Dell LA-F115P
  • RickyGrizutti
    • Mar 2021
    • 13
    • Argentina
    Dell LA-F115P
    Hey guys, how are you?
    I am having a problem with a Dell Notebook (Mother Compal LA-F115P)
    The problem is the following: When I connect an original charger, the equipment turns on, but not the display. If the machine is off with the battery connected and plugged into the charger, the charger charges the battery (Therefore it is not a PSID problem (I even have data transfer)).
    If I start on battery, the computer boots normally. And here's the weird thing, if I connect a power supply or a generic charger, the machine turns on, shows a display and obviously I get generic charger alerts. The last test I did is power up on battery and plug in the original charger and the machine freezes.
    Does anyone have any idea what could be the cause? The equipment came with a changed BIOS, I downloaded it from the official page and updated it with the programmer
    Note: The charger works, because with other Dells, they work perfectly for me
  • kalilinux25
    • Mar 2018
    • 2089
    • ZAMBOANGA SIBUGAY
    Re: Dell LA-F115P
    hi mate good day , ill help you lets focus on the charger ic test all voltage f the charger ic .
    Tip always put schecmatic
    • RickyGrizutti
      • Mar 2021
      • 13
      • Argentina
      Re: Dell LA-F115P
      Hello, thanks for answering! I didn't understand. Do you want measurements to know the measurements of the CHARGER (PUB01)? If so, which pins do you want to know?
      • mon2
        • Dec 2019
        • 14231
        Re: Dell LA-F115P
        What is the voltage to ground of the PSID at the dcin connector?
        • RickyGrizutti
          • Mar 2021
          • 13
          • Argentina
          Re: Dell LA-F115P
          I couldn't tell you exactly right now since I'm not in the workshop. But what is that question about? I clarified that the PSID is not only in 3V on both sides (jack and EC), but by measuring with an oscilloscope I have data transfer, what is necessary for the EC to know that it is an original charger that is connected.
          • mon2
            • Dec 2019
            • 14231
            Re: Dell LA-F115P
            What is the power rating of the original charger that is failing?
            What is the power rating of the generic adapter that works?
            There are numerous public articles on the operation of the single wire communication for the PSID line and with use of emulators to allow for home brew adapters.
            • RickyGrizutti
              • Mar 2021
              • 13
              • Argentina
              Re: Dell LA-F115P
              The original charger is 65 watts.
              The alternative charger also 65 watts
              And I have a 30v 5 amp adjustable source
              • kalilinux25
                • Mar 2018
                • 2089
                • ZAMBOANGA SIBUGAY
                Re: Dell LA-F115P
                better use yoour original charger
                • RickyGrizutti
                  • Mar 2021
                  • 13
                  • Argentina
                  Re: Dell LA-F115P
                  I'm using the original charger
                  • mon2
                    • Dec 2019
                    • 14231
                    Re: Dell LA-F115P
                    To learn about the PSID interface details:
                    https://www.mikrocontroller.net/topic/186476
                    • RickyGrizutti
                      • Mar 2021
                      • 13
                      • Argentina
                      Re: Dell LA-F115P
                      Perhaps I'm not explaining myself well. I have an original charger (which works and has the same watts as the device uses) (I tested it on other Dells) that when I connect it to the device, the machine turns on, but there's no image, even though I have one-wire communication (measured with an oscilloscope). On the other hand, when I connect a regulated power supply or a generic charger, the machine turns on, displays an image, but obviously doesn't charge the battery and runs slowly. The question is, what could be happening that with an original charger working, the device doesn't display an image
                      • mon2
                        • Dec 2019
                        • 14231
                        Re: Dell LA-F115P
                        Read your post #5
                        • BTubbs200
                          Dead Dell Latitude 5420 not receiving 20 volts from USB-C charger
                          by BTubbs200
                          Dell Latitude 5420 P137G
                          Board: LA-K491P REV A01
                          I have received this laptop which was described as "does not power on or accept charge." Battery shows no sign of charging when charger is plugged in, nor does the board show any signs of life when battery is unplugged and charger is plugged in. No light from the LED at all or any other indications of activity.
                          Board seems to have no shorts, all power rails are fine and show high resistance.
                          When charger is plugged in, voltage is present in 3.3V rail but absent in others....
                          01-24-2025, 08:15 PM
                        • Johndill
                          Dell Inspiron 7567 LA-D993P odd charger issue
                          by Johndill
                          Hi, I have a Dell Inspiron 7567 LA-D993P that I've just got running.
                          There was corrosion around PU1503 which shorted PC1518 & blew PL1504. (Reference pictures attached)
                          I've replaced PC1518 & PL1504 & the laptop is now running however I now have another issue.
                          Here are the tested scenarios:
                          1. With the laptop running on battery, I plug in the 150W charger & the charger shuts off (no LED, protection mode) but the laptop remains running on battery.
                          2. With the laptop off, plug in charger (LED says on) & the front charging...
                          11-16-2022, 10:55 PM
                        • Bowline
                          by Bowline
                          06-11-2025, 10:13 AM
                        • PowerAmpFreak
                          Dell Latitude 7280 does not recognize charger
                          by PowerAmpFreak
                          I have a Dell Latitude 7280 which complains during boot-up that the charger wattage cannot be determined. Tested with two different chargers.
                          Any common faults that could be fixed?
                          I replaced the DC jack, the original DELL LATITUDE 7280 DC30100Z300 0DP4VC.
                          How does the communication between the charger and the PC work?...
                          07-28-2025, 07:18 AM
                        • flat-earther
                          ASUS X54H laptop thinks it's always charging even with charger unplugged
                          by flat-earther
                          The charging indicator light on my ASUS X54H laptop is always on even when the charger is disconnected.
                          Windows also shows ''Plugged in'' when charger is not connected.
                          This problem started year ago gradually, when unplugging the charger the charging light took several seconds to disappear, then minutes, and now almost always on even when unplugged for an entire day.
                          Strangely, before sometimes immediately when plugging in the charger the charging light went away, and later came back with it connected.
                          If I let battery run out and say it has 3% Windows will...
                          06-24-2025, 09:32 AM
