MacBook 12" 2016 820-00244
  • waterchill
    • Sep 2021
    • 33
    Good day friends, so I have here this MacBook which is drawing 20V 180mA only the Mainboard and 400mA with battery. No Apple logo no boot. I have actually no clue where start to check voltages because it is drawing current. Could it be that is a cpu damage like the 2015 models?
    greets
  • mon2
    • 14659
    Re: MacBook 12" 2016 820-00244
    Check voltage to ground of PPBUS_G3H @ F7040.
    Also confirm the voltage to ground of PP3V3_G3H.
    • waterchill
      • Sep 2021
      • 33
      Thanks for help
      Here are some voltages:
      PPBUS_G3H = 8,70V
      PP3V3_G3H = 3,30V
      PPDCIN_G3H = 19,7V
      PP3V3R3V0_AON = 3,3V
      PP5V_G3H = 5,1V
      PP5V_S4 = 5,1V
      PP5V_S0 = 5,1
      PP3V3_S5 = 3,3V
      PP3V3_SUS = 3,3 V
      PP3V3_S4 = 3,3 V
      PP3V3_S0 = 3,3V
      PP1V8_SUS = 1,8V
      PP1V8_S3 = 1,8V
      PP1V5_S0 = 1,5V
      • mon2
        • 14659
        Attach a USB mouse. Do you see activity on the mouse during boot? (Red led)
        • waterchill
          • Sep 2021
          • 33
          Not sure how to do this because there is only one usb port. I have USB hub which has 2 normal usb ports and usb-c for load but if you plug in the mouse and plug in DC there is mouse activity without macbook.
          • mon2
            • 14659
            Use your external USB hub with any USB thumb drive with a led and connect all to your laptop.
            Check if the led on the thumb drive flickers during power on cycle. Checking for USB activity which is linked to the USB host controller inside the PCH (CPU).
            • waterchill
              • Sep 2021
              • 33
              It looks like it would like to read something and then it cut down the power. I see a problem because with the hub it is only providing 5V not 20V. Actually I have plugged in power for little longer and it seems to charging the battery actually with 1,4A and 20V. I will wait untli fully charged and try later to start with battery. I have noticed that the D6900 light is on. I don't know what this is for. With the hub the Diode is blinking.
              • mon2
                • 14659
                If the USB drive LED is blinking then there is hope that the CPU is alive. Yes, do continue to review with a pre-charged battery.
                A good USB hub for Type C should permit the negotiations to 20V power delivery contract.
                Be sure you are using the original or confirmed suitable Type C power adapter that can deliver 20V.
                • waterchill
                  • Sep 2021
                  • 33
                  So the charging looks like fake charging because since one hour still 1,4amps. The whole mainboard is warm especially the cpu. I can also plug off the charger, system still running with battery because if connect usb stick the led on the stick is on. Also the monitor notice that there is a signal but no signal there.Very strange
                  • mon2
                    • 14659
                    Does the USB stick remain solid ON or also blinks?
                    If solid on, this means that the USB VBUS of 5v is present. If it blinks, then there are attempts being made by the CPU to read the contents of the USB stick.
                    This model is nasty for CPU failures.
                    • waterchill
                      • Sep 2021
                      • 33
                      I found an old usb stick, this turns on for 5 seconds and then goes off. Doesn't matter if macbook started with battery and only plugged in usb stick or with usb hub
                      • mon2
                        • 14659
                        Check the voltage to ground of
                        PPVCORE_S0_CPU
                        Remove all power. Meter in resistance mode.
                        Check the resistance to ground of PPVCORE_S0_CPU.
                        Post your measurements.
                        • waterchill
                          • Sep 2021
                          • 33
                          Voltage is 0,0V and Resistance 10,2ohm. Measurements took on C1130
                          • waterchill
                            • Sep 2021
                            • 33
                            I have checked with a 2017er 12" macbook, resistance is same 10,5ohm but voltage is 0,635V. I will later check the parts which producing this voltage
                            • mon2
                              • 14659
                              PPVCORE_S0_CPU regulator will have an enable pin. Check the voltage to ground of the enable pin to confirm if the power rail is being enabled or not.
                              • waterchill
                                • Sep 2021
                                • 33
                                I have checked:
                                VCIN of U7210 and U7230 = 5,10V
                                VIN of U7210 and U7230 = 8,70V
                                ZCD_EN = 0V = CPUCORE_FCCM
                                CPUCORE_FCCM is produced by U7100
                                VIN of U7100 = 8,7V
                                VCC of U7100 = 5,1V
                                I don't see an enable pin for U7100. Schematics says for VIN 12,9V I got 8,7V. Maybe this is problem or bad U7100? Or something else?
                                • npielawski
                                  MacBook Pro late 2016 (820-00239) with multiple failure modes.
                                  by npielawski
                                  I will just preface all this by saying that I have a fairly technical background but have never attempted SMD electronics diagnostics and repair before, I really like the idea and want to learn.
                                  I have a MacBook Pro late 2016 that died maybe four years ago. Over the course of 30 seconds, it got slower and stuttered, until it froze for a second and died. No click from the trackpad anymore, nothing. I started getting interested in electronics repair and decided to give it a shot, so I opened it, removed the battery (one cell was puffy), took out the motherboard and experimented with...
                                  10-15-2025, 01:53 AM
                                • samstown
                                  Apple 076-00236 Genuine Apple Data Migration Tool for MacBook Pro 2016 2017
                                  by samstown
                                  This special tool from Apple is used to recover data from Macbook A1706. I've been using it for a while but it stops working. When connecting Thunderbolt 3 between the tool and working Macbook, Macbook should prompt "new device detected, allow or not"... but it doesn't.
                                  Has anyone ever experience this ? It's not a cabling or power supply issue, some IC have stopped working but not sure which one. Probably the one that manager thunderbolt 3
                                  Claude...
                                  05-09-2024, 02:02 AM
                                • envym
                                  by envym
                                  Hi everyone!
                                  06-27-2025, 08:54 AM
                                • shlomim412
                                  macbook pro a1990 - 820-01041 drawing 5v on usb c port
                                  by shlomim412
                                  Hello
                                  working on a 820-01041 a1990 macbook pro
                                  the machine is only drawing 5v on usb c ports, and around 0.24a
                                  one board measured 5v and 0.00a but later when i connected again it's went to 0.24a
                                  ppbus is 12.27v-12.29v
                                  is not recognized on apple configurator on dfu or recovery
                                  can't seem to find a short anywhere on board but with the power adapter connected (without battery)
                                  i notice the t2 chip is getting a little hot..
                                  pp1v8_slps2r present and doesnt seems to be shorted..
                                  any ideas? how can...
                                  07-16-2024, 12:58 PM
                                • Flasman90
                                  Macbook Pro DFU Restore Issues
                                  by Flasman90
                                  I have a 2020 Macbook Pro A2289 and after many attempts managed to get it into DFU mode, using my older 2017 A1706 Macbook Pro (Running Ventura 13.7.8). However, when attempting 'Restore', it fails at step 4 of 4, showing the following error:
                                  - "The operation couldn’t be completed. (AMRestoreErrorDomain error -1 - Failed to handle message type StatusMsg (Generic error)) [AMRestoreErrorDomain – 0xA (10)]
                                  - "The system cannot be restored on this device. Failed to create new state machine for restore [com.apple.MobileDevice.MobileRestore - 0xFB1 (4017)]
                                  08-30-2025, 10:27 AM
