Hello everyone. I would like to ask for your help. I am reviewing the DAH98MMB8D0 REV: D HF board whose behavior is that when turning on the notebook (which is from the Honor brand) it only turns on leds of the keys caps Lock and FN. I thought it could be a Bios problem, but when I observed I saw that a component was overheating when connecting the charger. This is component MPNL 8694 1665. I have searched for information and found nothing. Not what it is, if it is a mosfet or another component. Can someone help me identify it?
DAH98MMB8D0 REV: D HF board component doubt
Tags: None
Re: DAH98MMB8D0 REV: D HF board component doubt
The company who made this IC is MPS (monolithic power Systems) , MP is a prefix for the company , and NL is the type of package which here is : QFN (3x4) , and 8694 is the Part number . the 1665 stands for Z ==> reels packaging .
The problem is , this package isn't found anywhere to buy , probably because it's discrete , discontinued or for evaluation .
We'll keep searching anyway . -
We'll keep searching anyway ., as you have helped me identify that DrMos. It's a shame that there are no replacements available because I detected a short just in this DrMos on the board. I really appreciate your time. Do you know if there is any alternative to replace it? Also, do you know what type of inductor this is? I can't find any references for it either
Thank you very much for your response, as you have helped me identify that DrMos. It's a shame that there are no replacements available because I detected a short just in this DrMos on the board. I really appreciate your time. Do you know if there is any alternative to replace it? Also, do you know what type of inductor this is? I can't find any references for it either
This inductor is a Panasonic power inductor choke coil .. Its value is 0.15 mh , the c stands for molded package and 033 for reference ..
The attached pictures show that it's from the Panasonic series MC , and the part number is PCC-M0730L ..
I'll tell you also tomorrow what you can do concerning the 8694 ..Comment
Welcome Arkangelus;
I'll tell you also tomorrow what you can do concerning the 8694 ... You're the best!
Look, I found a DrMos very similar to the 8694 and I think it could be compatible. I'll leave the link below for MP86934GLT-Z MP86934 8694 QFN on AliExpress: https://es.aliexpress.com/i/1005003719623091.html
Infinite thanks for responding and taking the time to help me identify these components. I truly appreciate all the information and assistance you are giving me. You're the best!
, welcome again ..
What I wanted to tell you , is , if you're acknowledged in Electronics , you could easily find the difference between packages , and if you want other easy ways , here's how I solved similar problems :
1) - I keep putting the specific part number in the big sites , (AE , AB , Amazon , Ebay , etc ...) , and then wait for a week or two , sometimes a month , and their search engines would provided it consequently !!!
2) - A donor or similar defected board ..Comment
I always keep my promises, welcome again ..
On the other hand, the R15C inductor is currently impossible to find since Panasonic has discontinued it and neither Aliexpress nor eBay has it available. I would have to apply point number 2 of your advice there, because I have only seen that resistor in equipment with 10th or 11th generation i5 processors. I will have to search for a donor boardComment
Assuming...7 Photos -
by m1ch43lzmHi, this is my personal laptop, which the original board (lets call it Board A) blew up PU8700 (TPS51486), making a hole on the board, i had left the laptop at my desk one day with the battery fully charged and didn't touch it for a week, but when i tried to turn it on it didn't
Thought the battery was dead, so i plugged in the charger then tried to power on, the power LED blinked once, charged LED still orange, unplugged the charger, plugged in again and I noticed the "magic smoke" smell, so i unplugged the charger, removed the back cover and saw the blown IC (the "magic... -
by howardc64All left and right refers to looking from rear of TV (or looking from front with TV upside down)
- TV came with vertical bars and no image. Found faulty TVS on left buffer board. Also replaced T-Con (may have damaged the original while hot air removing components, board has slight warp) and have full image but few horizontal lines on the screen. Some of the lines appears to be 2 pixel tall while others are 1 pixel tall.
- Disconnecting left and right buffer board potentially reveals problems on both sides with different signals (unless this T-Con require jumper like Samsung FB_TRDY1&3) Fault
by HakuuHi There,
More Details
TV Model - LG OLED77G1PUA
Got the same exact TCON board from TVPartsToday and replaced it. But didnt transfer the EPPROM data (didnt... -
by SoulzinkHi everyone,
I am trying to fix a samsung washinmachine power supply main board.
I already replaced it with another one to fix the machine but i want to try understand the issue with the old board.
Therefore i hope to be able to get some help to explain what to check in order to troubleshoot.
The power supply board reference is the following: DC41-00189a
I have followed one thread (https://www.badcaps.net/forum/troubl...ingmachine-rel... - Loading...
