MacBook Pro 13'' M2 A2338 get 5V 0A does not boot. 820-02773
  • mon2
    • Dec 2019
    • 14210
    Re: MacBook Pro 13'' M2 A2338 get 5V 0A does not boot. 820-02773
    Attach the Type C power adapter and locate the local ACE controller linked to the USB connector in use.
    Need to check the LDO rails for that ACE controller to confirm the ACE controller is not defective.
    Measure the voltage to ground of:
    PP3v3_UPC0_LDO (UF400)
    PP1v5_UPC0_LDO_CORE (UF400)
    PP3v3_UPC1_LDO (UF500)
    PP1v5_UPC1_LDO_CORE (UF500)
    Remove all power -> meter in resistance mode.
    Measure the resistance to ground of PP3v3_S2.
      • 20914
      Originally posted by slimmy182
      Any hint would be really appreciated
      In future please upload all your images to badcaps rather than use an external image host.
      Some image hosts add advertising to links for all sorts of shit,including promoting their own site.
      • slimmy182
        • Apr 2021
        • 105
        • italy
        Thank you, I will.
        Locig board connected to battery only (no DCIN) show 1.80v fuse @F5200 (2 PPBUS_AON 1 PPVBAT_AON_CHGR_REG. Is that nomal?
        Last edited by Vesko356; 05-16-2023, 12:28 PM. Reason: Removed full quote with picture.
        • slimmy182
          • Apr 2021
          • 105
          • italy
          PP3v3_UPC0_LDO (UF400) 3.44V
          PP1v5_UPC0_LDO_CORE (UF400) 1.48V
          PP3v3_UPC1_LDO (UF500) 3.44V
          1.48V
          CC717
          1 PP3v3_S2 35(2000K scale) ohms
          0 gnd 0 ohms
          • slimmy182
            • Apr 2021
            • 105
            • italy
            Really stuck on this.
            PPBUS_AON 12.30V present,
            PP3v8_AON 3.78V present,
            PP3v3_s2 0v, not shorted. PP3V3S2_EN not present as well.
            P3V3S2_DSCHG_EN_RC 3.40V present.
            LDO check on:
            U8100
            PP3V8_AON_MPMU_ISNS_VIN
            CY1M3 3.77V
            PPVDD_LDO20_14_8_3
            C8300 0V DIODIE MODE 269
            PPVDD_S2SW_VDD2H
            C83B1 0V DIODE MODE 36
            PP1V8_AON
            R8620 1.79V
            PP3V3_S2_LDO
            C8331 0V DIODE MODE 1.25 (20k multimeter scale)
            PP1V2_AWAKE_PLL
            C8360 0V DIODE MODE 358
            PP1V8_AON_MPMU
            C84A0 1.79V
            PP1V2_AON_MPMU
            C8341 1.19V
            PP3V3_AON
            C83A0 0.33V (CLIKING SOUND WHEN MEASURING) DIODE MODE 0.84 (20K SCALE MULTIMETER)
            PP0V855_S2SW_CIO
            C83B5 0V DIODE MODE 0.54 (20K SCALE MULTIMETER)
            PP3V3_S2SW_SNS
            C83D0 0V DIODE MODE 488
            PP1V2_S2_CIO
            C8350 0V DIODE MODE 01.19 (20K SCALE MULTIMETER)
            PP1V5_LDOINT_MPMU
            C8380 1.50V
            U7700
            PP3V8_AON_SPMU_ISNS_VIN
            CY1S5 3.77V
            PP1V25_S2
            RT311 0V DIODE MODE 246
            PP0V88_S1
            C77C1 0V DIODE MODE 01.27 (20K SCALE MULTIMETER)
            PP0V72_S2_VDD_LOW
            C7840 0V DIODE MODE 256
            PP1V8_AON_SPMU
            C7891 1.80V
            PP1V2_AON_SPMU
            C78A0 1.20V
            PP0V8_S1_VDD_FIXED
            C78C0 0V DIODE MODE 0.35 (20K SCALE MULTIMETER)
            PP1V5_LDOINT_SPMU
            C7810 1.50V.
            Cliking sound could be related to dead M2 chip?
            • slimmy182
              • Apr 2021
              • 105
              • italy
              #26
              Still in need for help
              • mon2
                • Dec 2019
                • 14210
                PPBUS_AON is too low.
                Reference:
                https://repair.wiki/w/A2337_2020_MacBook_Air
                Each battery has a BMS (battery management system) that communicates over smbus (i2c) lines. If either or both of the smbus (SCL and SDA) lines are stuck, this communication will fail to dial up the proper ppbus_aon voltage.
                Measure the voltage to ground of each battery connector pin. Post each measurement.
                • slimmy182
                  • Apr 2021
                  • 105
                  • italy
                  #28
                  J5151
                  1 GND
                  2 I2C_SMC_PWR_3V3_SCL 0V
                  3 I2C_SMC_PWR_3V3_SDA 0V
                  4 GND
                  5 NC
                  6 NC
                  7 SYS_DETECT_L 0.14V
                  8 NC
                  9 NC
                  10 GND
                  11 GND
                  12 GND​
                  • mon2
                    • Dec 2019
                    • 14210
                    Check pins 2 and 3 but in diode mode. Remove the battery and adapter. Red probe to ground. Black to the pin to test.
                    • slimmy182
                      • Apr 2021
                      • 105
                      • italy
                      #30
                      Both 640
                      • mon2
                        • Dec 2019
                        • 14210
                        Confirm the voltage to ground of PP3V3_AON.
                        • slimmy182
                          • Apr 2021
                          • 105
                          • italy
                          #32
                          PP3V3_AON. 0V
                          • mon2
                            • Dec 2019
                            • 14210
                            Remove all power -> measure the resistance to ground of this PP3V3_AON​ power rail.
                            • CuriousDave
                              • Aug 2024
                              • 11
                              Did you check the TPS62180 and the NAND chips? I have a few devices with 5V0A and these turned out the SSD got shorted from shorted TPS chip that sent 12V to SSD.
                              • themikesystems
                                • Jun 2019
                                • 3
                                • in
                                #35
                                Could you help with the board view for the 2022 13-inch M2 MacBook Pro?
                                • mon2
                                  • Dec 2019
                                  • 14210
                                  What is the A**** number that is laser marked on the bottom side of the laptop? The BV may be already posted (if available) inside the dedicated schematic forum.
                                  • sdogs
                                    macbook pro M1 a2338 no video on internal display PP3V3_S2 short
                                    by sdogs
                                    Greetings to the entire forum, I ask you for help because I'm going crazy. A dear friend of mine gave me a macbook pro M1 A2338 that only works with an external screen. With the internal one, no backlight or image. Only the external display is detected from the system settings.
                                    First I changed the display flat, then I made a backup with time machine and tried a reset in dfu but nothing to do, always the same problem.
                                    I analyzed the logic board, it shows no sign of liquid or visible damage. I then moved on to examine the logic with the thermal camera and found that the UP701 chip was...
                                    06-27-2025, 01:58 PM
                                  • sdogs
                                    by sdogs
                                    06-27-2025, 11:26 AM
                                  • No Lan
                                    [Macbook pro A1708] [Boot loop] [Trackpad ?]
                                    by No Lan
                                    Hey everyone,
                                    Usually, I'm not the type to ask for help, but this time, I'm calling on your wisdom and expertise I've seen what this community can do, so I'm pretty sure you guys can help me out.
                                    Here's the deal: I noticed my MacBook got stuck in a boot loop. After opening it up and doing some initial troubleshooting, I found that the boot loop stops only when the trackpad is unplugged.
                                    Now, just so you know, the trackpad actually works — I tested it with another motherboard and it's all good. Same for the cable, no issues there. The problem is only...
                                    05-24-2025, 03:09 PM
                                  • TheNuclearOption
                                    MacBook Pro 13'' M2 A2338 get 5V 0.01-0.02a does not boot. 820-02773
                                    by TheNuclearOption
                                    I bought this laptop with water damage. There is corrosion on the logic board (ive included some pics). I removed the cr634 capacitor that was burnt on the ppbus line. The pad is still shorted to ground. I'm not sure how to proceed from here, any suggestions would be greatly appreciated.
                                    The other areas ive included in the pics are the backlight circuit....
                                    02-20-2024, 05:09 PM
                                  • twonk9098
                                    Macbook Pro mid 2015 battery required to boot?
                                    by twonk9098
                                    I have read many forums that state the Macbook Pro 2015 needs / does not need a battery to boot. I'm not convinced as yet which is correct.
                                    The Macbook Pro mid 2015 I have has no battery and do not really want to buy one just to test.
                                    This model has the newer trackpad which is not clickable when turned off.
                                    At the moment, without battery it does turn on with no display (with backlight), no chime and then turns off after 13 seconds. I see this from the power draw on my DTPS.
                                    If I hold the power button whilst connecting the magsafe 2 charger it turns on, again no image but...
                                    12-10-2024, 06:51 PM
