Asus GL503VD Not charging or powering on
  • Jasonexe
    • Apr 2023
    • 69
    • Belgium
    Re: Asus GL503VD Not charging or powering on
    Originally posted by mon2
    How much current was consumed?
    Is the CPU with a heat sink?
    I used a DC step down converter for this so i could only see voltage but the amps that it outputs is 1A. And no i removed the heatsink, the cpu didn’t get hot. I don’t have a bench power supply with me for the moment so i will have to wait until next week. Is there any other way to find the short?
    • mon2
      • Dec 2019
      • 13988
      You will need higher current to heat up the shorted part. We use a product called Short Killer 30A (available on AliExpress). It pulses out a preset voltage at 30 amps. We often select 0v8 for the voltage. This is ample to crack open shorted capacitors.
      Wait till you have an adjustable power supply.
      • Jasonexe
        • Apr 2023
        • 69
        • Belgium
        Seems like that is the only option for now. Is 10 amps for a bench powersupply enough?
        • Vesko356
          VIP Moderator
          • Aug 2018
          • 4386
          • Bulgaria 🇧🇬
          Yes.
          Become a Badcaps supporter
          Thanks to all supporters.​
          • Jasonexe
            • Apr 2023
            • 69
            • Belgium
            Okay. thank you both for helping me, i will keep you posted when i got the bench power supply.
            • Jasonexe
              • Apr 2023
              • 69
              • Belgium
              #26
              What is better to check for shorts or for voltage injection, a switching powersupply or linear?
              • mon2
                • Dec 2019
                • 13988
                It does not matter. Switching will be smaller, light weight, more efficient from heat generation and cheaper.
                • Jasonexe
                  • Apr 2023
                  • 69
                  • Belgium
                  #28
                  Okay great, thank you.
                  • Jasonexe
                    • Apr 2023
                    • 69
                    • Belgium
                    #29
                    Hi, i got my bench powersupply now and tried injecting 1v and 1A where the short is but didn’t notice anything getting hot. I can see that it was only drawing 300-450ma when injecting.
                    • Vesko356
                      VIP Moderator
                      • Aug 2018
                      • 4386
                      • Bulgaria 🇧🇬
                      #30
                      Hi, i got my bench powersupply now and tried injecting 1v and 1A where the short is but didn't notice anything getting hot. I can see that it was only drawing 300-450ma when injecting.
                      The readings of the device may not be accurate, does it show 1A consumption if you short-circuit the two probes?
                      • nams2590
                        • Apr 2023
                        • 5
                        • France
                        #31
                        Vesko356 is right.
                        You should first try to short circuit your probes to be sure the voltage is falling and your current consumption is almost 1A.
                        Then inject again the 1V/1A to the board.
                        Do you have isopropyl alcohol?
                        If yes, you can put it on the suspected parts and check which part is getting hot by evaporation.
                        • Jasonexe
                          • Apr 2023
                          • 69
                          • Belgium
                          #32
                          Yes it shows 1A when shorting probes. I found the problem on my laptop, it took some time to find out but i found a video of someone having the same issue with a asus gaming laptop and it was a mosfet that was shorted. I remember that my laptop adapter was only outputting 0.40v when plugging it in the motherboard because of a short. So i decided to inject 19v in the charger port with my bench powersupply and slowly increase the current and the mosfet on the right side was getting hot. The short is gone after desoldering it. Both mosfets are the TPCA 8059-H so i will replace them both. I already ordered the mosfets but i have to wait for about 10 days for it to arrive.. i will keep you posted when i got it.
                          • Vesko356
                            VIP Moderator
                            • Aug 2018
                            • 4386
                            • Bulgaria 🇧🇬
                            #33
                            Don't inject 19V like this in the future, or you'll kill some chip. If you have shorted high side mosfet for example. And most probably you're wrong with your conclusion about the fault.
                            Or the initial measurements you reported were incorrect.
                            Edit: I need to see the schematic, post the link to the schematic and boardview.
                            • Jasonexe
                              • Apr 2023
                              • 69
                              • Belgium
                              #34
                              Okay,
                              I got the schematic/boardview from here: https://www.badcaps.net/forum/showthread.php?t=85104
                              • Vesko356
                                VIP Moderator
                                • Aug 2018
                                • 4386
                                • Bulgaria 🇧🇬
                                #35
                                Okay,
                                What about the schematic, is it available?
                                • Jasonexe
                                  • Apr 2023
                                  • 69
                                  • Belgium
                                  #36
                                  Yes i downloaded it from there.
                                  • Vesko356
                                    VIP Moderator
                                    • Aug 2018
                                    • 4386
                                    • Bulgaria 🇧🇬
                                    #37
                                    I don't see the schematic at that thread in your link, only the boardview?
                                    • Jasonexe
                                      • Apr 2023
                                      • 69
                                      • Belgium
                                      #38
                                      Sorry my bad, i thought that the 2 things were the same thing. I will try to look if i can find one.
                                      • Vesko356
                                        VIP Moderator
                                        • Aug 2018
                                        • 4386
                                        • Bulgaria 🇧🇬
                                        #39
                                        OК no worries, I did a quick search too but couldn't find anything, but we'll manage to sort out the problem somehow even without a schematic I believe.
                                        • Jasonexe
                                          • Apr 2023
                                          • 69
                                          • Belgium
                                          #40
                                          Okay, I will try to look for it tomorrow.
                                          • flat-earther
                                            ASUS X54H laptop thinks it's always charging even with charger unplugged
                                            by flat-earther
                                            The charging indicator light on my ASUS X54H laptop is always on even when the charger is disconnected.
                                            Windows also shows ''Plugged in'' when charger is not connected.
                                            This problem started year ago gradually, when unplugging the charger the charging light took several seconds to disappear, then minutes, and now almost always on even when unplugged for an entire day.
                                            Strangely, before sometimes immediately when plugging in the charger the charging light went away, and later came back with it connected.
                                            If I let battery run out and say it has 3% Windows will...
                                            06-24-2025, 09:32 AM
                                            ASUS ROG GL503VD-FY260T Notebook Strix Specification for Upgrade or Repair
                                            This specification for the ASUS ROG GL503VD-FY260T Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the GL503VD-FY260T boardview and GL503VD-FY260T schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                            09-06-2024, 02:34 PM
                                            ASUS ROG GL503VD-E4136T Notebook Strix Specification for Upgrade or Repair
                                            This specification for the ASUS ROG GL503VD-E4136T Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the GL503VD-E4136T boardview and GL503VD-E4136T schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                            09-06-2024, 02:30 PM
                                            ASUS ROG GL503VD-DB71 Notebook Strix Specification for Upgrade or Repair
                                            This specification for the ASUS ROG GL503VD-DB71 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the GL503VD-DB71 boardview and GL503VD-DB71 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for...
                                            09-06-2024, 06:00 AM
                                            ASUS ROG GL503VD-DB74 Notebook Strix Specification for Upgrade or Repair
                                            This specification for the ASUS ROG GL503VD-DB74 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the GL503VD-DB74 boardview and GL503VD-DB74 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for...
