New Members
Please consider donating to this site if it has helped you. We rely on these donations.
Please also introduce yourself here Introduce yourself here.
And finally, Read the Forum rules here.
I did not. The ones which I ordered from China looked identical to the ports on the machine. However, what I received was not what I ordered, and I ran out of time for the job.
Review part #102-4484-1-ND from DigiKey. Compare the data sheet dimensions against your original. Should be a match but do compare. Hybrid 24 pin type c connectors are common but the board locks and their location can vary.
I have the above mentioned bord after repair, which was related to a lot of missing smd devices on the back of the board.
There were almost 20 devices missing, caps, resistors and some diodes/mosfets.
The board is generally working now, all PCIe ports are working, Windows installs normally.
However I have a problem with SATA ports 4-7 (the board has 8 SATA ports) - disks are not beeing recognized by the BIOS neither by Windows (which is usually normal in case BIOS does not recognize them).
The SATA 4-7 driver network is quite simple chipset<->buffers/drivers<->SATA...
Yesterday a customer brought us a Latitude 5530 with 2 damaged USB ports (type A).
The ports are made by Singatron and, checking the measurements and soldering points, the model should be this one: https://www.singatron.com.tw/en/product/file/280177-1
I checked at RS, TME, Farnell but I didn't find this model
Where can I find them? Something compatible is also fine...
Hi, I hope you are doing great,
I am confronting this weird behavior from this MBP from 2019.
The motherboard is 820-01914A MBP 15inch 2019
The initial symptoms the user told me was that from one day to another the display was just black and the toucchbar would show only the ESC button.
Connecting an external monitor they wiped everything and installed again. The computer boots but "same" thing. Now with external monitor you can "use" the system. The backlight from the internal display works and reacts when changing the brightness, but stays black...
Sorry for the person who’s going to read all this !
I'm on a Nintendo Switch Lite, motherboard HDH-CPU-02.
While replacing the left joystick, I had to remove the motherboard to access the connector underneath. When I lifted the LCD connector latch, it broke (the plastic had become brittle over time), so I replaced the entire connector.
During the desoldering of the LCD connector using hot air, three small components located just below the connector (likely 0402 capacitors) came off and remained stuck to the bottom of the...
This specification for the LG Gram 16T90P-K.AA75A1 Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 16T90P-K.AA75A1 boardview and 16T90P-K.AA75A1 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
