Asus x553ma no power
  • ahmarzo
    • Mar 2015
    • 173
    • india
    Have asus x553ma motherboard in dead condition 19v rail is ok but 3v 5v and all voltages fluctuate on power switch 3v is stable. Help with diagnose this problem
  • mon2
    • Dec 2019
    • 14664
    Re: Asus x553ma no power
    Hi. Remove all power. Measure the resistance to ground of each inductor / coil on the logic board.
    If the voltage is fluctuating -> measure there resistance to ground to see if there is a short condition.
    Next, locate the power regulator for the rails that are bouncing. What is the regulator's topside markings ? Very likely the regulator will have an ENABLE pin.
    Power up and measure the voltage to ground of the ENABLE pin. Is the ENABLE pin also toggling ON/OFF ?
    Often, a current sense loop will force the regulator to shut off. The current draw is known in advance by the designers and if the current draw is exceeded, the regulator will be shut off.
    • GLISIT
      by GLISIT
      01-16-2025, 02:29 PM
    • PantherDave
      by PantherDave
      Hi all!
      I'm trying to troubleshoot a Microsoft Surface Pro (5th gen) model 1796 that won't power on. Motherboard model is M1007506-015. My priority is retrieving data, but the SSD is integrated so it looks like if I can't repair it it'll need to go to a data recovery company. I've done a little basic board repair before, but nothing this advanced until now. So please forgive my ignorance in advance. πŸ˜…
      05-29-2024, 02:01 PM
    • bajdik
      Intermittent Power Issue on Asus X553MA – CPU Voltage Drops ftom 0.89V to 0V
      by bajdik
      I have a problem with an Asus X553MA motherboard. Sometimes the system works fine, but other times the CPU voltage drops to 0V. In most cases, the laptop reboots after a few seconds due to the voltage drop.
      Occasionally, it shows the ASUS logo or boots into the BIOS. Sometimes it can stay in the BIOS for hours without issue.
      I checked the board with a thermal camera, but I couldn't find any overheating or leaking capacitors.
      Unfortunately, I don’t have access to the schematic.
      It seems to me that when I bend the board, something changes.
      Could this...
      08-13-2025, 07:26 AM
    • ShadowAi
      ASUS TUF X570-PLUS doesn't power on: no VRM_EN signal.
      by ShadowAi
      Hello, I have an issue with the motherboard. Specifically, it doesn't power on, more precisely, the POST initialization doesn't occur.
      Let me start from the beginning, the motherboard suddenly stopped working one day. There are no beep signals from the speaker, and the debug LEDs are not lighting up. After inspecting it under a microscope and using thermal imaging, I didn't find anything that could be damaged.
      After that, I began voltage measurements, in which I noticed the absence of VDDQ, VDDP, VTT, and VPP lines. Later, I checked if there is an EN state on these lines,...
      03-15-2024, 10:46 AM
