Asus x553ma no power
  • ahmarzo
    • Mar 2015
    • 168
    • india
    Have asus x553ma motherboard in dead condition 19v rail is ok but 3v 5v and all voltages fluctuate on power switch 3v is stable. Help with diagnose this problem
  • mon2
    • 13954
    Re: Asus x553ma no power
    Hi. Remove all power. Measure the resistance to ground of each inductor / coil on the logic board.
    If the voltage is fluctuating -> measure there resistance to ground to see if there is a short condition.
    Next, locate the power regulator for the rails that are bouncing. What is the regulator's topside markings ? Very likely the regulator will have an ENABLE pin.
    Power up and measure the voltage to ground of the ENABLE pin. Is the ENABLE pin also toggling ON/OFF ?
    Often, a current sense loop will force the regulator to shut off. The current draw is known in advance by the designers and if the current draw is exceeded, the regulator will be shut off.
    • GLISIT
      by GLISIT
      01-16-2025, 02:29 PM
    • Tynan Dill
      by Tynan Dill
      Assuming...
      11-22-2024, 01:46 PM
    • PantherDave
      by PantherDave
      Hi all!
      05-29-2024, 02:01 PM
    • ShadowAi
      ASUS TUF X570-PLUS doesn't power on: no VRM_EN signal.
      by ShadowAi
      Hello, I have an issue with the motherboard. Specifically, it doesn't power on, more precisely, the POST initialization doesn't occur.
      Let me start from the beginning, the motherboard suddenly stopped working one day. There are no beep signals from the speaker, and the debug LEDs are not lighting up. After inspecting it under a microscope and using thermal imaging, I didn't find anything that could be damaged.
      After that, I began voltage measurements, in which I noticed the absence of VDDQ, VDDP, VTT, and VPP lines. Later, I checked if there is an EN state on these lines,...
      03-15-2024, 10:46 AM
    • meraklinetx
      Asus Z97-a power cycle, no boot no cpu voltage
      by meraklinetx
      Hello, I have an asus Z97-A motherboard and it doesn't start which was working properly before, the problem isn't related by ram, ram slots or psu (I changed all and nothing work), the exact problem is when you switch it on , it starts and after 1 seconds (no boot or display picture) it's off and then on cycle continuously until you power it off from psu also it's responding to the power switch for turning it off if you keep pressing it 3 or 4 seconds (power button pin has 3.3v) , also when you start it with eatx 12v socket connected this is happening (power cycle also all voltages are resetting...
      05-10-2023, 06:08 AM
