Problem backlight lenovo s145-15ast
  • eric35
    • Nov 2021
    • 40
    • France
    Hello ,
    I have Problem of backlight on my lenovo s145-15ast.
    I touched the lvds connector with the cable.
    it sparked and now my screen is very dark.
    I tested the f2 fuse and it seems good. it beeps with my multimeter in continuity mode.
  • Vesko356
    VIP Moderator
    • Aug 2018
    • 4386
    • Bulgaria 🇧🇬
    Re: Problem backlight lenovo s145-15ast
    Originally posted by eric35
    Hello ,
    Will be in help if you add some more information. Do you have a picture without backlight, or both are missing?
    For the convenience of the people helping you in solving the problem, schematic and boardview:
    https://www.badcaps.net/forum/showthread.php?t=115603
    Become a Badcaps supporter
    Thanks to all supporters.​
    • eric35
      • Nov 2021
      • 40
      • France
      we see the image if we illuminate with a strong light
      • Vesko356
        VIP Moderator
        • Aug 2018
        • 4386
        • Bulgaria 🇧🇬
        There is a hope.
        Check the fuses (3.3V and !9V rails) at the screen pcb itself. If the fuses are OK, we can start measuring, but for now check that first.
        • eric35
          • Nov 2021
          • 40
          • France
          I tried another screen and the image is also very dark
          • mon2
            • Dec 2019
            • 14047
            What is the voltage to ground on each side of this fuse (F2) ?
            Confirm the same voltage reaches the display connector. Do this carefully.
            • eric35
              • Nov 2021
              • 40
              • France
              I don't know how to do that unfortunately
              • mon2
                • Dec 2019
                • 14047
                Meter in dc volts mode.
                Red probe to one side of fuse.
                Black probe to ground. Check the measurement.
                Repeat with the other side of the fuse.
                Post all readings.
                • eric35
                  • Nov 2021
                  • 40
                  • France
                  20.1 on each side
                  • mon2
                    • Dec 2019
                    • 14047
                    Confirm the same voltage is able to reach the LCD display connector - see attached and check where the arrows are shown.
                    To be safe, remove all power. Meter in DIODE mode. Short the meter probes and should hear a beep tone.
                    Next, one probe on either side of the fuse @ F2, other meter probe to the arrows in the attachment. Do you hear the tone beep?
                    • eric35
                      • Nov 2021
                      • 40
                      • France
                      I have 0.6 everywhere
                      • eric35
                        • Nov 2021
                        • 40
                        • France
                        I got the wrong motherboard. I have one where there is no sign of life and on the one in continuity the fuse f2 is good but on the motherboard where I have a very dark display no beep in continuity mode.
                        • eric35
                          • Nov 2021
                          • 40
                          • France
                          I don't know how to change the fuse
                          • PochoMellit
                            • Aug 2024
                            • Argentina
                            Hello people! Please excuse my English, but I'm from Argentina and I don't speak English properly (but I can interpret by reading). If the voltage and diode values ​​are normal, could we conclude that the fault is in the LDC flex or should we continue with the measurements at other place?
                            • rogfanther
                              • Jul 2006
                              • 458
                              • Brazil
                              If you have access to another flex cable, it is easier to try with it, to not risk shorting some lines when probing. If after trying with *correct* cable and screen it still do not show image ( but shows in vga/hdmi ) , then you can measure other points to see if the Enable signal is being generated.
                              • s_specialist
                                Lenovo E15 Gen 2 GE4B0 GE5B0 NM-D011 Rev 1.0 sometimes not opening problem
                                by s_specialist
                                Recently, I have started to encounter a problem with Lenovo E15 Gen 2 models not opening. When you try to open the device, it gives a warning sound and does not display an image, when you apply light pressure on the keyboard, the image appears and works for a while, when you turn it off and on, the same thing happens again. Bios was tried, RAM slots were cleaned and soldered to the legs, the problem still persists. There seems to be a problem with the onboard processors, but since Lenovos glue the processor firmly from the sides, the paths are very damaged when removing it. Has anyone encountered...
                                07-07-2025, 11:47 AM
                              • perzyk23
                                Lenovo T580 - LCD Panel problem - error 0288
                                by perzyk23
                                Good morning,
                                I have a problem with Lenovo T580, which after error code 0288 suggests a problem with the display. I checked the display and it works on another laptop. I replaced the display cable with a new one. I programmed another BIOS (downloaded from this forum) and I still have the problem of a dead display - there is an image via HDMI, and the system does not detect the built-in LCD at all. The problem appears to be hardware. What can I check to confirm or disprove this? I found many threads on the Internet related to this problem 0288, but without specific solutions. Please advise....
                                10-25-2024, 12:42 AM
                              • konradx
                                Lenovo Thinkpad T15 Touchscreen problem bios
                                by konradx
                                i have problem witch Lenovo T15, my LCD display was demaged, i buyed New LCD, Touch screen version. Problem is LCD Working but Touchcreen not working, i wrinted to seller . He sended to me another LCD, but still not working. I have to Lenovo T480s with touchcreen LCD and that display and touch work. I think that is somethink like whitelist support LCD in BIOS. Someone have the same problem?
                                That is my DUMP.
                                My device:
                                SN: PF29Y4N6
                                1s20S7S2WF00PF29Y4N6
                                MB: GT4A0 GT5A1 GP4A0 GP5A1 GT4A2 NM-C931 REV 1.0...
                                09-06-2024, 01:33 AM
                              • madrali
                                lenovo e15 gen2 bios ? problem
                                by madrali
                                Model: Lenovo ThinkPad E15 Gen 2 (Intel)
                                20TD-50S0KU00
                                Hi, my laptop suddenly shut down while it was running. When I try to turn it back on, the screen stays black and it emits a melodic beep.
                                I used Lenovo's SmartBeep decoder and it returned error 0284:
                                "TCG-compliant functionality-related error (possibly BIOS code validation failure)"
                                I then tried to enter crisis BIOS recovery mode by pressing Fn + R at boot. The melodic error code changes, but nothing else happens regardless of whether a USB is inserted. I receive another...
                                06-16-2025, 12:06 PM
                              • Ziome3eknh
                                Lenovo x1 carbon problem
                                by Ziome3eknh
                                Hello, I have a problem with this computer.
                                After connecting the power supply, the keyboard lights up and the touch bar works, you can click on it and it even illuminates the keyboard. When the fan is turned on, it turns on and off. the processor heats up. I have tried different bios but with no success, the same signs. It doesn't charge the battery either. when starting, it takes 20v and about 0.650a, after some time it drops to 0.350a and 5.2w. Has anyone solved the problem with this model?
                                Will it be a RAM or CPU problem?
                                below is the computer details
                                Lenovo x1 carbon...
                                01-29-2025, 02:35 AM
