please help, friend, asu ROG G750JW REV. 2.1 lvds problem
  • fredyjbi
    • Feb 2021
    • 144
    • malaysia
    asus board series g750jw rev 2.1
    the laptop turns on, the caplock lights up and works normally but the LCD doesn't display an image
    I have 2 units of this laptop, one of which has no display, so I've tried changing the flexible cable and LED and also the GPU card
    J4501
    pin list
    1 AC_BAT_INV 19v
    2 AC_BAT_INV 19v
    3 AC_BAT_INV 19v
    39 +LCD_POWER 0v
    40 +LCD_POWER 0v
    24 BL_EN 0v
    38 LCD_PWM 0v
    L4501 pin 1, 2 0v
    Q4502 pin list
    1,2,5,6 +LCD_POWR_S 3,3v
    4 +LCDPOWER 0v
    3 L_VDDEN_RR 0v
    Q4501
    1,4 gnd 0v
    5,6 L_VDDEN_P 3.3v
    3 L_VDDEN_RR 0v
    2 L_VDDEN 0v
    Q4503
    gate L_VDDEN_P 3.3v
    drain +LCD_POWER_R 3.3v
    source gnd 0v
    R4509 1 and 2 0v
    D4502
    1 LID_SW# 3.3v
    2 LCD_BACKOFF# 3.3v
    3 BL_EN_C 0v
    D4501
    1 LCD_BACKEN 0v
    2 BUF_PLT_RST# 3.3v
    3 BL_EN_C 0v
    all resistance is not short to ground
    thank you for your help friends
  • ktmmotocross
    Boardkiller
    • Feb 2014
    • 3627
    • slovakia
    Re: please help, friend, asu ROG G750JW REV. 2.1 lvds problem
    as u dont have PWM, BL_ON and +LCD_POWER
    it is not in error but it is not enabled. bad gpu, bad onboard ram, ....
    did u flash virgin bios?
    • fredyjbi
      • Feb 2021
      • 144
      • malaysia
      thank you sir for your explanation, I have flashed the bios and also replaced the vga card but it is still the same, I have 2 units one using 3d and one using a 2d vga card I tried to exchange it but the result is still the same
      • theone111
        by theone111
        3. Problem: TV shuts down
        07-22-2024, 10:36 AM
      • Zeonalbasta
        Thinkpad X1 Carbon "LMQ-1MB 12298-2 48.4LY26.021" VCC3M problem
        by Zeonalbasta
        i have a problem with thinkpad X1 carbon gen 2 "LMQ-1MB 12298-2 48.4LY26.021"
        The laptop was turned off because the MOSFET was not transmitting voltage. After checking it turned out that the gate pin on the MOSFET was the problem, because it was producing an inappropriate voltage. and it was discovered that the problem was with the Think engine, so I decided to reprint each pin, and finally the mosfet could work properly. However, there is another problem, even though the voltage has been supplied to the laptop, it still won't turn on, there isn't even an LED indicator. After double...
        09-13-2024, 01:17 PM
      • arashmoayyedizadeh
        lenovo b590 lvds problem
        by arashmoayyedizadeh
        hello friends
        i had a lenovo b590 with no display
        i programmed the bios and now it has display on vga and hdmi but not on lvds
        lvds cable and led has changed but no difference
        backlight comes up but no data
        there is one beep at startup
        pch is my suspect but i cant confirm it
        any idea?
        thank you very much
        09-01-2022, 03:27 AM
      • Gibon378
        Problem with stopping audio and video for no reason
        by Gibon378
        PC Specs:
        • CPU: Ryzen 5 1600
        • GPU: GTX 1080 Palit JetStream
        • MOBO: ASRock ab350 PRO4
        • RAM: Crucial Ballistix Sport 2x8GB 3000MHz (XMP 2.0)
        • PSU: XFX 650W (don't remember what model)
        • OS SSD: ADATA SP920
        • OS: Windows 10 21H2
        Problem description:
        Hi. I have a problem that has been going on for some time (2-3 years). It's hard to explain what it really is. Sometimes, my computer stops playing music, stops videos (starts buffering on youtube), there is no sound in games and when I minimize the game window and return to the game there is a black screen with window borders...
        11-19-2022, 09:41 AM
      • perzyk23
        Lenovo T580 - LCD Panel problem - error 0288
        by perzyk23
        Good morning,
        I have a problem with Lenovo T580, which after error code 0288 suggests a problem with the display. I checked the display and it works on another laptop. I replaced the display cable with a new one. I programmed another BIOS (downloaded from this forum) and I still have the problem of a dead display - there is an image via HDMI, and the system does not detect the built-in LCD at all. The problem appears to be hardware. What can I check to confirm or disprove this? I found many threads on the Internet related to this problem 0288, but without specific solutions. Please advise....
        10-25-2024, 12:42 AM
