HP LA-K321P low res on +5Valw
  • jasko_jacker
    • Oct 2014
    • 1140
    • italy
    HP LA-K321P short on the +5VALWP line.
    I injected 5V and UA1 (ALC3287) is very hot, after removing it +5VALWP = 5V but the resistance on this line is only 80ohm. If I inject 5V/5A the consumption is only 10mA (80 ohm only on +5valw see picture) but if I try to turn on the board the led turns on for a few seconds and then turns off. I don't know if the card doesn't turn on for 80 ohms or if there is a problem on another component. On the diagram on page 5 looking at the pwr sequence it seems to me that many voltages should be present before the power button is pressed (PBTN_OUT#) is this correct or am I wrong? I thought of a problem with the PCH even if it usually concerns the 3Valw line. Naturally I tried to reprogram the two bios without result.
    MOD Edit: Link to schematic -> https://www.badcaps.net/forum/showthread.php?t=111570
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: HP LA-K321P low res on +5Valw
    80 Ohms at 5VALW does seems low but its very difficult to findout whats causing it as very low consumption on injection. If you have 10A dc supply, try injecting 5V/10A on +5VALW line and see if it helps. Another way is to manually remove components on +5VALW line to see if resistance increases. I dont see a easy way out.
    PS: Remove card reader,lan chip, usb diodes as well.
    • dellxps15
      • Feb 2014
      • 1598
      • italy
      12.6 vb 5valw , 3valw, 1,8valw are present when psu is connected (page 3 on schematic).
      80omh seems low on 5valw rail.
      10mah for 5volt is 0,05 watt.... so no short
      check resistance on j2 jump near u10.
      check u10 if +5vs is on when powered on.
      check pqd11 pqd12 volts on drain source gate to be sure that gate get right voltage for full open circuit.
      • cubytus
        Samsung UN50TU8000FXZC shows thin horizontal green line when warm
        by cubytus
        Hi to all,
        I was given this TV, an entry-level 4K 50" set. Some have criticized its lack of contrast and relatively poor colour rendering, but for my needs, it's very decent.
        I reset everything to factory settings, but this line keeps on fading in and out when watching a streaming channel from the Tizen firmware. Interestingly, it only happens when TV is warm, after about 1h45 of it being turned on.
        Watching a movie from an external source doesn't trigger the line as easily (needs 2 hours), and from a normal viewing distance, is hardly noticeable. It...
        01-10-2024, 01:26 AM
      • otaku_nut
        Vizio E701i-A3 fixed but now has red vertical line
        by otaku_nut
        Hi all, I tried searching the site for answers but I'm a bit over my head understanding some of what might apply and what doesn't, so please be patient with me. I used Freakaftr8's fix to remove the left driver board to restore picture to a black screen with sound Vizio E701i-A3. After doing so, I now have a large red vertical stripe down the center of the screen. The fix did require getting another t-con board from online, I ordered it before I knew about the mosfit fix for the old t-con board. I have tried cleaning the cable connections to the t-con board. I swapped the cables going from...
        08-19-2025, 06:11 PM
      • TrueSword88
        Kogan - KALED65XU9220STB - Blue Vertical Line
        by TrueSword88
        Hi all.
        I have a Kogan 65' LCD Panel with a thin blue vertical line (top to bottom) on left hand side of panel.
        The line just happens to coincide with the end of COF and start of the next COF (attached).
        The line is permanent no matter what I've tried. I've tried pressure testing the panel (top to bottom) and all over, I didn't notice any difference with the line, either temporary or semi-permanent.
        Also tried unplugging all flex cables, cleaned with isopropyl then re-inserting to no avail - line remains.
        Hoping to fix...
        05-05-2023, 04:28 PM
      • kalilinux25
        LENOVO Shorted +5VALW AND +3VALW LINE ACLU9/ACLU0 NM-A311
        by kalilinux25
        Hi good day to all hope someone can give me some advice whats happening to this board.
        Ive check the output voltage line of +5valw and +3valw all shorted I thought I was having a SIO shorted to.
        I try to remove the SIO chip But still shorted I tried to check all CAPS of the pu401 and PU402 all ok
        SHORTED TO GROUND
        PL402 AND PL401 , i tried also to remove the 2 coils and test the PJ402 and PJ406 im having short at those sections,
        I hope someone can guide me if anyone, Thank You in advance...
        01-20-2021, 11:56 PM
      • FALKLAN
        Running Line Voltage and Integrating LED Pods - Automotive
        by FALKLAN
        Howdy everyone! I hope all is well where ever you are!
        I'm attempting to integrate a couple of LED pods into an automotive reverse lamp circuit. The problem being, while the vehicle is running there is a 8.5v current present on the reverse lamp power wire. Needless to say is that all LED pods and lights dimly illuminate while the 8.5v is present, so the LEDs are always powered on while the vehicle is running. When the vehicle is shifted into reverse, the voltage changes to 12 volts.
        I am uncertain how to convert this line into a switched 12v output line for the LED pods....
        02-05-2025, 12:30 AM
