ROG G512li No power
  • mon2
    • 14636
    Re: ROG G512li No power
    Thanks @reformatt - looks like that software has potential.
    • Zparts01
      • Nov 2021
      • 107
      So I was able to use AsProgramer, the latest version to set QE=1. It was actually not as difficult as I thought it would be using the information found @ https://forum.reveltronics.com/viewtopic.php?t=280 ... "To enable QE you need to set S9 to "1"
      So Status Register 2 (S15-S8) should has binary value 0000 0010, which is 0x02 in hex (you can use windows calculator for conversion between binary and hex if you not familiar with that)." ... That was easy in the new version of AsProgramer as under "Status Register#2" it now shows a checkbox for QE. Once I checked that box and clicked on the "write" button, then read the "SREG" it now shows register 2 (S15-S8) has binary value 0000 0010, indicating QE=1. ... I don't believe I missed anything, so if that's not the problem I'm still not sure what could be stoping this laptop from powering up.
        • 21692
        I think it still needs a hardware mod
        https://www.badcaps.net/forum/showpo...4&postcount=40
        http://apkservice.ru/articles/28-sof...na-ch341a.html
        • Zparts01
          • Nov 2021
          • 107
          Yikes! Thanks SMDFlea! ... I have read some of this now, but I will look at it carefully later today. Sounds like it is very bad news for my situation though
          • Zparts01
            • Nov 2021
            • 107
            I'm not so sure how to tell if I have been able to successfully get the chip into QE=1 ... Everything I read says is it shows register 2 (S15-S8) has binary value 0000 0010, then QE=1. The link posted may be true, but I think because this board may have been set up for QE=1, then maybe it would not apply. Would that be the case. As for power rails on the board, maybe I'm barking up the wrong tree in the first place. I do not show power at 3VA_DSW_PWRGD (although I'm not sure what need to be connected to the board to see power on this rail.)
            • mon2
              • 14636
              When you purchased this IC from the vendor - the part # defines that the factory (Winbond) pre-programs the QE bit to '1'.
              • Zparts01
                • Nov 2021
                • 107
                Ok, that would make sense to me, but when I checked register 2 (S15-S8) had binary value 0000 0000 before I changed it in AsProgramer. Another thing I did before that was unprotect the firmware on that chip. It warned me that it may not be reversible, but I still went ahead and did it. I do have a backup of the original chip, but if I were to restore it, would all of those settings be restored as well? Also, would there be a known good copy of the firmware for this chip that's setup for this exact model of laptop if I need to find a copy? ... I am full of questions, sorry, but all of this hep is certainly appreciated and I'm learning a bunch on the way through.
                • mon2
                  • 14636
                  Post the full topside markings of the chip you are programming. Then we can review the datasheet and confirm the register details.
                  From my past experience of such flash memory devices, the registers such as the QE bit settings are not saved in the read binary image. Only the contents of the flash are saved to a binary file.
                  Cannot comment on the bios image file but someone should have one available. This request must be made in the BIOS section of the forum.
                  It would not hurt to make this request so you can test it.
                  Also, if there is a local EC controller flash - often a lower density device - post the full topside markings of that part and also request a clean image of that firmware in the BIOS forum.
                  Armed with both, you can rule out bad images of the bios chips.
                  • Zparts01
                    • Nov 2021
                    • 107
                    Thanks for the info mon2! I will post the images of the chips soon!
                    • Zparts01
                      • Nov 2021
                      • 107
                      He is the photos of the chips. The Winbond is the lower density chip that I'm mostly been asking about here. The other is the higher density...
                      • Zparts01
                        • Nov 2021
                        • 107
                        I will also post in the BIOS forum once I hear from you on this! Thanks again!
                        • eukal
                          Panasonic toughbook cf-h2 Mk1 no power, 3.3v-5v present but no 3v on bios chip
                          by eukal
                          Hello, i have a Panasonic Toughbook Cf-H2 Mk1 that won't power on. The battery charge without problem but no response from the laptop when i press the power button.
                          I have disassemble and unpluged the cmos battery, same no power on on battery with and whitout the adapter, and only adapter
                          I have check the voltage i have the main power rail ( +-16v normal for toughbook it's not 19v). I have on the coil after power management chip 3.3v and 5v.
                          I have check the 3.3v on the power button ribbon cable attach to the motherboard and the voltage go to 0v when i press the button. So...
                          07-01-2023, 01:00 PM
                        • Tynan Dill
                          by Tynan Dill
                          Assuming...
                          11-22-2024, 01:46 PM
                        • iulik17d
                          Intel Arc A380 videocard power limit remove - BIOS needed
                          by iulik17d
                          Hello everyone!
                          The Asrock A380 low profile card (ID 8086 56A5 - 1849 6006) have an power limit of 45W. Intel removed the possibility to increase power using the software utility, anyway the card is in an proxmox machine that doesn't run windows.
                          The same hardware is in another form by the name Asrock A380 Challenger that have the same VRMs and the power limit is at 60W. I searched online and found on another website an .bin bios file from the Challenger variant, that I flashed using an CH341a. Flashng worked well, I put the card in PC and booted. GPUz shows that new device ID is 8086...
                          01-10-2025, 02:33 PM
                        • hotcrossedbuns999
                          M715q Desktop (ThinkCentre) - Type 10M3 - Request bios chip location and useable bios for use with CH341A Programmer.
                          by hotcrossedbuns999
                          My pc updated bios through Windows Update and I was greeted with BLACK SCREEN WITH CPU FAN MAX SPEED. I don't think there is even a screen signal, because it triggers my monitor for a couple seconds and then the monitor turns off. I tried the other outputs as well.
                          1. I tried clearing bios, resetting bios, removed the CMOS battery, removed m.2 ssd, wifi, and ram. Still black screen with CPU fan blasting.
                          2. I tried using the Lenovo BIOS CD and BIOS USB, but neither worked. At least I couldn't get anything to work.
                          3. I could only locate two chips that look like bios chips. Could someone verify this
                          01-03-2025, 12:32 PM
                        • Sparklingx
                          CH341 disconnects, test clamp not working, soldered bios chip but not erasing/writing how I fixed
                          by Sparklingx
                          So i've bough a ch341 programmer, and the chip was CH341B . the test clamp was not working( when connecting bios using test clamp, ch341 device was disconnecting) I tried soldering the bios on the provided board, soldering the bios I could read the chip but could not write or erase. ASprogrammer , neo, ch341a programmer... all programmer software was hanging and device was disconnecting after few second of erase/write operating.
                          So then I have soldered a capacitor(whatever I had..[10v ~470uf ] ) from VCC to GND on my provided pcb where you solder the bios
                          now all...
                          08-29-2024, 01:53 PM
