HP EliteBook 840 G5 charging issue
  • doc_aj30
    • May 2023
    • 14
    • canada
    Re: HP EliteBook 840 G5 charging issue
    Found cap short
    Replaced
    PVSYS now is 19.8V and previous problem components don’t overheat
    But as suspected there are more issues
    Charger in shows 19.8V and power led goes white
    Attempt to start gives constant flashing white CAPS LCK and NUM LCK
    Searching deeper into schematic
    • doc_aj30
      • May 2023
      • 14
      • canada
      To finalize
      Traced issue to smart charging/power/battery chip
      Rabbit hole is too deep
      Going to vendor
      • abrnb
        • Apr 2023
        • 6
        • India
        Hi All
        isl 9241h and isl 9538h are same
        • mon2
          • Dec 2019
          • 14659
          See the diagram in post #3 here:
          https://www.badcaps.net/forum/troubl...ing-components
          At the top left is a parts legend. Those parts are compatible if the suggested parts are changed during the pcb assembly.
          • abrnb
            • Apr 2023
            • 6
            • India
            ok brother Thanks!
            • Cuboy
              HP probook 4510s mosfet issue
              by Cuboy
              I am currently trying to help a ONG by volunteering to help repair laptops, it's something that i have been into since 2017, always watching videos, on discords, forums etc...
              I have an HP ProBook 4510s laptop that does not power on and has no indicator lights, which suggests an issue with the power supply or the motherboard.
              I started by verifying that there is voltage at the input of the motherboard, confirming that the power adapter is working correctly. However, when I checked the voltage at the output of the first MOSFET (Q1032), I found 19V at...
              03-16-2024, 10:29 AM
            • drlarsen
              MacBook Air M1 A2337 battery/charging issue
              by drlarsen
              Hello. Sorry for the long post, but I am trying to decide if this is a simple battery replacement, or potentially something more complicated.
              I bought an open box MacBook Air M1 2020 A2337. Seller claimed it was never used. Visually, it appears pristine.
              On arrival, the battery was completely flat. Computer powers up and boots fine. Battery status showing 1% and charging, 1 cycle. coconutBattery showing 0 mAh and ~6 watts.
              After some hours, the battery status did not improve. Restore via DFU did not help.
              I connected the power adapter to a Kill-a-Watt...
              07-17-2025, 02:35 PM
            • ahmarzo
              la-j081p charging issue
              by ahmarzo
              Have Dell la-j081p laptop with battery issue.
              First the laptop was not charging pqb25 was short after changing pqb25 and pqb26 the laptop starts charging and runs properly on charger but battery it shutdown after 10 seconds.
              And when powered on only on battery the laptop turns off after 8-10 second without giving display.have tried another battery on another working laptop and it's working fine
              I have changed charging ic and pqb25 ,pqb26 and pqb13.
              When adapter is disconnected the laptop stays on battery for 8-10 sec then abruptly shutdown everytime.
              This is the link...
              04-24-2025, 05:16 AM
            • DominikPechac
              MacBook Air A1466 820-00165 Charging Issue
              by DominikPechac
              I have a problem identifying a problem on this MacBook Air A1466 with board 820-00165.
              A customer came in with a problem, the laptop was not charging. Otherwise, it works fine - runs from a battery without an issue. The battery is original, the customer also provided his original charger.
              However, when I was diagnosing the issue, I turned the laptop off, checked the board, etc. When I put everything back together, the laptop was charging (I inserted the charger and then turned the laptop on). After unplugging the charger and plugging it back,...
              04-05-2024, 02:20 AM
            • ebyte64
              Lenovo IdeaPad 330 laptop mosfet issue
              by ebyte64
              Good day everyone.
              I have been scratching my head with a Lenovo laptop I got in today.
              The laptop had no power and taking no amps from the power supply. Checking voltage showed 20v only on one side of the first mosfet. Took it off and replaced it and then same story. Took off second mosfet and then the first mosfet had the right voltages as well as 25v on gate is it should. Replacing the second mosfet the problem started again.
              Even using a wire to bypass the second mosfet does the same interference with the first mosfet.
              Would anyone...
              06-27-2023, 10:19 AM
