FX505DT IT8987E
  • trepachka
    • Oct 2022
    • 439
    FX505DT IT8987E
    My motherboard - FX505DT - has IT8987E BXS chip which I need to replace. A local seller has IT8987E BXA chip for sale. Can I get it or must I have the chip with BXS marking on it to match what's on the motherboard?
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: Asus tuf FX504gm troubleshooting
    BXA-The last letter "A" stands for Always
    BXS-The last letter "S" stands for Suspend
    Now decide for yourself.
    • trepachka
      • Oct 2022
      • 439
      Can you give me a straight answer to my question? Must I use the exact match "BXS" or can I use "BXA" as well?
      • kalilinux25
        • Mar 2018
        • 2089
        • ZAMBOANGA SIBUGAY
        Just use the same chip model printed
        • mcplslg123
          • Jun 2015
          • 7262
          • india
          I've explained the difference between two suffix. Cant give a clear answer as on some platforms, they are inter changeable and on others they dont work. Since there is no way to know whether they will work after suffix swap,no one can give you an aswer in YES or NO. I always match the suffix to avoid swapping the SIO twice for non compatibilty. So once again choice is yours.
          • trepachka
            • Oct 2022
            • 439
            Re: FX505DT IT8987E
            I ordered the exact match and it should be here in 2 weeks.
            • mcplslg123
              • Jun 2015
              • 7262
              • india
              Re: FX505DT IT8987E
              Wise decision.Btw, what is the issue with your MB?
              • trepachka
                • Oct 2022
                • 439
                Re: FX505DT IT8987E
                The motherboard is completely dead. I get no lights, nothing. The 19v rail is present. I found the IC chip shorted, ordered the new chip from China 2 weeks and had it installed today. The short where I found it is no longer there. However, the motherboard is still dead. I only get 19v line. I am looking for suggestions. Thanks.
                • rediii
                  h???, spurrrn
                  • Mar 2018
                  • 496
                  • somewhere in europe
                  Re: FX505DT IT8987E
                  be aware of fake chips. nowadays it is a really big problem and best would be to harvest chips from dead motherboards...
                  • trepachka
                    • Oct 2022
                    • 439
                    Re: FX505DT IT8987E
                    Looks like the issue is with dc line 1st mosfet. I checked both mosfets and they are good. The gate on the 1st mosfet is showing 0V. Please, correct me if I am wrong. The gate should get about 10v and it is powered by SM4511NHKPC-TRG chip (ACDRV, pin 4). There is a resistor between the gate and ACDRV and it measures 4K Ohms which is correct.
                    So, does it mean the SM4511NHKPC-TRG chip is not enabled or may be faulty? Can someone suggest what I need to check next? I do not have enough knowledge to proceed from this point on.
                    Thanks.
                    • trepachka
                      • Oct 2022
                      • 439
                      Re: FX505DT IT8987E
                      I forgot to mention that I am referring to bq24780S chip.
                      The following pin measurements were taken:
                      ACDET (pin 6)=2.7V
                      VCC (pin 28)=19.43V
                      PHASE (pin 27)=0.4V
                      HIDRV (pin 26)=0.4V
                      BTST (pin 25)=1.35V
                      REGN (pin 24)=1.42V
                      It is my understanding ACDET is higher than 2.4V. So, unless there is a short on the motherboard, the chip is supposed to provide power to 1st and 2md mosfet to open the gates. I have not been able to find any shorts at this moment.
                      • mon2
                        • 14598
                        Re: FX505DT IT8987E
                        REGN (pin 24)=1.42V
                        This is a low voltage and is an internal LDO that should offer 6 volts.
                        Locate and remove the ~4k resistor on the ACDRV pin. Flux it and remove with care using tweezers. Do not lose the part.
                        What is the voltage to ground now of REGN pin? ACDRV pin?
                        ACDRV should be ~25 volts but will only be this boosted value if REGN is ~6 volts.
                        Remove all power and measure the resistance to ground of the REGN pin.
                        If the resistance is not low, suspecting that this charger IC is defective and will need to be replaced. Common to source on Mouser / Digikey / Aliexpress and many other sites.
                        https://www.mouser.com/ProductDetail...NvLnK4Wg%3D%3D
                        • trepachka
                          • Oct 2022
                          • 439
                          Re: FX505DT IT8987E
                          REGN pin resistance to ground is 60 ohms with a capacitor between the pin and ground. I ordered the chip and it should be here in a couple of days. I will test all of this then. At this point I suspect this chip is faulty but I will find out soon.
                          • mon2
                            • 14598
                            Re: FX505DT IT8987E
                            Agreed. Remove the cap and check if the resistance increases or not. It is way too low for this LDO rail. If the resistance increases to be much higher, then the cap is clearly shorted and needs to be replaced. Without the cap the LDO should return to ~6 volts.
                            Next suggestion is the same, replace this charger IC.
                            • mcplslg123
                              • Jun 2015
                              • 7262
                              • india
                              Re: FX505DT IT8987E
                              Before ordering the charger IC
                              01.Remove the cap on REGN pin and check resistance to GND again
                              02.If resistance remains same after step#1,remove the charger IC and repeat the measurement.
                              03.Order the charging IC if resistance increases significantly after step#2.
                              • trepachka
                                • Oct 2022
                                • 439
                                Re: FX505DT IT8987E
                                The chip arrived yesterday and I had it soldered in. ACDET pin reads 2.7V, VCC pin reads 20.4V, REGN pin reads 6V, ACDRV reads about 26V. I checked some coils and was able to detect 5V, 3.3V ad 1.8V power rails. So, I had the computer fired up. The keyboard kept cycling yellow letters on and off, on and off. I had the computer turned off. I checked the readings on the chip and while REGN pin still reads 6V, ACDRV went to 0V. I left the motherboard for an hour or so. I came back and had the charger plugged in. ACDRV went to 26V again for about 10 seconds or so and then went to 0V again.
                                I am just wondering if I have a faulty chip?
                                • mcplslg123
                                  • Jun 2015
                                  • 7262
                                  • india
                                  Re: FX505DT IT8987E
                                  May be soldering of the chip is the issue.Check once more.
                                  • trepachka
                                    • Oct 2022
                                    • 439
                                    Re: FX505DT IT8987E
                                    I visually inspected the soldering, also make sure each pin was connected to other components. I found IT8987E BXS that I replaced recently, several pins are now loose. I have not soldered them back to the board. Just wondering whether this could also pull the voltage on ACDRV down to 0V. I am sorry for all the questions. I am really new to this.
                                    • mon2
                                      • 14598
                                      Re: FX505DT IT8987E
                                      Remove the 4k resistor on the ACDRV pin. Do not lose this resistor.
                                      Power up again and check the ACDRV voltage at the charger IC pin.
                                      Is it now ~25v and stable?
                                      • mcplslg123
                                        • Jun 2015
                                        • 7262
                                        • india
                                        Re: FX505DT IT8987E
                                        If SIO is not soldered properly, the motherboard can behave absurd. Use good quality flux and touch up all the pins of SIO properly. Clean the area with IPA then check whether any pin is still loose. Post a clear pic of SIO soldering before doing anything and then again after the touchup job.
                                        • DynaxSC
                                          ASRock B650M PRO RS - BIOS CHIP 25Q256JW BLOCKED BY STATUS REGISTERS
                                          by DynaxSC
                                          Hi
                                          I have then desoldered the chip, backupped the contents, and tried to earease the chip in order to program stock image, but the chip is locked by status registers SREG2 (TB) and SREG6...
                                          08-04-2025, 12:20 PM
                                          Common SPI bios chip programming Questions and Answers
                                          by SMDFlea
                                          Q: I have a bios request,i can`t post my backup as i can`t read from the chip.
                                          A: If you can`t read from it how do you expect to write to it ?.
                                          Q: Why is my bios chip unreadable ?.
                                          A: The programmer is faulty or has a worn or broken zif socket.
                                          The USB cable is frayed,connector pins worn or some other physical damage.
                                          Not enough amperage or voltage to power the programmer properly.
                                          Bad...
                                          09-02-2021, 04:40 PM
                                        • macmino
                                          Buffer data does not match SPI chip!
                                          by macmino
                                          Hi all, after several attempt, I finally got a working CH341 Pro working USB device. Now I'm able to read dump the BIOS
                                          When I verify the image (800G6_EC_RCunlocked.BIN found on this forum) I receive "Buffer data does not match SPI chip!". I tried different programmer but the message is the same. Anyway, I removed the password but I see at the boot the HP Message:
                                          "HP Endpoint Security Controller Problem"
                                          When I hit OK, the boot continues and I'm able to use the computer. Did. the SPI chip not match error caused the error?
                                          09-08-2024, 09:52 AM
                                        • BMCappelletti
                                          Asus Chromebox CN62 - wrong chip put on BIOS reader
                                          by BMCappelletti
                                          Long story short:
                                          - dad converted Asus Chromebox CN62 into Windows compatible, with mrchromebox BIOS, years and years ago
                                          - gave the computer to his son a couple years later
                                          - son now decided to revert it to Chrome OS, to sell it as original (re-writing BIOS with the backup one created by his dad)
                                          - too lazy to remove the board from the case, thought a voltage regulator was the BIOS chip (you know... it has 8 legs)
                                          (seems like the story was not that short)
                                          He used alligator clips to read the chip. No luck reading it. Removed chip and placed on a SOC-8...
                                          01-08-2025, 07:27 PM
                                        • Troystain
                                          Help EZP2023+ updated chip database for w25q256jveq?
                                          by Troystain
                                          Hello, anyone here have updated ezp2023+ chip database in .dat file format.
                                          I need to add w25q256jveq chip but I do not know what data should I type.
                                          I'm using the ezp chip dabase editor posted from here https://www.badcaps.net/forum/troubl...ro-programmers
                                          The currenty unit model that I am trying to detect is HP elitebook 640 g9 which is currently locked on admin bios....
                                          11-25-2024, 12:53 AM
