MacBook Pro 13'' M2 A2338 get 5V 0A does not boot. 820-02773
  • slimmy182
    • Apr 2021
    • 105
    • italy
    Hello out there.
    I purchased this mac MacBook Pro 13'' M2 chip, model A2338, logic board number 820-02773 as partially working. Seller give me an apple report saying: "Liquid spill on trackpad flat, BMU battery flat and logic board. Macbook starts only when connected to DC IN and show intermittent shoutdown".
    Now that I got it is does not start at all, Amp mether shows 5V 0A on both usb-c.
    Tearing down the logic board I can confirm there was liquid spill on the battery connector area and the battery flat. Liquid spill also on the trackpad connector and small amount on the antenna wifi connectors. I guess there was also a little moisture on the Q5800 side (referring to 820-02020 board view as 820-02773 is not present at this time).
    The back side of the board is pretty clean, no sings of corrosion or cleaning.
    The fact is that this moderboard was already cleaned from moisture, so I need to better check everything under microscope. Futhermore it seems to me that i'm hearing the famous clicking sound also in that board. But no components it's getting hot when plugged in.
    I would be glad if somenone more skilled that me will help me troubleshotting this Mac to have it finally working. That would be really appreciated.
    What I can start testing with my multimeter?
  • mon2
    • Dec 2019
    • 14243
    Re: MacBook Pro 13'' M2 A2338 get 5V 0A does not boot. 820-02773
    Since the current draw is @ 0v and stuck @ 5v, start with a review of the USB Type C controllers (aka ACE controllers).
    See attached.
    Remove all power. Meter in resistance mode. Check the resistance across the white body parts = fuses.
    Post your measurements.
    • slimmy182
      • Apr 2021
      • 105
      • italy
      Many Thanks mon2!!
      Cheking the two fuses nearby ACE controllers i've got continuity (no resistance)
      Upon connecting to DC IN i've got 5.17V on both side of each one.
      I also took those measurement (please mind that I'm using 820-02020 brd as reference):
      voltage on PPBUS_AON on FP800
      1 PPBUS_AON 12.3V
      2 PPVIN_LCDBKLT_F 12.3V
      voltage on PP3v8_AON
      L5800
      1 P3V8AON_VSW1 3.78V
      2 PP3V8AON_PH1 3.78V
      PP3v3_S2 voltage
      LC710
      1 P3V3S2_SW 0V
      2 PP3V3_S2 0V
      CD3217 support voltages
      RP844
      1 PP5V_S2 0V
      2 PP5V_BKLT_D 0V
      PP3v3_S2_UPC NOT ABLE TO LOCATE
      C5320
      1 PP1V25_S2 0V
      2 GND
      PPDCIN_AON_CHGR_R
      C520C
      1 PPDCIN_AON_CHGR_R 5.17V
      2 GND
      series of current sensing resistors
      R5221 — 1.4 Ω
      R5222 — 1.4 Ω
      R5261 — 1.4 Ω
      R5262 — 1.4 Ω
      Upon investigating board on microscope I found this spot of corrosion, see attached. Mainly around JT200, Q5840, C5800, UD560 areas.
      Last edited by SMDFlea; 05-16-2023, 05:14 AM. Reason: added external images to badcaps
      • slimmy182
        • Apr 2021
        • 105
        • italy
        Any of these part w moisture could be related to the problem?
        • mon2
          • Dec 2019
          • 14243
          Perhaps. Pour alcohol (IPA) and see if these sites can be cleaned up.
          • slimmy182
            • Apr 2021
            • 105
            • italy
            I guess the voltage of each LDO rail is present on each of the CD3217 devices.
            • mon2
              • Dec 2019
              • 14243
              I think you are missing to check one more LDO rail at 1v1? Review the schematic. Not at my desk. It is the rail used for the bmc communication over the CCx lines.
              • slimmy182
                • Apr 2021
                • 105
                • italy
                i think you are missing to check one more ldo rail at 1v1? Review the schematic. Not at my desk. It is the rail used for the bmc communication over the ccx lines.
                cant find
                those are the one I guess cheked
                1 PP3V3_UPC0_LDO
                2 GND
                CF405
                1 PP1V5_UPC0_LDO_CORE
                2 GND
                CF508
                1 PP3V3_UPC1_LDO
                2 GND
                CF505
                1 PP1V5_UPC1_LDO_CORE
                • slimmy182
                  • Apr 2021
                  • 105
                  • italy
                  Ok, damn, upon checking voltages in renases chip area I deadly short the IC. Now the board is taking 5.16V and 0.43A, consuming 2.2W. That chip is pretty hot. Any advice how to find a replacement?
                  That would be different from RAA225501A A2338 2020 logic board I guess.
                  Mine is 501CR17 H150EDN 19054131, the other is 501CR0B.
                  damn damn damn damn
                  Last edited by SMDFlea; 05-16-2023, 05:15 AM. Reason: added external images to badcaps
                  • mon2
                    • Dec 2019
                    • 14243
                    Check the resistance to ground at the output of this regulator.
                    Post the measurement. If the resistance is low (and futile) then that explains why it is heating up.
                    • slimmy182
                      • Apr 2021
                      • 105
                      • italy
                      Could you please help me locate the output?
                      • mon2
                        • Dec 2019
                        • 14243
                        Ok - found it - it is U5700.
                        All output pins need to be checked for their resistance to ground. Remove all power.
                        Measure for example,
                        pin #7 (LDO5)
                        pin #5 (PVCC)
                        pin #3 (UGATE1)
                        etc. - review the direction of the arrows on this component's library symbol in the schematic and measure each such pin to see if there is an excessive load.
                        • slimmy182
                          • Apr 2021
                          • 105
                          • italy
                          Thank you so much for helping me.
                          U5700
                          5 P3V8AON_PVCC 5.2Ω
                          7 PP5V_AON 4.4Ω
                          Are pretty shorted. I'm facing difficult on measuring other IC output.
                          I found that A2338 M1 2020 820-02020 and A2338 M2 2022 820-02773 seems to share same U5700.
                          It isn't?
                          M2 and M1 images
                          Last edited by SMDFlea; 05-16-2023, 05:17 AM. Reason: added external images to badcaps
                          • slimmy182
                            • Apr 2021
                            • 105
                            • italy
                            pin #7 (LDO5)
                            pin #5 (PVCC)
                            pin #3 (UGATE1)
                            U5700 replaced, now got 3.77V on P3V3AON. But the board is still taking 5.241V and 0A.
                            There is anything else I can check?
                            • mon2
                              • Dec 2019
                              • 14243
                              The primary rail is the USB type c adapter voltage which by default will be 5 volts. After a proper handshake over the bmc interface (CCx lines), the adapter will kick into 20volts.
                              Surprised it is 0 A current draw as downstream rails use this 5volt rail.
                              Is the meter accurate? Is the type c meter bidirectional in support? We initially had a crappy one that was unidirectional only so it reported the wrong current consumption of 0 A always.
                              Check the fuses.
                              Next, check the LDO rails on each ACE controller. The rails confirm that the ACE controllers are ok. Each controller must be working else you will be stuck at 5 volts. Review the LDO rails in the schematic for each ACE controller.
                              • slimmy182
                                • Apr 2021
                                • 105
                                • italy
                                Check the fuses.
                                As always, you were right. My type c meter is trusty, always use the same one and is bidirectional. Connecting to the transformer adapter side (not logic board side) I can detect 5.237V and 0.034A.
                                upon re-checking LDO rails and fuses for each ACE controller seems right. But I have not voltage on S2 rails.
                                Anyways I found schematis, boardview file and power supply diode mode reads pdf on famous chinese app. So from now my references are right for A2338 M2 820-02773 logic board.
                                PPDCIN_AON_CHGR_R 5V on both ports
                                LDO outputs
                                PP3V3_UPC1_LDO 3.44V
                                PP1V5_UPC1_LDO_CORE 1.58V
                                PP3V3_UPC0_LDO 3.44V
                                PP1V5_UPC0_LDO_CORE 1.58V
                                CC270
                                PP5V_S2 0V
                                RG2A0
                                1 PP3V3_S2_LDO 0V
                                2 PP3V3_UF790 0.34V
                                PP3V3_S2_USBLS1_ISNS 0V
                                PP3V3_S2_WLBT_ISNS 0V
                                PP1V25_S2 0V
                                RC714
                                P3V3S2_PWR_EN 0V
                                P3V3S2_EN 0V
                                PPBUS_AON_3V3S2_VIN_ISNS 12.30V
                                LC260
                                1 P5VS2TPS_PHASE 0V
                                2 PP5V_S2 0V
                                P5VS2_PWR_EN_RC 0V
                                I feel like UD600 could be damaged…
                                PP1V5_LDOINT_MPMU 1.48V
                                PP17V0_LDOIN 3.30V
                                • mon2
                                  • Dec 2019
                                  • 14243
                                  To me, the PP3V3_UPCx_LDO rail outputs seem high. These should be close to 3v3 according to the schematics.
                                  For now, let us ignore this.
                                  Remove all power. Meter in resistance mode. Check the resistance to ground at each inductor / coil on the board. Each such coil is linked to a local buck regulator so we are checking to see if there is a low resistance on the respective power rail. Often linked to a shorted part; ideally a shorted cap.
                                  • slimmy182
                                    • Apr 2021
                                    • 105
                                    • italy
                                    Thank you. Upon cheking, no low resistance found at each inductor / coil on the board.
                                    • slimmy182
                                      • Apr 2021
                                      • 105
                                      • italy
                                      These are the measures I take in diode mode. Mine in red, black one as reference.
                                      I'm not able to find any problem by myself.
                                      Last edited by SMDFlea; 05-16-2023, 05:19 AM. Reason: added external images to badcaps
                                      • slimmy182
                                        • Apr 2021
                                        • 105
                                        • italy
                                        Any hint would be really appreciated
                                        • sdogs
                                          macbook pro M1 a2338 no video on internal display PP3V3_S2 short
                                          by sdogs
                                          Greetings to the entire forum, I ask you for help because I'm going crazy. A dear friend of mine gave me a macbook pro M1 A2338 that only works with an external screen. With the internal one, no backlight or image. Only the external display is detected from the system settings.
                                          First I changed the display flat, then I made a backup with time machine and tried a reset in dfu but nothing to do, always the same problem.
                                          I analyzed the logic board, it shows no sign of liquid or visible damage. I then moved on to examine the logic with the thermal camera and found that the UP701 chip was...
                                          06-27-2025, 01:58 PM
                                        • sdogs
                                          by sdogs
                                          06-27-2025, 11:26 AM
                                        • No Lan
                                          [Macbook pro A1708] [Boot loop] [Trackpad ?]
                                          by No Lan
                                          Hey everyone,
                                          Usually, I'm not the type to ask for help, but this time, I'm calling on your wisdom and expertise I've seen what this community can do, so I'm pretty sure you guys can help me out.
                                          Here's the deal: I noticed my MacBook got stuck in a boot loop. After opening it up and doing some initial troubleshooting, I found that the boot loop stops only when the trackpad is unplugged.
                                          Now, just so you know, the trackpad actually works — I tested it with another motherboard and it's all good. Same for the cable, no issues there. The problem is only...
                                          05-24-2025, 03:09 PM
                                        • TheNuclearOption
                                          MacBook Pro 13'' M2 A2338 get 5V 0.01-0.02a does not boot. 820-02773
                                          by TheNuclearOption
                                          I bought this laptop with water damage. There is corrosion on the logic board (ive included some pics). I removed the cr634 capacitor that was burnt on the ppbus line. The pad is still shorted to ground. I'm not sure how to proceed from here, any suggestions would be greatly appreciated.
                                          The other areas ive included in the pics are the backlight circuit....
                                          02-20-2024, 05:09 PM
                                        • twonk9098
                                          Macbook Pro mid 2015 battery required to boot?
                                          by twonk9098
                                          I have read many forums that state the Macbook Pro 2015 needs / does not need a battery to boot. I'm not convinced as yet which is correct.
                                          The Macbook Pro mid 2015 I have has no battery and do not really want to buy one just to test.
                                          This model has the newer trackpad which is not clickable when turned off.
                                          At the moment, without battery it does turn on with no display (with backlight), no chime and then turns off after 13 seconds. I see this from the power draw on my DTPS.
                                          If I hold the power button whilst connecting the magsafe 2 charger it turns on, again no image but...
                                          12-10-2024, 06:51 PM
