macbook a2251 820-01949a no power 20V ok
  • reset1986
    • Dec 2014
    • 308
    • italia
    hi all, this mac won't turn on, it seems that the battery is charged when I put the power supply, but there is no rotation of the fan and ignition,
    I can't find shorts, I measured the 20V and they are ok
    PP3V3_G3H 3.4v
    PP5V_G3S 5v
    PP3V3_G3H_RTC_REG_R 3.3V
    l7030 12.25 rising,
    i notice the l7030 gets warm but i think its normal for charging,
    what could i check? Thank you
  • mon2
    • 14662
    Re: macbook a2251 820-01949a no power 20V ok
    What is the voltage to ground of PPBUS_G3H @ F7000 ?
    • reset1986
      • Dec 2014
      • 308
      • italia
      f7000 11.30v with battery
      with battery and power supply 11.80 and tends to go up
      • mon2
        • 14662
        According to:
        https://repair.wiki/w/A2251_2020_13%22_MacBook_Pro
        ~12.60–12.65 V = Normal
        So flux and remove F7000. Then check the voltage of this rail again on the PCB pads.
        Post the measurement.
        • reset1986
          • Dec 2014
          • 308
          • italia
          According to:
          ok, removed, on one side 0, on the other 12.25, both with and without battery
          • mon2
            • 14662
            From the above repair wiki link:
            ~12.28–12.35 V = T2 communication issue with the ISL9240. The likely cause for this is the device is stuck in DFU mode due to corrupt T2 firmware or a failed CD3217. Proceed to repair steps below for corrupt T2 firmware.
            • reset1986
              • Dec 2014
              • 308
              • italia
              ok, I have an old imac with osx available, from what I've read, do you have to connect both macs with usb-c?
              • piernov
                • Jan 2016
                • 4439
                • France
                Of course T2 won't communicate if PPBUS_G3H is disconnected.
                Still T2 DFU recovery can be attempted if data is not important. (with the fuse in place obviously)
                Also this voltage is only relevant when battery is disconnected as always.
                • reset1986
                  • Dec 2014
                  • 308
                  • italia
                  ok,all the symptoms seems to have the t2 corrupted,i was wondering if it was possible to flash like on motherboards with external programmer
                  • SarcasticOP
                    General question about MacBook power rails for repair.
                    by SarcasticOP
                    I am looking at an A2337 and found this for the order of power rails and what they do. Can this be confirmed before I dive into hunting down power rails that do not exist or are not neccisary?
                    • PPBUS_G3H (12.6V-12.8V)
                      • This is the main power rail that supplies power to the entire system. Check this rail first, as it must be present for other power rails to work.
                    • PP3V42_G3H (3.42V)
                      • This power rail is derived from PPBUS_G3H and is used to power the SMC (System Management Controller) and other essential circuits. It should be present if PPBUS_G3H is working correctly.
                    • PPVRTC_G3H (3.3V)
                      • This
                    12-12-2024, 05:50 PM
                  • Tynan Dill
                    by Tynan Dill
                    Assuming...
                    11-22-2024, 01:46 PM
                  • PantherDave
                    by PantherDave
                    Hi all!
                    05-29-2024, 02:01 PM
                  • GLISIT
                    by GLISIT
                    01-16-2025, 02:29 PM
                  • Arshad alam4659
                    macbook a2251 no power
                    by Arshad alam4659
                    i have a macbook a2251 820-01949-a 5v stuck with 0.274ma
                    some measured volt
                    PP3V3_G3H_RTC=3.3v
                    PP3V3_UPC_X_LDO=3.3v
                    PP1V8_SLPS2R=1.8v
                    PPBUS_G3H=12v
                    PP3V3_G3H=3.3v
                    P5VP3V3_VREG3=3.3v
                    PP5V_S5_LDO=0v
                    PP20V_USBC_X_VBUS=0v...
                    10-24-2024, 02:29 AM
