Macbook air 820-00165-A fixing
  • bargo
    • Aug 2022
    • 46
    The good thing is that, now I know all the stuff are working, because they were successfully initialized by linux drivers, including wifi/bluetooth, keyboard USB. I just need to get the correct bios.
    Oh man, I have a chime now apparently this guy is good to go for a round of testing
    • bargo
      • Aug 2022
      • 46
      Right now I have this 820-00165-A and another brother 820-00165-A logic board both working on the same level.
      I have a problem with both logic boards that could be due to something I don't yet know. They pass all Apple diagnostic with ADP000 result which means no errors were found. When I boot into OSX on Big Sur or later Monetery, I get a very slow machine, the speed of the processor on both logic boards are constantly at 800Mhz according to the powermetrics.
      I then booted into Ubuntu for both logic boards the processor speeds were changing according to load just as normal so I can see 2500Mhz and 500Mjz
      my IMON circuitry seems to be fine except that OSX needs something special, while linux run the processor on its optimal speed as needed.
      • mon2
        • Dec 2019
        • 14660
        https://www.it-tech.com.au/how-to-re...way-issue/amp/
        • bargo
          • Aug 2022
          • 46
          The osx loads fine in my case, its not stuck, but its very slow clokcing at half default base clock of 1.6ghz so its clocking at 800mhz always
          I have identified one reason for the Performance throttling and it seems to be due to this thing "GPU LIMIT GTDRIVER" according to powermetrics
          Whats more interesting I could not find any search engine result with that matched string "GPU LIMIT GTDRIVER​"
          • mon2
            • Dec 2019
            • 14660
            Still review the shared link - from the landing page:
            This cross-checking confirms that the logic board is faulty, but not “stop” booting, just extremely slow.
            • bargo
              • Aug 2022
              • 46
              I will do so, seems to be relevant but both logic boards with the same issue, only on OSX
              • bargo
                • Aug 2022
                • 46
                Yes as I guessed its not actually logical, just go for another round of batteries and both logic boards are working again just in their full clocks as normal..
                • envym
                  MacBook Pro 2018 with Activation Lock
                  by envym
                  Hi everyone!
                  I have a 2018 MacBook Pro (with Sequoia OS) that I've been using for years with no problem. I recently received an M2 MacBook Pro so I'm mostly using it and not the 2018 one, but since a friend of mine needs a computer, I thought I could restore my 2018 and give it brand-new-like to my friend.
                  I tried using the built-in tool to restore the MacBook (Settings > General > Transfer or restore > Delete) but it got stuck when trying to remove the Find Device configuration (it asked me for the password for my old Apple ID -now I use the same account but...
                  06-27-2025, 08:54 AM
                • Jamey021
                  Yep...I broke it MOAR after fixing it. a2681 MacBook Air
                  by Jamey021
                  So, what are the odds I shorted the M2 CPU? I got in an a2681 MacBook Air. Liquid damage. Ordered from China and replaced a chip (APL109D 343S00555) cleaned corosion and ultrasonic..The whole 9 yards.
                  Last night I put it all together and it came on beautifully. 20V- Apple Logo. I celebrated and knocked the LCD connector loose right away while holding the laptop. Now, it wont boot and it cycles on the volt meter.
                  Cycle 20v - .02a then volt meter goes off, then it comes on and rinse and repeat. Classic sign of a MacBook short. I looked at the board with my thermal camera and I can...
                  01-22-2025, 05:22 AM
                • Flasman90
                  Macbook Pro DFU Restore Issues
                  by Flasman90
                  I have a 2020 Macbook Pro A2289 and after many attempts managed to get it into DFU mode, using my older 2017 A1706 Macbook Pro (Running Ventura 13.7.8). However, when attempting 'Restore', it fails at step 4 of 4, showing the following error:
                  - "The operation couldn’t be completed. (AMRestoreErrorDomain error -1 - Failed to handle message type StatusMsg (Generic error)) [AMRestoreErrorDomain – 0xA (10)]
                  - "The system cannot be restored on this device. Failed to create new state machine for restore [com.apple.MobileDevice.MobileRestore - 0xFB1 (4017)]
                  08-30-2025, 10:27 AM
                • tobeend
                  Bypass mdm macbook m2 ventura
                  by tobeend
                  1. RESET MACOS WITH IPSW
                  a. Power off MacBook, press and hold the power button to enter Recovery
                  b. Open Disk Utility, remove Macintosh HD
                  c. Reboot, connect to the network to Activate Mac.
                  d. Plug the C cord in the first port of the MacBook into the other Mac, then power off the MacBook
                  d. Hold down the Control (L) + Option (L) + Shift (R) + Power key combination for 10 seconds
                  e. Release the other keys, but keep holding the Power key for another 10 seconds
                  f. MacBook is returned to DFU, open Apple Configurator 2 on the other Mac, right-click...
                  05-26-2023, 07:18 AM
                • SarcasticOP
                  General question about MacBook power rails for repair.
                  by SarcasticOP
                  I am looking at an A2337 and found this for the order of power rails and what they do. Can this be confirmed before I dive into hunting down power rails that do not exist or are not neccisary?
                  • PPBUS_G3H (12.6V-12.8V)
                    • This is the main power rail that supplies power to the entire system. Check this rail first, as it must be present for other power rails to work.
                  • PP3V42_G3H (3.42V)
                    • This power rail is derived from PPBUS_G3H and is used to power the SMC (System Management Controller) and other essential circuits. It should be present if PPBUS_G3H is working correctly.
                  • PPVRTC_G3H (3.3V)
                    • This
                  12-12-2024, 05:50 PM
