Try our new boardview, bios, & schematic search. Over 1.3 million files for download!
Macbook Pro 13'' 2017 A1708 Won't power on with battery connected.
  • arevut
    replied
    Originally posted by mon2
    For a good mosfet, these are low resistance measurements. Carefully, flux and remove this mosfet off the board and test using the same method after the mosfet has cooled down and on your work bench. Confirm if the measurements remain this low or not.
    source (1-2-3) & drain (5-6-7-8) = 8K vs OL
  • arevut
    replied
    Hi. I ordered new mosfets and today I replaced old with the new one. And... nothing changed. When I disconnect the battery the voltage in PPBUS_G3H is normalizing to 13V. When I connect the battery it decrease to 11V. Which guy will be the next? May be U7000 (ISL9239
  • mon2
    replied
    source (1-2-3) & drain (5-6-7-8) = 5.42K vs 157K
  • arevut
    replied
    What is the voltage to ground of the battery?
    PPVBAT_G3H_CONN = 10.5V
    Remove all power / no battery. Meter in resistance mode.
    Measure the resistance of the battery mosfet @ Q7065.
    Measure as follows:
    source (1-2-3) & gate (4)
    gate (4) & drain (5-6-7-8)
    Post each measurement. We are checking if there is a leaky mosfet here.
    Q7065 is a P-channel mosfet so to enable this mosfet, the gate voltage is required to be lower than the voltage being passed between source / drain pins.
    source (1-2-3) & gate (4) = 0.54M vs 7.8M
    gate (4) & drain (5-6-7-8) = 7.3M vs 11M
    *vs depending on the polarity of the probes
  • mon2
    replied
    Measure as follows:
  • arevut
    replied
    Flux and carefully remove the fuse(S) on the ppbus_g3h rail to isolate the producer and consumer sides of this rail. Then power up again. Is the ppbus_g3h higher and stable? The smbus rail is not shorted which is good but ppbus_g3h is the wrong voltage. The isl chip may be defective or the current sense resistance is of the wrong values. Leave the fuses off til the ppbus_g3h is stable.
    So I got 13V on ppbus_g3h when I just simply disconnect the battery to remove the fuses.
  • arevut
    replied
    What is the usb type C adapter voltage? Is it 20v?
    Yes, 20V present
    Using a suitable power adapter to power this unit? Suggest 100W with certified 100W cable.
    Yes, I use certified 100W cable and 100W power adapter.
    Is the 1.7A current consumption immediate or climbs to this value? If immediate then there is likely a shorted part onboard (capacitor?).
    Now consumption is 1.4 I think due to the battery charging. The consumption climbes to it values.
    ​Flux and carefully remove the fuse(S) on the ppbus_g3h rail to isolate the producer and consumer sides of this rail. Then power up again. Is the ppbus_g3h higher and stable? The smbus rail is not shorted which is good but ppbus_g3h is the wrong voltage. The isl chip may be defective or the current sense resistance is of the wrong values. Leave the fuses off til the ppbus_g3h is stable.
    Ok. I will try.
  • mon2
    replied
  • arevut
    replied
    Measure the voltage to ground of each pin on the battery connector with both, the battery and power adapter attached. Post each measurement.
    J6951 connector with both battery and power adapter attached:
    pin 2: SMBUS_SMC_5_G3H_SCL = 3.408V
    pin 3: SMBUS_SMC_5_G3H_SDA = 3.408V
    pin 7: SYS_DETECT_L = 0.016V
    Now the motherboard does not start
    Current consumption of the board with all parts attached is 1.707A.
    PPBUS_G3H = 11.25V with attached power adapter
    PPBUS_G3H = 10.52 without power adapter (only battery attached)
  • arevut
    replied
    Now it is still in the working mode. It boots without any problem. Measurements will probably need to be taken, when it switches to the mode from which it no longer starts without the battery disconnected?
  • mon2
    replied
  • arevut
    replied
    Re: Macbook Pro 13'' 2017 A1708 Won't power on with battery connected.
    Well done. Thanks for your update.
    Hi, I have the close problem. Motherboard do not want to start with the battery connected if I keep the laptop closed and disconnected from external power for a day or so. After reconnecting the battery, it can to start some amount of time. I tried to disconnect keyboard, trackpad, reset SMC, replaced the battery to the brand new one - gave no result. Motherbord lookes great like just from factory. No any tracks of liquid damage, all is clean. But there is some strange thing. The PPBUS_G3H is only 10,68V. On the gate of Q7065 is 2,46V. What to do next? Which direction to move in?
  • arevut
    replied
    Okay so am reporting back on the success now of this board. Believe it or not it was a bad bios or Bad MeRegion. I downloaded a Clean ME Region from peste on this forum and slapped it in.And all problems disappeared. It's working fine now with everything connected.Was able to learn a good bit of things to check in this thread about the sda/scl lines very grateful for that.Thanks to everyone.
    Hi, Could you please provide a link to this forum thread?
  • mon2
    replied
  • platinumsteel
    replied
  • platinumsteel
    replied
    Yes if i remove the display cable i will boot normally. I'll have cpuvcore. And also I get external display.I have 3x screens.2 of them are for testing.2 of them Got a lot of scratches and dents. But they work fine.And the other one is a brand new screen I ordered which came about 2 weeks now.All screens do the same thing.
    Thanks a lot for the guess Stevedb.That is the only area i didn't check out.I just woke up and now about to check out this lidswitch thingy.
  • mon2
    replied
    This model and age is affected by the flex gate issue.
    Remove the display cables.
    Boot normally. Are you able to toggle the caps led on the keyboard after booting and waiting the time for the login screen?
  • Stevedb
    replied
    Hi maybe a gues but i would look into lidswitch area . I think something wrong there.
    Greetings
    Steve
  • platinumsteel
    replied
    Hi mon i spent days and nights troubleshooting all kind of different scenarios to figure out what the hell is going on with this board.As soon as it is about to show boot logo on screen it shuts down kinda like when u hold down the power button.I see a split second flash on screen.I tried everything in the book.And still no hope.I narrowed it down too this. Once the board is in a chasis it will not complete a boot with picture with screen and battery attached. if I take it out of the chasis and connect the screen and battery only it will complete the boot and give me picture.I ruled out everything else and i mean everything. I also tried to put some paper under the entire board but still no hope.I switched chasis nothing changed.I can't begin to state every component i changed prior.lol. I changed smc 3 times. the ISL. 4 main components of the backlight circuit. Backlight IC and Mosfets. I even changed the battery Mosfet.One thing tho if i remove the backlight fuse with screen connected it completes the boot cycle.So thought it was related to backlight which is why i changed all main components for the backlight circuit. I don't know what to try again. Anything you can point out to test or try ?
  • mon2
    replied
    These are good readings in diode mode.
    There are numerous I2C bus connections on the LCD display connector.
    With no power, meter in DIODE mode.
    Red probe to ground.
    Black probe on point to test -> continue to test each and every I2C line.
    See attached. If you have similar readings for each of these I2C lines, proceed to test the other pins on the LCD display connector WITH the display attached.
    Someone is tanking the logic board once the display is attached.
    Premium supporters get full download access and other benefits.
  • manymonsteras
    Macbook Pro - A2251 - No power when battery is connected
    by manymonsteras
    I am hoping to get some advice. I have a 2020 13" Macbook Pro - A2251 that wouldn't turn on. I have done lots of electronics repair in the past but never on Macbooks. I have had this laptop sitting around and I finally decided to take a look at it and see if I could spring some life into it.
    First, it wouldn't boot up at all. I did a DFU restore and managed to get it to power on. Did a full restore but the battery was dead and wouldn't charge. I put in a new battery in it but now it won't boot up when the new battery is connected. I ordered a second new battery just in case,...
    11-20-2025, 09:42 PM
  • CornholioGSM
    Macbook Pro 15" 2018(820-01041-A) Freezing, Rebooting, Kernel Panics but only with connected Battery
    by CornholioGSM
    I have here one interesting problem.
    Laptop comes to me with freezing and rebooting problem. All inside was relatively clean and no water damage. Only visible problem was one swolled cell on battery...all was looking like batt problem.
    I have put inside new - not original batt, but problem with freezing still. I am able to boot into os, then pc can run few seconds, then freezes and reboot and reboot until force power off.
    Quickly i am able to see battery information...batt is detected normally in os with power cycles hours...
    06-25-2024, 12:27 PM
  • mavaro
    MacBook A1990 — No Display With Battery Connected
    by mavaro
    Hi, I have a problem with MACBOOK A1990 - The laptop starts with no image when the battery is connected, but without the battery it starts with an image - however, when using only the power supply, when logging into the system it turns off and resets again.
    Battery replaced with another unit → same problem.
    ISL9239 replaced → no change.
    SMBUS_BATT_SCL / SDA measure ~20-50kΩ to GND with battery disconnected (normal).
    Any ideas or advice would be a huge help!
    Thanks in advance for your time.​
    04-18-2025, 08:07 AM
  • Bowline
    by Bowline
    06-11-2025, 10:13 AM
  • code share
    Lenovo P43s won't boot with internal battery connected – looking for help diagnosing battery issue
    by code share
    I'm having an issue with my Lenovo ThinkPad P43s. The laptop does not power on when the internal battery is connected, but it works fine on AC power alone (battery disconnected). Once the battery is reconnected, the system becomes completely unresponsive — no lights, no fan spin, nothing.
    Here's what I've tried so far:
    • Power/EC reset (held power button for 60 seconds with battery and AC disconnected)
    • Booted successfully on AC power only with the battery disconnected
    • Visual inspection of the battery — no swelling, burn marks, or connector damage
    • Battery
    04-21-2025, 12:50 PM
