macbook pro 17" 820-2914 - b
  • hazem3636
    • Jun 2022
    • 35
    • sa
    macbook "820-2914-b"
    hi there only green light on the magsafe without fan spin no boot
    with battery green light and change to red same no fan no boot
    voltage
    PPBUS_G3H: 12.62V
    PP3V42_G3H: 3.497
    PPVRTC_G3H: 3.337
    SMC_RESET_L : 3.2v
    PP5V_S5: 5.01V
    PP3V3_S5: 3.1V
    PP5V_S3: 5.1V
    PP3V3_S3: 3.2V
    pp5v_s0 : 0 V
    PP3V3_S3: 0 V
    PM_SLP_S4: 0V
    PM_SLP_S3: 0V
  • mon2
    • 14662
    Re: macbook pro 17" 820-2914 - b
    Remove all power. Meter in resistance mode.
    What is the resistance to ground of pp5v_s0 ? Also interested the resistance to ground of the other 0v rails in your list.
    Post the measurements.
    • hazem3636
      • Jun 2022
      • 35
      • sa
      thanks for support sir
      resistance mode :
      PP3V3_S5 : 395 ohm
      P3V3S0_SS : 80 Kohm
      PP3V3_S0 : 2.8 Kohm
      pp5v_s0 : 4.8Kohm
      PP5V_S0_ISNS_R : 4.8Kohm
      i did something , direct voltage 2 V only with small current on PP3V3_S0 i found the PCH take all current and getting hot .
      your opinion sir
      • envym
        by envym
        Hi everyone!
        06-27-2025, 08:54 AM
      • Flasman90
        Macbook Pro DFU Restore Issues
        by Flasman90
        I have a 2020 Macbook Pro A2289 and after many attempts managed to get it into DFU mode, using my older 2017 A1706 Macbook Pro (Running Ventura 13.7.8). However, when attempting 'Restore', it fails at step 4 of 4, showing the following error:
        - "The operation couldn’t be completed. (AMRestoreErrorDomain error -1 - Failed to handle message type StatusMsg (Generic error)) [AMRestoreErrorDomain – 0xA (10)]
        - "The system cannot be restored on this device. Failed to create new state machine for restore [com.apple.MobileDevice.MobileRestore - 0xFB1 (4017)]
        08-30-2025, 10:27 AM
      • tobeend
        Bypass mdm macbook m2 ventura
        by tobeend
        1. RESET MACOS WITH IPSW
        a. Power off MacBook, press and hold the power button to enter Recovery
        b. Open Disk Utility, remove Macintosh HD
        c. Reboot, connect to the network to Activate Mac.
        d. Plug the C cord in the first port of the MacBook into the other Mac, then power off the MacBook
        d. Hold down the Control (L) + Option (L) + Shift (R) + Power key combination for 10 seconds
        e. Release the other keys, but keep holding the Power key for another 10 seconds
        f. MacBook is returned to DFU, open Apple Configurator 2 on the other Mac, right-click...
        05-26-2023, 07:18 AM
      • SarcasticOP
        General question about MacBook power rails for repair.
        by SarcasticOP
        I am looking at an A2337 and found this for the order of power rails and what they do. Can this be confirmed before I dive into hunting down power rails that do not exist or are not neccisary?
        • PPBUS_G3H (12.6V-12.8V)
          • This is the main power rail that supplies power to the entire system. Check this rail first, as it must be present for other power rails to work.
        • PP3V42_G3H (3.42V)
          • This power rail is derived from PPBUS_G3H and is used to power the SMC (System Management Controller) and other essential circuits. It should be present if PPBUS_G3H is working correctly.
        • PPVRTC_G3H (3.3V)
          • This
        12-12-2024, 05:50 PM
      • obelix24
        A2941 Macbook air 15” - 5V 0a
        by obelix24
        I’m working on one macbook air 15” m2 that was water damaged.
        keyboard, lcd, microphone connectors were damaged so i’ve replaced all of them and without screen connected macbook worked fine. Keyboard &trackpad and also lid sensor was working fine.
        i’ve put macbook in shelf and order new screen so i can fully repair it.
        Now i got the screen and macbook stays at 5v 0a.
        i’ve tried if it’s not in DFU with another macbook but it’s not detected at all.
        i don’t have schematics so i don’t know where to start can someone help me?...
        03-27-2025, 01:19 PM
