A2442 MacBook Pro 14" 5V restart
  • Stephen
    Meow Meow MEOW!
    • Apr 2020
    • 674
    Got a 14" MBP constantly restarting at 5V .04 Amps. Meter turns on, then off and repeats. I am very familiar with this issue in A1990, A1707 or A2141 etc boards however the power sequence for this board is different and I am trying to figure out if we have a Power Sequence Diagram for these boards yet? Also if you have came across this issue and fixed it please point me to the right direction. Also the board is new, no water damage nothing no drop damage and in perfect condition, no visible blown caps and is in PERFECT condition from what we see, it has never been worked on either and looks to me it has an issue somewhere.
    sigpic
    MEOWING IN THE IMPOSSIBLE UNIVERSE!
  • Stephen
    Meow Meow MEOW!
    • Apr 2020
    • 674
    Re: A2442 MacBook Pro 14" 5V restart
    Also from my experience usually this would be a case of a bad USB C Chip on the board. There are 4 on this board and I do not see any pin holes in them, I could be wrong though for sure.
    sigpic
    • mon2
      • Dec 2019
      • 14518
      Remove all power. Meter in resistance mode.
      Measure the resistance to ground of PPBUS_AON.
      Post the reading.
      • Stephen
        Meow Meow MEOW!
        • Apr 2020
        • 674
        When measuring I’m getting 10 M Ohms and dropping.
        sigpic
        • Stephen
          Meow Meow MEOW!
          • Apr 2020
          • 674
          Now it’s down to 4 M OHms
          sigpic
          • Stephen
            Meow Meow MEOW!
            • Apr 2020
            • 674
            Mesuared again it rose to 15 M Ohms and dropping.
            sigpic
            • mon2
              • Dec 2019
              • 14518
              So it is definitely NOT shorted.
              When you power up, what is the voltage to ground of this rail?
              Remove all power. Measure the resistance to ground of each inductor on the board. Someone is shorted on the logic board and that is why you are power cycling.
              It could be one of the ACE controllers (CD321x) - as per @Piernov's articles, each and every controller must be functional for the 20V power delivery contract to be selected.
              Do you have a thermal cam? If yes, apply the power adapter and check the thermal view of which component is throbbing with the hot / cold cycling.
              The inductor resistance check is a good start.
              On the ACE controllers - each LDO power rail on the IC must be checked.
              • Stephen
                Meow Meow MEOW!
                • Apr 2020
                • 674
                VOltage to ground 12Volts then drops to 3 when it restarts.
                sigpic
                • Stephen
                  Meow Meow MEOW!
                  • Apr 2020
                  • 674
                  As suspected it could be a faulty CD321... I don't see any visible issues but that was my assumption ill check further. Crazy how this is a brand new board and its dead lol
                  sigpic
                  • mon2
                    • Dec 2019
                    • 14518
                    USB Type C power delivery is crapware. We started some designs with PD 1.0 spec - I almost burnt my hands in testing out with some rather expensive tools - PD bus analyzer + cables from Taiwan (an approved supplier of the spec and was recommended) + Cypress development tools. We tested to sink the current they advertised.
                    It was like I was touching a working heater element. Dropped the cable and the design like a hot potato.
                    Reported the mishap to VIA Semiconductor in Taiwan and they claimed they knew the fault and would correct it. Apparently it has been corrected now.
                    The fault is often due to the cross shorting of the delicate USB C pads inside the connector shell while removing the adapter is 'hot' enabled with 20V delivery. The high voltage gets injected onto the lower voltage connector pins and kills the ACE controller(s).
                    TI has a whole article on this but do not believe this protection is onboard the devices, yet.
                    This short video is a must watch:
                    https://www.ti.com/video/60052597440...RT%20TO%20VBUS
                    Oh the irony - TI builds an external device to protect against such damage yet these TI ACE controllers get killed by the same event.
                    To locate the offending / damaged CD321x controller, remove all power.
                    Meter in DIODE mode.
                    Check the diode mode reading of each USB C connector pin - start with the CC1 / CC2 pins and compare the readings to the other ports onboard.
                    Red meter probe to ground (yes RED). Black meter probe to the contact to test.
                    • Stephen
                      Meow Meow MEOW!
                      • Apr 2020
                      • 674
                      Will report my findings Monday. Went a bought a glorified heat camera. Been meaning to do it so decided to pull the trigger.
                      sigpic
                      • mon2
                        • Dec 2019
                        • 14518
                        Seek Thermal recently announced a low cost thermal module for which they offer a development kit. We are reviewing a low cost solution. The resolution is lower than others but it should work fine for board repairs.
                        FYI:
                        https://shop.thermal.com/S104SP
                        • Stephen
                          Meow Meow MEOW!
                          • Apr 2020
                          • 674
                          HAHAH the USB C shorts happening at an angle is so true. That 20V being inputted into the wrong line....BYE BYE USB C CHIP haha. God that video proves what I always thought what a normal user would do when removing the cable, an angle is common and will result in blown chip.
                          sigpic
                          • Stephen
                            Meow Meow MEOW!
                            • Apr 2020
                            • 674
                            Replaced all 4 USB C chips nothing. Still turning off and off like the same result. Put a thermal gun to it, no heating spikes. Any suggestions?
                            sigpic
                            • mon2
                              • Dec 2019
                              • 14518
                              What is the current draw of the Type C port? Still as per post #1 ?
                              Check the voltage to ground of each power rail, on each CD3217.
                              • Stephen
                                Meow Meow MEOW!
                                • Apr 2020
                                • 674
                                Will post my findings tomorrow thanks mon2
                                sigpic
                                • Stephen
                                  Meow Meow MEOW!
                                  • Apr 2020
                                  • 674
                                  Ok back on this topic. Couldnt seem to find the issue for some reason and did the unthinkable, i said fuck it. Removed all 4 USB C chips. Tested the board to make sure it is not turning off and on again. Viola it stopped. So one of the chips or a few were bad. Ordering 4 new USB C CD3217 B12 chips hopefully we are good. I am kind of exhausted and do not feel like reballing these chips with our stencil so just going to feel better with new chips. Wish me luck.
                                  sigpic
                                  • Stephen
                                    Meow Meow MEOW!
                                    • Apr 2020
                                    • 674
                                    Sad news nothing lol
                                    sigpic
                                    • mon2
                                      • Dec 2019
                                      • 14518
                                      What is the current draw of the logic board?
                                      Apply the power adapter and check the power rails for each ACE controller against the schematic.
                                      Also consider to remove all power -> meter in diode mode -> check the diode reading of each USB Type C connector pin (red probe to ground; black probe to pin to test) -> compare the measurements against the other type C connector(s)).
                                      • obelix24
                                        MacBook Pro a2442 - 20v restart every second
                                        by obelix24
                                        I just got one MacBook Pro a2442 (M1 Pro) there was small liquid damage.
                                        Board starts normally at 5V and then jumps to 20V but after few seconds USB-C meter restarts (on every port) - sometime 1 or 2 times it's start and doesn't restart.
                                        There was hotspot on U5200 (but it looks like on PIN1 (CHGR_GATE_Q4) but I've check in diode mode and it was ok reading (but I've replaced it anyway but still the same ...
                                        There was corrosion around UR660, UR630, UR600 but I've checked all CAPS and it looks ok ...
                                        When I connect USB-C meter and check with...
                                        11-07-2024, 11:34 AM
                                      • dbuergi
                                        Macbook A2442 no display board 820-02098
                                        by dbuergi
                                        i got a Macbook A2442 which statrts normal but is not showing any picture. Using an external monitor works fine. After opening the Macbook i found a dried up line of liquid damage around CN979, RD503, and UP730. I cleaned up everything and also unsoldered the chips to clean the pads. There were no shorts before but i still don't have any picture. Sometimes you can see a glimpse of light in the middle of the display.
                                        So before i change the whole display i want to make sure that it's not any issue with the logicboard. So any ideas what i can check next?...
                                        05-25-2025, 10:58 AM
                                      • TechSplendid
                                        MacBook A2442 not powering on – suspecting CD3217, but replacement didn’t help
                                        by TechSplendid
                                        Hi All,
                                        I'm working on a MacBook Pro A2442 (14", 2021) that's not powering on. On two out of three USB-C ports, I get 5V and the current briefly ramps up to around 0.210A before dropping to 0.036A. On the third port (JF600), I only get 0.0045A and it stays there.
                                        Initially, I suspected a faulty CD3217 on that port, especially since I noticed signs of previous liquid damage near the JF600 USB connector. I replaced the CD3217 with an UF400 (from an A2442 donor board from the same location). According to the supplier, this should be a compatible version, but the behavior...
                                        04-09-2025, 02:13 AM
                                      • Constantinos
                                        Macbook Pro A2442 820-02098 No image but has backlight
                                        by Constantinos
                                        Hi all
                                        I have a Macbook Pro A2442 with the 820-02098 from a friend which has no picture on the display, however, the backlight works.
                                        He was streaming a football match on a questionable site, then the site crashed, and the problem emerged.
                                        Initially, he sent it to apple, who quoted him £1323.95 to replace the display, lid angle sensor and top case.
                                        Obviously, he decided against this and gave it to me so that I could have a crack at it.
                                        From initial diagnostics, I connected to an external monitor, I first tried with a HP 22W monitor, and I booted into the boot menu...
                                        08-24-2024, 09:48 AM
                                      • Enzo150i
                                        MacBook A2442 exclamation mark after oxydation
                                        by Enzo150i
                                        I have a MacBook Pro A2442 with board 820-02098-A very highly oxydated (water) by an accident.
                                        The customer just need to recover the data (no backups, heh), so we cleaned fully to make it power on.
                                        Fortunately the Mac is still alive but it shows an exclamation mark in a circle (!) (Apple T2 fw issue?) with the text "support.apple.com/mac/restore" and doesn't go further.
                                        We tried to interface with another Mac, but can't get in DFU. Very likely the keyboard is gone too because the water, so we're planning to buy a cheap compatible one just to....
                                        06-29-2025, 01:26 PM
