Lenovo S340 wont run off battery after RAM upgrade
  • AJ847.63e
    • Aug 2020
    • 171
    • Africa
    Hi All,
    Bit of a strange one. I upgraded the RAM in my laptop yesterday. Removed the battery before removing/installing the new RAM. Reinstalled the battery booted the machine up on battery only and ran a few tests everything seemed fine. All the new installed ram was detected and available to Windows. Windows said it was on 64% battery so I left it for a few minutes on idle to see how quick the battery would drain. Roughly 4 minutes into that the machine shut off and now it refuses to turn on unless I have the charger connected. With the charger the battery is recognized and is now charged to 100% but as soon as you disconnect the battery it shuts off.
    Apart from a bad battery, which seems a bit too coincidental because it's been fine up until now, what else could be causing this? I've had a look through the schematic on this forum and haven't been able to see any battery fuse or something that could of been blown while reconnecting the battery. Not to mention that seems implausible since it was working first time boot after installing the new RAM. I haven't been able to find the board view for it so finding where the battery connects and tracing it back to the charge circuit hasn't been possible.
    Thanks for your assistance!
  • mon2
    • Dec 2019
    • 14205
    Re: Lenovo S340 wont run off battery after RAM upgrade
    Is this the board view for your board?
    https://www.badcaps.net/forum/showth...light=LA-H131P
    Near your battery connector should be the battery mosfet. This mosfet enables to power the logic board if the external power adapter is absent.
    Locate the mosfet. Check the voltage to ground of each pin on the mosfet with the battery only connected.
    • AJ847.63e
      • Aug 2020
      • 171
      • Africa
      Thanks for that. That's the post where I got the schematic from there's only that in the zip folder no boardview, unless I'm missing something?
      Extremely weird. I closed up the chassis today to put it away while I wait for the new battery to arrive and now it's working fine. Charging fine. Disconnecting the charger it stays on, you reboot it without the charger its fine. You shut it down and turn it on without the charger everything seems fine. Very weird. Thanks for the help it's working now so I'm going to see how it goes, hopefully it was just some gremlins it had to get out...
        NVDC charger configuration...
        11-05-2024, 03:28 PM
        ISL6257HRZ ISL6257HRZ-T Laptop Battery Charger Datasheet
        Highly Integrated Narrow VDC Battery Charger for Notebook Computers
        The ISL6257HRZ ISL6257HRZ-T is a highly integrated battery charger controller
        for Li-Ion/Li-Ion polymer batteries. ISL6257 is designed for
        Narrow VDC applications where the system power source is
        either the battery pack or the regulated output of the charger.
        This makes the max voltage to the system equal to the max
        battery voltage instead of the max adapter voltage. Operating
        at lower system voltage can improve...
        11-05-2024, 04:43 PM
      • ferah831208
        Strange battery present behaviour in Lenovo Legion 5-15ARH05 mb model nm-d041
        by ferah831208
        Hello guys, i need help with this problem, I have a NM-D041 mobo, it came with low impedance in 3v linear regulator rail, the cause was a damaged EC controller ITE8227e-192. I ordered a new one and replaced it. This laptop have a different chip for keyboard management and it8227e pins for programming ITE chips are not accesible through keyboard interface, I flashed it using i2c interface pins with vertyanov programmer because laptop was dead and SPI flash didn't have power (only 3v EC) so it couldn't access firmware stored in SPI memory. I read SPI and extracted it8227 firmware from original BIOS...
        03-18-2025, 01:18 AM
      • Bowline
        by Bowline
        06-11-2025, 10:13 AM
        Bauer tool battery pack charging with a HERCULES charger modification
        by sam_sam_sam
        The Bauer power tool battery charger just has to many issues with the charger over heating because I several HERCULES Hercules battery chargers that are 3 amp charge and because they have gone on quite a few times over the years before they came out with the fan cooling battery charger I going to modify one so I can charge Bauer battery packs faster than the crape battery charger that they have
        Here is how this modification is going to be done I taking a 1.5 amp hour battery enclosure and gutting it removing the battery cells and replacing some Ryobi 1.5 amp hour battery pack that...
        05-06-2023, 12:17 PM
