Asus GL503VD Not charging or powering on
  • mon2
    • Dec 2019
    • 14002
    Re: Asus GL503VD Not charging or powering on
    Does your power supply support CC = constant current ?
    • Jasonexe
      • Apr 2023
      • 69
      • Belgium
      #62
      i think it does but i will send the link of the powersupply i got.
      https://eleshop.eu/owon-spe3103-power-supply.html
      Edit: Yes it does.
      • Jasonexe
        • Apr 2023
        • 69
        • Belgium
        #63
        Good news, i managed to repair my laptop. A SMD capacitor was causing the short, i replaced it and it’s all good now.
        • Vesko356
          VIP Moderator
          • Aug 2018
          • 4386
          • Bulgaria 🇧🇬
          #64
          Originally posted by Jasonexe
          Good news, i managed to repair my laptop. A SMD capacitor was causing the short, i replaced it and it's all good now.
          Bravo, you are lucky one, as I told you something is shorting the 19V power rail, a bad cap is the easiest case. Good job!
          Become a Badcaps supporter
          Thanks to all supporters.​
          • Jasonexe
            • Apr 2023
            • 69
            • Belgium
            #65
            Yes, i still noticed a problem. I can use the laptop with the charger but once i unplug it, my pc will turn off instantly. Windows is telling that my battery is 100%. I also tried measuring the voltage of the battery connector when the laptop is turned on and the voltage fluctuates between 0.6-0.8 volts. When i listen carefully i can hear a crackling sound close to the battery connector.
            • mon2
              • Dec 2019
              • 14002
              Remove the battery.
              Meter in dc volts mode.
              Measure the voltage to ground of each pin the battery connector on the logic board side.
              The crackling sound may be contact arcing between the battery and mating connector contacts.
              While the battery is removed, check the voltage on the battery without the laptop as a load. Is the battery charged?
              See attached.
              What is the voltage to ground of pin 15 (BATPRES#) without the battery connected?
              What is the voltage to ground of this same pin, with the battery connected?
              Remove the power adapter so that only the battery is powering the board.
              What is the voltage to ground @ PL10 (point #1)?
              point # 2 (battery mosfet gate) and
              point # 3 (battery mosfet drain pin cluster) ?
              When the battery is present, pin #15 (active low signal) must be LOW (0v).
              When the battery is absent, pin #15 should be pulled high by resistor PR531 and the voltage rail +3VPCU.
              Respectively, when the battery only is present, the charger IC should enable the battery mosfet @ PQ23 to power the logic board.
              Confirm this operation by checking the mosfet pins of PQ23.
              When the adapter is connected, PQ23 should be OFF.
              Confirm it.
              • Vesko356
                VIP Moderator
                • Aug 2018
                • 4386
                • Bulgaria 🇧🇬
                #67
                First check again the PQ21 & PQ22 fets, if one or both are shorted again, this could be the reason.
                • Jasonexe
                  • Apr 2023
                  • 69
                  • Belgium
                  #68
                  I have a problem, i desoldered the bios ic and reflashed it with a SPI programmer because I wanted to get rid of bios password. I didn’t use this laptop for a while so i forgot the password. I soldered the ic back and tested it and it was all good, i noticed that 1 pin was not fully soldered on to the board so i did the soldering process again. And after that my pc would not turn on, the weird thing is.. if i plug the charger in, the keyboard backlight would turn on by itself, but the led indicator doesn’t show that my laptop is powered on, even after pressing the power button. I desoldered the ic again after to check if nothing was shorted and I didn’t see anything wrong so i have no idea what’s going on.. it’s frustrating me. When i plug the charger in without the bios ic, i get the same thing, keyboard backlight turns on by itself.
                  • Jasonexe
                    • Apr 2023
                    • 69
                    • Belgium
                    #69
                    Hi, i managed to fix my laptop. I will check the things you asked me to do tomorrow and keep you posted.
                    • Jasonexe
                      • Apr 2023
                      • 69
                      • Belgium
                      #70
                      Remove the battery.
                      See attached.
                      Confirm it.
                      I measured voltage from pin 15 and i get a voltage that fluctuates between 0-120 millivolts, same thing when battery is connected. I confirmed that the battery is dead, i tried recharging it with a adapter but after a couple hours it was still refusing to output any voltage.
                      • Jasonexe
                        • Apr 2023
                        • 69
                        • Belgium
                        #71
                        Edit: i decided to disassemble the battery pack (4 cells) and measured voltage from each cell and i get around 3.98v. When i measure from the battery connector i get nothing. So i think that a component on the pcb where the battery cells are connected is defective.
                        I also measured voltage from the battery connector on the motherboard with the battery removed.
                        pin 1, 2 and 3: voltage fluctuates between 2.61-3.80v
                        pin 4: voltage fluctuates between 3.18-3.20v
                        pin 5: voltage fluctuates between 3.18-3.25v
                        pin 6, 7 and 8: voltage fluctuaes between 0-2mv
                        • flat-earther
                          ASUS X54H laptop thinks it's always charging even with charger unplugged
                          by flat-earther
                          The charging indicator light on my ASUS X54H laptop is always on even when the charger is disconnected.
                          Windows also shows ''Plugged in'' when charger is not connected.
                          This problem started year ago gradually, when unplugging the charger the charging light took several seconds to disappear, then minutes, and now almost always on even when unplugged for an entire day.
                          Strangely, before sometimes immediately when plugging in the charger the charging light went away, and later came back with it connected.
                          If I let battery run out and say it has 3% Windows will...
                          06-24-2025, 09:32 AM
                          ASUS ROG GL503VD-FY260T Notebook Strix Specification for Upgrade or Repair
                          This specification for the ASUS ROG GL503VD-FY260T Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the GL503VD-FY260T boardview and GL503VD-FY260T schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                          09-06-2024, 02:34 PM
                          ASUS ROG GL503VD-E4136T Notebook Strix Specification for Upgrade or Repair
                          This specification for the ASUS ROG GL503VD-E4136T Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the GL503VD-E4136T boardview and GL503VD-E4136T schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                          09-06-2024, 02:30 PM
                          ASUS ROG GL503VD-DB71 Notebook Strix Specification for Upgrade or Repair
                          This specification for the ASUS ROG GL503VD-DB71 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the GL503VD-DB71 boardview and GL503VD-DB71 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for...
                          09-06-2024, 06:00 AM
                          ASUS ROG GL503VD-DB74 Notebook Strix Specification for Upgrade or Repair
                          This specification for the ASUS ROG GL503VD-DB74 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the GL503VD-DB74 boardview and GL503VD-DB74 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for...
