Macbook Pro 13'' 2017 A1708 Won't power on with battery connected.
Macbook Pro 15" 2018(820-01041-A) Freezing, Rebooting, Kernel Panics but only with connected Batteryby CornholioGSMHello,
I have here one interesting problem.
Laptop comes to me with freezing and rebooting problem. All inside was relatively clean and no water damage. Only visible problem was one swolled cell on battery...all was looking like batt problem.
I have put inside new - not original batt, but problem with freezing still. I am able to boot into os, then pc can run few seconds, then freezes and reboot and reboot until force power off.
Quickly i am able to see battery information...batt is detected normally in os with power cycles hours... -
by mavaroHi, I have a problem with MACBOOK A1990 - The laptop starts with no image when the battery is connected, but without the battery it starts with an image - however, when using only the power supply, when logging into the system it turns off and resets again.
Battery replaced with another unit → same problem.
ISL9239 replaced → no change.
SMBUS_BATT_SCL / SDA measure ~20-50kΩ to GND with battery disconnected (normal).
Any ideas or advice would be a huge help!
Thanks in advance for your time. -
by BowlineMy question pertains to understanding the control circuity inside a Dell PT434 type battery used in Dell E6400, E6410 and other Dell notebooks?
I have tried multiple different Dell power adapters. My Dell... -
by code shareHi everyone,
I'm having an issue with my Lenovo ThinkPad P43s. The laptop does not power on when the internal battery is connected, but it works fine on AC power alone (battery disconnected). Once the battery is reconnected, the system becomes completely unresponsive — no lights, no fan spin, nothing.
Here's what I've tried so far:- Power/EC reset (held power button for 60 seconds with battery and AC disconnected)
- Booted successfully on AC power only with the battery disconnected
- Visual inspection of the battery — no swelling, burn marks, or connector damage
- Battery
This was a no power initially. Thanks to your help, I discovered it was the first mosfet, so I replaced. Now, the device will power up only if the battery is NOT connected. As soon as I connect the battery, it shuts off. If I connected the battery while the device is off, it simply will not respond to the power button. I replaced the battery, and while I suppose the new battery could be faulty, I'm assuming it is not. I'm having the same behavior with the new battery. I measure .2v at the charging coil. Manually applying power to the + and - at the battery header, there is no charging happening....
- Loading...
