Laptop Keyboard problem and it is not the keyboad!!!
  • ladharimohamed2
    • Jul 2021
    • 40
    • tunisia
    Good night everyone,
    My problem seems to be strange and i didn't found anything on the internet so here it is if someone have faced it and could help.
    It is a Lenovo Legion Y520-15IKBN that have some keys on the keyboard not functioning ( E , G , H , 8 , 9 , FN , ....) so i thought that it is a keyboard problem, i ordered a new one and replaced it , at first night it worked perfectly the second night those keys were not functioning but when i press one of them 5 or 6 times they function again i restarted the laptop sometimes works sometimes not sometimes i press several times so they work again. after that they stopped completely. The exact same keys that were not functioning on the old keyboard became non functional on the new one so i guessed that it is not a keyboard problem.
    The trucks on the motherboard are connected from the keyboard connector to the super IO that i checked and are OK , the connector is ok too , i updated the bios , reinstalled the driver and didn't fix the problem.
    Does anyone have any idea about this issue ?
    Thanks.
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: Laptop Keyboard problem and it is not the keyboad!!!
    Very likley a defective keyboard as long as connection from kbd connector to SIO is intact.
    • ladharimohamed2
      • Jul 2021
      • 40
      • tunisia
      but it is a new one, and the defective keys are the exact same ones on the old keyboard
      I'm thinking it is a SIO problem maybe ?
      • myth77
        • Feb 2017
        • 380
        • Croatia
        check keyboard connector on motherboard with microscope...maybe one pin from inside is bent or dirty or similar.
        • ladharimohamed2
          • Jul 2021
          • 40
          • tunisia
          all good
          • myth77
            • Feb 2017
            • 380
            • Croatia
            Second i would check in continuity mode connection from those pins to ite chip. And if all ok then i would check pins on ite chip if one of them is making bad/loose connection to the motherboard (solder crack).
            • Vesko356
              VIP Moderator
              • Aug 2018
              • 4386
              • Bulgaria 🇧🇬
              Originally posted by ladharimohamed2
              ... The tracks on the motherboard are connected from the keyboard connector to the super IO that i checked and are OK , the connector is ok too , ...
              Become a Badcaps supporter
              Thanks to all supporters.​
              • ladharimohamed2
                • Jul 2021
                • 40
                • tunisia
                I mesured every pin of the connector and are perfectly connected to the SIO, i even resoldered the SIO to the motherboard for perfect connection.
                the pins of the keyboard are from 36 to 46 and from 51 to 65.
                • ladharimohamed2
                  • Jul 2021
                  • 40
                  • tunisia
                  I disassembled the old keyboard and found that all keys that are not working have the same exact line on the keyboard. That line is connected to pin number 10 of the keyboard connector wich is connected to pin number 60 of the SIO. i even mesured connection directly from those buttons to their pin of the SIP (60) and they are connected. So i guess there is nothing left but a SIO problem.
                  • mon2
                    • Dec 2019
                    • 13986
                    Remove all power. Meter in diode mode. Keep the keyboard connected to the logic board.
                    Red meter probe, yes RED to ground.
                    Ground meter probe to the pin to test.
                    Test each pin from #1..#24 on the keyboard connector.
                    Post each measurement and the pin number being tested.
                    Update - check the SIO pin that is common to the non-working group in DIODE mode and compare this value against a working group.
                    • ladharimohamed2
                      • Jul 2021
                      • 40
                      • tunisia
                      Hi mon2,
                      these are the measurements :
                      Pin 1 : 601 | Pin 2 : 601 | Pin 3 : 703 | Pin 4 : 701 | Pin 5 : 603 | Pin 6 : 704 | Pin 7 : 703 | Pin 8 : 601 | Pin 9 : 703 | Pin 10 : 700 | Pin 11 : 601 | Pin 12 : 600 | Pin 13 : 699 | Pin 14 : 602 | Pin 15 : 599 | Pin 16 : 599 | Pin 17 : 599 | Pin 18 : 600 | Pin 19 : 599 | Pin 20 : 600 | Pin 21 : 597 | Pin 22 : 599 | Pin 23 : 601 | Pin 24 : 601 |
                      I also measured pin number 60 of the SIO that is common to the non-working group and found 700 value. Pin 64 of the SIO wich is a working group found 700 value too.
                      • mcplslg123
                        • Jun 2015
                        • 7262
                        • india
                        I'm still batting for the "NEW" keyboard being also defective. All chinese stuff and they are known for their "QUALITY". So take it with a pinch of salt. have faced a new keyboard found defective on many occassions.
                        • ladharimohamed2
                          • Jul 2021
                          • 40
                          • tunisia
                          Hi mcplslg123,
                          After further investigation i found that is a well known fault on this laptop with the exact same buttons.
                          https://forums.lenovo.com/t5/Gaming-...3631381?page=1
                          • ladharimohamed2
                            • Jul 2021
                            • 40
                            • tunisia
                            Hi mon2,
                            Hi mon2,
                            after more measurements i found different values of pin number 60 of the SIO (the pin wich the line of the non functioning buttons are connected)
                            the value on point 1 = 567 (point 1 where the pin 60 of SIO is soldered to the motherboard).
                            the value on point 2 = 700 (a track of that pin)
                            PS : continuity between those two points is 0 and no visual problems of connection between the two points there. What can it be ?
                            thanks a lot
                            • mon2
                              • Dec 2019
                              • 13986
                              The diode readings should be the same at the start of the pad and to the end of the trace that mates with the pin.
                              In posted pic, concerned about the lack of fiberglass view between the pins. Can clearly see a solder ball between 2 pins of this region.
                              Suggest to apply flux onto the pads and then use desolder braid to draw up the excess solder between the pads. Then use IPA alcohol to clean up the area.
                              In summary, solder sould be present on the pin and landing pcb pads. The area between the pins should be clean and without solder else there is a risk of a short.
                              • reformatt
                                • Feb 2020
                                • 1400
                                I have seen a similar issue on a HP. IIRC, when I scoped each pin, the pullup on one (which is internal to the EC itself) was low when that column of keys was activated. So the EC itself was the fault.
                                • ladharimohamed2
                                  • Jul 2021
                                  • 40
                                  • tunisia
                                  Hi mcplslg123,
                                  Well, it is a company fault that no one found an effective solution , even those who have returned their laptops to lenovo service center and made a repair the fault appeared again after like one month or two.Lenovo support marks the problem as solved and talks to customers with arrogance with no informations about the origin of the problem, they only said that is a hardware issue.
                                  Thanks everyone for helping.
                                  • mon2
                                    • Dec 2019
                                    • 13986
                                    More good reading:
                                    https://www.ifixit.com/Answers/View/...in%20downwards).
                                    • ladharimohamed2
                                      • Jul 2021
                                      • 40
                                      • tunisia
                                      I ordered a second new keyboard and works fine for now, maybe when those SIO legs where partially shorted they caused the first new keyboard to fail. I also took out the ram cover completely because it is near the keyboard connector and may affect the connector or its tracks going to SIO and finally i protected this second new keyboard ribbon cable with adhesive tape.
                                      This second new keyboard works fine for now and hopefully it continue to do so.
                                      • SDNarcia
                                        Dell 15R-5521 keyboard problem (KBC?)
                                        by SDNarcia
                                        Hello, I have a Dell 15R-5521, with the problem that the Ctrl, Alt, Shitf and Num Lock keys do not work, I tested the keyboard with a keyboard tester and it is functional, I also got another new keyboard and the computer has the same problem with the same keys. Check continuity between the ZIF connector from the keyboard to the KBC and all pins are correct. I cleaned the ZIF connector and the KBC and I still have the same problem. I reinstalled windows just in case, and it didn't work. I updated the BIOS to the latest version A16 and there were no changes.
                                        As additional information,...
                                        07-20-2024, 10:47 PM
                                      • Vliegenier04
                                        Macbook A2338 M2 (EMC 8162) keyboard not functioning, trackpad is working
                                        by Vliegenier04
                                        Hi! This Mac has been an headscratcher for me, I can't seem to figure out the issue. The Macbook has gotten water damage to the front of the keyboard connector and battery connector. The keyboard connector was dead, by which I mean it was completely corroded and I have replaced it with a brand new one.
                                        I have verified all the pins are connected to the main board and the main voltages (PP1V8_AONSW_KBD_ISNS and PP3V3_AON_KBD_CONN) are both present, with and without keyboard attached.
                                        Unfortunately, the keyboard does NOT want to work, caps lock LED not functioning as well as any...
                                        06-16-2025, 12:03 PM
                                      • MrDadosz
                                        Lenovo Legion 15IMH05 keyboard problem
                                        by MrDadosz
                                        Hello, I have lenovo legion 5 15imh05 (board: nm-c911) and I have a problem with a keyboard.
                                        When I hold power button for ~30 seconds or unplug RTC battery keyboard will work only one time. After laptop reset or shutdown, keyboard won't work.
                                        In 90% cases when I unplug power supply and turn on laptop on a battery, keyboard works even after plugging power supply - I can't turn on laptop with a power supply and get keyboard working.
                                        Shortcuts Fn + F1-F12 are working. Keyboard is fine.
                                        I replaced IT8176FN-56A and reprogram it with a dump from previous chip and it worked for...
                                        08-15-2024, 05:07 AM
                                      • fmajbour
                                        Acer Nitro 5 model A515-51 keyboard problem
                                        by fmajbour
                                        I have ACER Nitro 5 model AN515-51 main board model LA-E911P Rev 1A after replacing the mainboard keyboard stop working properly.
                                        Some keys not working like Q,Z,C and some keys show deferent chr$ if i press K i will get I press D for F4 key etc...
                                        i have tried all software issues like drivers test the keyboard on Windows 10 and Windows 11 and Linux with same problem.
                                        I have check the keyboard connector on the mainboard every thing looks ok.
                                        Then i replaced the keyboard with new one ......same problem exact same keys problem.
                                        I need your advice if anyone face...
                                        11-13-2023, 09:50 PM
                                        HP ProBook 430 G5 + Essential Top Load Case + USB Essential Keyboard & Mouse Notebook 400 Specification for Upgrade or Repair
                                        This specification for the HP ProBook 430 G5 + Essential Top Load Case + USB Essential Keyboard & Mouse Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 430 G5 + Essential Top Load Case + USB Essential Keyboard & Mouse boardview and 430 G5 + Essential Top Load Case + USB Essential Keyboard & Mouse schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you...
                                        09-06-2024, 06:21 AM
