Lenovo S340 wont run off battery after RAM upgrade
  • AJ847.63e
    • Aug 2020
    • 171
    • Africa
    Hi All,
    Bit of a strange one. I upgraded the RAM in my laptop yesterday. Removed the battery before removing/installing the new RAM. Reinstalled the battery booted the machine up on battery only and ran a few tests everything seemed fine. All the new installed ram was detected and available to Windows. Windows said it was on 64% battery so I left it for a few minutes on idle to see how quick the battery would drain. Roughly 4 minutes into that the machine shut off and now it refuses to turn on unless I have the charger connected. With the charger the battery is recognized and is now charged to 100% but as soon as you disconnect the battery it shuts off.
    Apart from a bad battery, which seems a bit too coincidental because it's been fine up until now, what else could be causing this? I've had a look through the schematic on this forum and haven't been able to see any battery fuse or something that could of been blown while reconnecting the battery. Not to mention that seems implausible since it was working first time boot after installing the new RAM. I haven't been able to find the board view for it so finding where the battery connects and tracing it back to the charge circuit hasn't been possible.
    Thanks for your assistance!
  • mon2
    • 14659
    Re: Lenovo S340 wont run off battery after RAM upgrade
    Is this the board view for your board?
    https://www.badcaps.net/forum/showth...light=LA-H131P
    Near your battery connector should be the battery mosfet. This mosfet enables to power the logic board if the external power adapter is absent.
    Locate the mosfet. Check the voltage to ground of each pin on the mosfet with the battery only connected.
    • AJ847.63e
      • Aug 2020
      • 171
      • Africa
      Thanks for that. That's the post where I got the schematic from there's only that in the zip folder no boardview, unless I'm missing something?
      Extremely weird. I closed up the chassis today to put it away while I wait for the new battery to arrive and now it's working fine. Charging fine. Disconnecting the charger it stays on, you reboot it without the charger its fine. You shut it down and turn it on without the charger everything seems fine. Very weird. Thanks for the help it's working now so I'm going to see how it goes, hopefully it was just some gremlins it had to get out...
        NVDC charger configuration...
        11-05-2024, 03:28 PM
        ISL6257HRZ ISL6257HRZ-T Laptop Battery Charger Datasheet
        Highly Integrated Narrow VDC Battery Charger for Notebook Computers
        The ISL6257HRZ ISL6257HRZ-T is a highly integrated battery charger controller
        for Li-Ion/Li-Ion polymer batteries. ISL6257 is designed for
        Narrow VDC applications where the system power source is
        either the battery pack or the regulated output of the charger.
        This makes the max voltage to the system equal to the max
        battery voltage instead of the max adapter voltage. Operating
        at lower system voltage can improve...
        11-05-2024, 04:43 PM
      • coasterghost
        Lenovo T14 Gen 2 Type 20XK Model 20XK0069US Odd Charging Issues
        by coasterghost
        For Badcaps Readers, Please note that I am hopefully going to present this same message to Lenovo to see if they have any insight to the matter as well and figured to share the entirety here for clarification. The System is out of warranty as it is but does have the option to have it extended.
        Model Information: T14 Gen 2 (Type 20XK, 20XL) Laptop (ThinkPad) - Type 20XK - Model 20XK0069US
        Board: T14 Gen 2 (Type 20XK, 20XL) - Type 20XK.
        System Hardware:
        Processor: AMD Ryzen 7 PRO 5850U
        Memory: 1x 16GB DDR4 3200 (Soldered on Board); 1x Crucial 32GB DDR4...
        09-08-2025, 10:46 PM
      • ferah831208
        by ferah831208
        03-18-2025, 01:18 AM
      • flat-earther
        how to prevent a connected charger from draining battery when not charging?
        by flat-earther
        I have an RC radio handset(Taranis QX7) which doesn't have internal battery charger which means I had to remove the battery every time I needed to charge it.
        So to improve it, I added a 15W USB-C charger board(link) inside and soldered it to the same connector on the PCB where the battery plugs into, great, now I can simply charge it with a USB-C cable.
        but the problem I found is that after the radio sat for two weeks without being used the 2S 18650 battery that I'm using was at 4.2V!
        So the battery is backfeeding the charger and being drained.
        How can I prevent...
        08-07-2025, 01:04 PM
