Hello out there.
I purchased this mac MacBook Pro 13'' M2 chip, model A2338, logic board number 820-02773 as partially working. Seller give me an apple report saying: "Liquid spill on trackpad flat, BMU battery flat and logic board. Macbook starts only when connected to DC IN and show intermittent shoutdown".
Now that I got it is does not start at all, Amp mether shows 5V 0A on both usb-c.
Tearing down the logic board I can confirm there was liquid spill on the battery connector area and the battery flat. Liquid spill also on the trackpad connector and small amount on the antenna wifi connectors. I guess there was also a little moisture on the Q5800 side (referring to 820-02020 board view as 820-02773 is not present at this time).
The back side of the board is pretty clean, no sings of corrosion or cleaning.
The fact is that this moderboard was already cleaned from moisture, so I need to better check everything under microscope. Futhermore it seems to me that i'm hearing the famous clicking sound also in that board. But no components it's getting hot when plugged in.
I would be glad if somenone more skilled that me will help me troubleshotting this Mac to have it finally working. That would be really appreciated.
What I can start testing with my multimeter?
 I've seen what this community can do, so I'm pretty sure you guys can help me out.
