the board and found that PIN 44-50 of the touchpad connector (J4501) got 11.2V instead of 12.6V. Those pins required 12.6v and they get their 12.6v from PPVIN_S4-TPAD_FUSE . I measure...
                                          10-09-2023, 04:56 AM
                                        • User555111
                                          A2338 13" 2022 MacBook Pro M2 820-02773 Touchpad/Keyboard/Display not working
                                          by User555111
                                          Currently Im trying to get this A2338 13" 2022 MacBook Pro M2 to function properly, Right now the trackpad and keyboard are not working but the power button and keyboard backlight are working. the Touch Bar shows display but does not respond to touch. I bought it on eBay and it was described as having a bad lcd. When I received it however I found that it was also missing the wifi and bluetooth antenna along with most of the screws hardware. it was also showing picture on the LCD but no backlight, I could also see some lines on the screen indicating the lcd was also somewhat damaged. on top...
                                          02-05-2024, 08:16 AM
                                        • playit
                                          ps/2 port keyboard dead ? p5ql pro / ethernet cable light
                                          by playit
                                          my system is p5ql pro asus mobo , logitech keyboard ps2 keyboard (more than 10 years) .
                                          my place use to get some power drip for a second ,at that time , pc shuts and restarts itself , it dint cause any problem till now , once or twice i noticed , i am not sure if it was exactly at power drip time or normal time - both keyboard and ethernet lan stopped working , the keyboard would lose power i mean led lights-num lock caps lock would not stay on , no light at etherbet cable too..then i would restart the pc - then its all good .
                                          few years back ps2 mouse stopped working, but ps2...
                                          12-23-2024, 06:05 AM
                                        • Vliegenier04
                                          Macbook A2338 M2 (EMC 8162) keyboard not functioning, trackpad is working
                                          by Vliegenier04
                                          Hi! This Mac has been an headscratcher for me, I can't seem to figure out the issue. The Macbook has gotten water damage to the front of the keyboard connector and battery connector. The keyboard connector was dead, by which I mean it was completely corroded and I have replaced it with a brand new one.
                                          I have verified all the pins are connected to the main board and the main voltages (PP1V8_AONSW_KBD_ISNS and PP3V3_AON_KBD_CONN) are both present, with and without keyboard attached.
                                          Unfortunately, the keyboard does NOT want to work, caps lock LED not functioning as well as any...
                                          06-16-2025, 12:03 PM
                                          HP ProBook 430 G5 + Essential Top Load Case + USB Essential Keyboard & Mouse Notebook 400 Specification for Upgrade or Repair
                                          This specification for the HP ProBook 430 G5 + Essential Top Load Case + USB Essential Keyboard & Mouse Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 430 G5 + Essential Top Load Case + USB Essential Keyboard & Mouse boardview and 430 G5 + Essential Top Load Case + USB Essential Keyboard & Mouse schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you...
                                          09-06-2024, 06:21 AM
