Macbook A1708 820-00840 Will only run on a charger
  • Instafixx
    • Jul 2022
    • 374
    • India
    I have a Macbook A1708 that only runs when plugged into the charger. It will not run off the battery. Changed the battery as well but still the same result. The board is clean with no traces of liquid damage. Little bit of dust here and there. Cleaned it.
    Checked D6950 - Both Pin 1 and Pin 2 Giving 3.4 Volts.
    The machine recognises the battery but it shows Battery Not Charging.
    What can be the issue here ?
  • mon2
    • Dec 2019
    • 14659
    Re: Macbook A1708 820-00840 Will only run on a charger
    What is the voltage on the battery?
    Remove the power adapter, attach a battery with enough voltage to power the board.
    What is the voltage to ground of PPBUS_G3H ?
    • Instafixx
      • Jul 2022
      • 374
      • India
      Battery Voltage is 2.2V.
      PPBUS_G3H is 13.2V
      • mon2
        • Dec 2019
        • 14659
        This PPBUS_G3H voltage is with only the battery or with the power adapter connected?
        Remove all power (no battery), meter in lowest resistance scale.
        Measure the resistance at the location of the 2 arrows in the attachment.
        We are checking to be sure the current loop path is present and is of the correct value.
        • Instafixx
          • Jul 2022
          • 374
          • India
          PPBUS voltage is with no power ( no adapter and no battery).
          attachment missing.
          • mon2
            • Dec 2019
            • 14659
            Noted. See above.
            • Instafixx
              • Jul 2022
              • 374
              • India
              Noted. See above.
              You want resistance to ground on each point or resistance across both points ?
              • mon2
                • Dec 2019
                • 14659
                No. We want one probe at one arrow, other meter probe at other arrow.
                This is to confirm the resistance between the 2 points of interest. The reading must be very close to the schematic shown resistors.
                • Instafixx
                  • Jul 2022
                  • 374
                  • India
                  The problem was from the small cable. Changed that. Issue Resolved. Both Old and New Batteries Work fine.
                  This was very weird as the cable looks totally fine under the microscope.
                  • mon2
                    • Dec 2019
                    • 14659
                    Which cable?
                    • Instafixx
                      • Jul 2022
                      • 374
                      • India
                      Which cable?
                      The small cable from the battery board to the main board.
                      • echothegamer
                        Macbook A1466 dies when charger disconnected
                        by echothegamer
                        Hello all,
                        Working on my wife's 13' Macbook air. It's been in a box since she upgraded but I figured it could be good practice.
                        Details:
                        Macbook 13' A1466
                        Board (820-3209-A)
                        Battery OEM 7.3v 50Wh 6700 mAh (020-7379-A)
                        Pictures below of Boardview and schematic...
                        I don't know how to test the voltage on a MacBook battery. I just assumed it had an enable pin but the best I could read was 300 something mV poking around the battery connector.
                        It's an older model and it is very likely that battery has become...
                        10-28-2023, 12:00 PM
                      • EpicFix
                        MacBook Pro A1708 820-00840 stuck @ 5V, no power, no charging
                        by EpicFix
                        Hey guys, I need a little help here. I have a MacBook Pro A1708 820-00840 stuck @ 5V. Started off affecting just one port but now it's affecting both. Both CD3215 ics were replaced but the issue remains. One port does a loop and the other stays at a constant 5V. Both CD3215 have 3V incoming. I checked for PP3V3_G3H @ R3000, C3100 and C3108, R3001, C3200 and C3208. The weird thing is though that the ammeter shows the current draw (5V @ 0.5A) coming out from the port as opposed to it going in. Any ideas on helping me fix this?
                        04-08-2025, 09:55 AM
                      • 24gsm
                        MacBook Pro A1708 install macos fail
                        by 24gsm
                        hi to all
                        i have MacBook Pro (13-inch, 2017, Two Thunderbolt 3 ports)
                        after enter to recovery and format hdd 1to .
                        after try to install macos online . its frezz at loading install in boot and i waiting few hour but nothing i ty install by boot using flash disk but same issu
                        can help please
                        Serial Number: FVFXP0U0HV2J
                        Config Code: HV2J
                        Find My Mac: OFF
                        04-16-2025, 03:57 AM
                      • envym
                        MacBook Pro 2018 with Activation Lock
                        by envym
                        Hi everyone!
                        I have a 2018 MacBook Pro (with Sequoia OS) that I've been using for years with no problem. I recently received an M2 MacBook Pro so I'm mostly using it and not the 2018 one, but since a friend of mine needs a computer, I thought I could restore my 2018 and give it brand-new-like to my friend.
                        I tried using the built-in tool to restore the MacBook (Settings > General > Transfer or restore > Delete) but it got stuck when trying to remove the Find Device configuration (it asked me for the password for my old Apple ID -now I use the same account but...
                        06-27-2025, 08:54 AM
                      • motormayhem
                        Lenovo T460 Only Charges on One Charger
                        by motormayhem
                        Laptop Question
                        I'm working on a Lenovo T460 that has been having trouble charging as of late. Its worked well since I've owned it for a few years. When I went to use it the other day it was dead and wouldn't turn on (was sitting on an Anker 65W GaN charger). After some fiddling with the charger I got it to turn on and start charging, but seemed like the charger was not working as it should (took a few plug and unplug cycles to get it to start charging).
                        A day later it was dead again and wouldn't boot/charge no matter what I did. No lights or anything when...
                        05-12-2023, 01:46 PM
