Dell laptop charger light comes on for a sec and turns off?
  • irepair559
    • Dec 2022
    • 134
    Hello guys i have a dell laptop , a newer one but doesnt power on.
    When i plug in the charger i get a white light for a sec then 2 fast blinks
    I did notice it was getting 19v on drain but not on other side nor on gate..
    I did notice many mosfets Source's are measuring 1 ohm to ground and some around 70ohms, idk if thats normal?
    what would be the next step?
    Ps i see no water damage or anything unordinary , board looks new.
  • kalilinux25
    • Mar 2018
    • 2069
    • ZAMBOANGA SIBUGAY
    Re: Dell laptop charger light comes on for a sec and turns off?
    https://www.badcaps.net/forum/showthread.php?t=112584
    post #3 schematic
    • kalilinux25
      • Mar 2018
      • 2069
      • ZAMBOANGA SIBUGAY
      Test the first and scecond mosfet
      first mosfet is PQB11 check if voltage passes to the other side on pin 1,2,3 ,
      If
      19v is not [present, power off , ohms mode test pin 5 to 1 resistance and pin 5 to 4
      same process to the secnd mosfet also
      • irepair559
        • Dec 2022
        • 134
        which would be the first mosfet ? Left or right one?
        • mon2
          • Dec 2019
          • 13870
          PQB11.
          See attached.
          • irepair559
            • Dec 2022
            • 134
            Originally posted by mon2
            PQB11.
            See attached.
            how can that be the first mosfet ? its a ways down from the dc jack ? i thought it would be those i pictured near the dc jack
            • irepair559
              • Dec 2022
              • 134
              If
              im getting 19v
              • Sephir0th
                • Oct 2020
                • 1262
                Next step could be to look which power rails are coming up as soon as you plug the charger and if you loose some voltages when the white light disappears.
                The big grey coils all over the board would be good points to check for voltages.
                FairRepair on YouTube
                • irepair559
                  • Dec 2022
                  • 134
                  i get 19v here at these mosfets drains but not on other side
                  • Sephir0th
                    • Oct 2020
                    • 1262
                    Well, if you don't follow the advise you likely won't make any progress here.
                    These two phases are very likely related to the VRM circuit, probably +VCC_CORE, which comes up in the late sequence.
                    • irepair559
                      • Dec 2022
                      • 134
                      i thought i did what you asked? sorry so u want me to measure what points "loose" power as soon as the light is off? thats only half a second or so thatll be hard. Ill probe around coils to see what readings i can get. Thanks
                      • Johndill
                        Dell Inspiron 7567 LA-D993P odd charger issue
                        by Johndill
                        Hi, I have a Dell Inspiron 7567 LA-D993P that I've just got running.
                        There was corrosion around PU1503 which shorted PC1518 & blew PL1504. (Reference pictures attached)
                        I've replaced PC1518 & PL1504 & the laptop is now running however I now have another issue.
                        Here are the tested scenarios:
                        1. With the laptop running on battery, I plug in the 150W charger & the charger shuts off (no LED, protection mode) but the laptop remains running on battery.
                        2. With the laptop off, plug in charger (LED says on) & the front charging...
                        11-16-2022, 10:55 PM
                      • Bowline
                        by Bowline
                        06-11-2025, 10:13 AM
                      • Tonnie
                        Dell Latitude E6440 - Charger light goes out when plugged in
                        by Tonnie
                        New user here with a similar situation as described on other thread with similar Dell unit. I hope someone can help me out in this case.
                        Motherboard VAL91 LA-9932P. I read the whole thread through and this was a good start to figure my problem out, although I am not quite sure if my situation is slightly different as per visual inspection it is obvious that something blew out and I need some guidelines on how to proceed to troubleshoot it.
                        I am posting a couple of images, one is the taken on the suspected part in question which I believe...
                        08-29-2023, 10:22 PM
                      • manol278
                        Dell laptop E6440 val91 la-9934p turns off
                        by manol278
                        Hi. I have problem with dell laptop E6440 val91 la-9934p rev.1.
                        I turn on the laptop and it turns off instantly. After 5-6 attempts it turns on normally. I saw that it was burnt PU800, CD3301B Power Controller Chip.
                        If you see in the photo someone tried to do bypass and remove PR831, PR832, PC820, PR838.
                        I will replace CD3301B. I have the schematic but i dont know what are the characteristics of other componets to replace...
                        [Mod. Edit]
                        Schematic -> https://www.badcaps.net/forum/troubl...cs-theory/trou...
                        01-26-2024, 11:50 AM
                        High Pressure Sodium Yard light when air conditioner turns light momentarily turns of
                        by sam_sam_sam
                        I have had these 70 watt high pressure sodium yard lights for many years now probably at least 15 years or more and there is a protection diode that after several years starts to go bad and when it does this it has momentarily shutting down the light and then a few minutes later it starts working again
                        This about the forth time I have fixed this one and you can tell if it the diode or not if it lights up and it only shuts down when the air conditioner turns on then it is the diode
                        If it cycling on and off constantly then it is the bulb itself that is the issue
                        06-03-2023, 05:24 PM
