lenovo b590 lvds problem
  • arashmoayyedizadeh
    • Jan 2022
    • 61
    • Iran
    hello friends
    i had a lenovo b590 with no display
    i programmed the bios and now it has display on vga and hdmi but not on lvds
    lvds cable and led has changed but no difference
    backlight comes up but no data
    there is one beep at startup
    pch is my suspect but i cant confirm it
    any idea?
    thank you very much
  • bbusterscruggs
    Lenovo B590 20208 Bios Problem
    by bbusterscruggs
    Hello, I wanted to update my laptop's BIOS from h1et40ww to h9et92ww. The website says I need to install h9et75ww first, so I tried installing that version first, but the installation failed and when I press the power button, the laptop momentarily turns on and off (the power light immediately flashes). I tried the crisis files with Fn+R but they didn't work (it works for about 30 seconds with Fn+R but nothing displays on the screen). How can I get a BIOS update file that I can use with Fn+R? Maybe I'm naming the files I put on the USB drive incorrectly. The ones I've tried are bios.bin, bios.cap,...
    09-15-2025, 11:57 AM
  • ravi_1617
    Lenovo B540 ,Starting Problem
    by ravi_1617
    Hello !
    Model Lenovo B540
    Board Details 09244-1
    LA14 DIS MB
    48.4DMO4.01.1
    This Board has starting problem , when CMOS batter is removed ,it starts (turn ON) by itself fine, than if is short power switch once board turns OFF Fine.
    when connected CMOS dont start.
    3.3 volts present at power switch (it slight less 3.267-87) .there was slight liquid spill at around U53 (SL62872HR),when I clean that area . I mean when its little hot board warm , board starts few time ON and OFF by power switch
    One more thing i want to mention ( by mistake i started at...
    10-14-2025, 02:08 AM
  • lucaszmn
    by lucaszmn
    Problem:
    Initial Findings:
    • I concluded that the
    08-12-2025, 03:01 PM
  • coasterghost
    Lenovo T14 Gen 2 Type 20XK Model 20XK0069US Odd Charging Issues
    by coasterghost
    For Badcaps Readers, Please note that I am hopefully going to present this same message to Lenovo to see if they have any insight to the matter as well and figured to share the entirety here for clarification. The System is out of warranty as it is but does have the option to have it extended.
    Model Information: T14 Gen 2 (Type 20XK, 20XL) Laptop (ThinkPad) - Type 20XK - Model 20XK0069US
    Board: T14 Gen 2 (Type 20XK, 20XL) - Type 20XK.
    System Hardware:
    Processor: AMD Ryzen 7 PRO 5850U
    Memory: 1x 16GB DDR4 3200 (Soldered on Board); 1x Crucial 32GB DDR4...
    09-08-2025, 10:46 PM
  • s_specialist
    Lenovo E15 Gen 2 GE4B0 GE5B0 NM-D011 Rev 1.0 sometimes not opening problem
    by s_specialist
    Recently, I have started to encounter a problem with Lenovo E15 Gen 2 models not opening. When you try to open the device, it gives a warning sound and does not display an image, when you apply light pressure on the keyboard, the image appears and works for a while, when you turn it off and on, the same thing happens again. Bios was tried, RAM slots were cleaned and soldered to the legs, the problem still persists. There seems to be a problem with the onboard processors, but since Lenovos glue the processor firmly from the sides, the paths are very damaged when removing it. Has anyone encountered...
    07-07-2025, 11:47 AM
