Hi everone
I have this craptop. AMD CPU. Motherboard model: DG425/DG525/DG725 NM-B321.
After battery replace (it has wear level 96.5% - no charging at all) and screen replace it seems that this laptop is working, charging. OS installed, driver, bios updated, etc...
But it does not work on battery, it turns on, ON button led and Num Lock led are on, fan spinning after while, but not screen. It's frozen. But if I connect charger then, it starts normally after short while.
I noticed, that replace battery (it is not new, but used, wear level 45%, charging normally) is not same type and capacity as old battery was, but same shape and same connector. Can be this source of problem or it is on motherboard, some power good signal ?
On photo is new battery, later I attach old battery.
Schematics here https://www.badcaps.net/forum/showthread.php?t=116545
