Macbook air 820-00165-A fixing
  • bargo
    • Aug 2022
    • 46
    Ok back to this board now.
    The status now, we have all signals and voltage present except that, no chime, no display USB blinks when inserted caps lock does not light up, power button works fine.
    Charger starts with green then switches to orange with and without battery present. ppbus_g3h is at 8.1V does not change to 8.4V
    inspected all lines that could potentially lead to why there is no chime but could not find any, the SMC seems to be functioning correctly. i also dont have a TBT_A_HV_EN thus L3095 is not showing any voltage. I thought I have a problem with U2800 because its the one that sends that enable signal, but I also think it should not be the case I have no shorts around that circuit.
    The LPC_FRAME_L and LPC_FRAME_L_R are both present and I have activity on LPC_AD
    SPI also shows some activity after few ms of time.
    Any ideas to know what is wrong here?
    • bargo
      • Aug 2022
      • 46
      OK reballed another SMC from the same model, with the same exact results
      • bargo
        • Aug 2022
        • 46
        Now I will go to the UEFI cleaning part and see if that does anything.
        • mon2
          • Dec 2019
          • 14659
          Review the I2C / SMBUS lines. Someone may be tanking this interface and preventing the SMC from reaching the higher voltage.
          What are the voltages on:
          SMBUS_SMC_0_S0_SDA
          SMBUS_SMC_0_S0_SCL
          Disconnect the eDP panel and check again. If still low, needs to be reviewed.
          There are other SMBUS networks and each must be reviewed.
          • bargo
            • Aug 2022
            • 46
            Thanks for sharing mon2. I will check it out when the bios chip is back in place. currently diving into this cleaning ME stuff
            I checked the smbus_smc_5_g3_scl and sda and it was reading the battery information and stats correctly according to the oscilloscope.
            I have not checked that specific one, I will plug myself into the bus itself and probe the devices on the bus and see what devices are populated and which ones are not. Once I fail with the EFI reflashing with clean ME.
            All my best,
            • bargo
              • Aug 2022
              • 46
              the clean ME did not change the situation. I have a clean ROM but same results.
              The SMBUS_SMC_0_S0_SCL​ and SDA are still 0 voltage and thats due to the edp panel power not being raised on u8300. So surely it is low at this state, what would cause edp_panel_pwr to be low? as it comes directly from the processor.
              it reads 1.3v on diode mode so its connected to the processor
              • bargo
                • Aug 2022
                • 46
                One more thing, when I plug the charger while the battery is connected, the mainboard starts and fan start to ramp up. when all connections are connected and then plug in the charger it also starts but the fan PWM stays calm (managed apparently).
                One more interesting stuff. Now I can see edp_panel_pw at 3.3volts but this happens only in ONE scenario. If i turn on the machine while the battery is connected and charger is disconnected.
                I read 3.3volts as well on SCL and SDA of the screen. I see a very dark screen with no backlight even with a flash light on the screen i see it very black. also EDP_BKLT_EN stay at 0v
                very interesting, now at least i can see the edp_panel_pw
                • mon2
                  • Dec 2019
                  • 14659
                  Confirm the operation of the dual diode @ D7005. Remove all power -> meter in diode mode.
                  Red meter probe on anode (pin # 1); black to the common cathode (pin # 3) - should conduct. Reverse the leads and it should block.
                  Repeat with pin # 2 & # 3. Same results if all is well.
                  Do check on the voltage to ground @ pin # 3 with and without the adapter / battery. The higher voltage should pass through.
                  • bargo
                    • Aug 2022
                    • 46
                    Thanks mon2 man
                    It reads 0.249v on both 1 and 2 pins in diode mode.
                    with charger plugged i get 16v on pin 3 and 6.5v with a battery only.
                    • mon2
                      • Dec 2019
                      • 14659
                      Correct. An absent sensor means the logic board will assume there is trouble and kick on the fan into high speed. The trackpad is required to sense if the display lid assembly is open or closed. This signal will be used to enable / disable the LCD backlight.
                      • bargo
                        • Aug 2022
                        • 46
                        ok interesting stuff as usual mon2, the trackpad is actually not connected only the keyboard is connected i will add the trackpad, to the combo and see if that makes the lid to light (I think it should)
                        I still dont understand why when plugging the charger i dont get the edp_panel_pw signal I only get it in the scenario i described (only with battery power source it shows up)
                        as we reached a level that this edp_panel_pw comes after about 3-4 seconds after the pw button have been pressed. Would that mean that SMC firmware is ok (im still worried about this blackbox chip)
                        Much appreciated, this was a very good hint, mon2
                        • mon2
                          • Dec 2019
                          • 14659
                          What is the voltage to ground of PM_BATLOW_L ?
                          • bargo
                            • Aug 2022
                            • 46
                            it measures 3.3v to ground
                            i connected the trackpad lid lights did not come in, edp_pwr_en is still at 3.3v (it also comes up if i remove the flex cable and keep the charger connected now, if i connect the flex cable it does not come up)
                            • bargo
                              • Aug 2022
                              • 46
                              Also when the 3.3v is present on PP3V3_S0SW_LCD the DP_INT_HPD also gets a 2.7v it reads zero v when that rail is down. EDP_BKLT_EN is still 0v
                              And all of that happens when i start the mainboard with the battery power source.
                              • mon2
                                • Dec 2019
                                • 14659
                                Disconnect even the keyboard. Then test again. If required, you can use tweezers and short the power on/off pcb pads to mimic the power button. There will be a pair of such pads on each side of the logic board. In the schematics, search for SMC_ONOFF_L signal (R5115/16 pads).
                                • bargo
                                  • Aug 2022
                                  • 46
                                  Disconnect even the keyboard. Then test again. If required, you can use tweezers and short the power on/off pcb pads to mimic the power button. There will be a pair of such pads on each side of the logic board. In the schematics, search for smc on off (similar to this net name).
                                  Do you mean disconnect everything except the battery and display? also flex cable and charger port?
                                  or keep the extension connected?
                                  its an absent R5116 for this board to trigger on/off
                                  just tested it in both ways with and without the extension. Same results PP3V3_S0SW_LCD shows up after the first turn on and turn off then turn on cycle
                                  the EDP_BKLT_EN does not come up.
                                  Keyboard disconnected/camera/speakers/WIFI/SSD
                                  question, this rail PP3V3_S0SW_LCD comes up because EDP_PWR_EN was triggered, does that mean we are post SMC firmware issues? or we may still have an SMC firmware issue. Or we are in a pre SMC firmware issue stage/state?
                                  • mon2
                                    • Dec 2019
                                    • 14659
                                    Disconnect even the battery. Also remove the bridge black flat cable that sits between the main board and the LIO board where you attach the MagSafe power adapter. Use your finger nails to gently lift the wider keyboard flat connector. Apply even lift pressure to lift the keyboard connector. Check YouTube videos if in doubt. Want the minimum hardware to test the board. Do you see the green power light on the MagSafe head? Clean the pogo pin power contacts with alcohol as they could have cat puke on them.
                                    yes, those are the pads but I think the logic board will power on without the need to short the pads.
                                    • mon2
                                      • Dec 2019
                                      • 14659
                                      The board is power cycling? Do check the spi flash rom for voltages. There may be a high current event stopping the boot. Be sure the adapter is the original.
                                      review this excellent website:
                                      https://www.it-tech.com.au/mac-q-a/m...sequences/amp/
                                      • bargo
                                        • Aug 2022
                                        • 46
                                        I dont like this tone my friend, I have no nails. Also I'm not very gentle, I like to break stuff.
                                        Also the flat/flex cable is needed for that green light to comes up, so I'm not sure if I follow any of your suggestions now..
                                        • mon2
                                          • Dec 2019
                                          • 14659
                                          Throwing the kitchen sink at this.
                                          with the lio cable connected, do you see the green led on for the MagSafe power head? Often the lio cable is defective between the 2 boards.
                                          https://boards.rossmanngroup.com/thr...n-light.63378/
                                          what is the voltage on SMC_RESET_L ?
                                          • envym
                                            MacBook Pro 2018 with Activation Lock
                                            by envym
                                            Hi everyone!
                                            I have a 2018 MacBook Pro (with Sequoia OS) that I've been using for years with no problem. I recently received an M2 MacBook Pro so I'm mostly using it and not the 2018 one, but since a friend of mine needs a computer, I thought I could restore my 2018 and give it brand-new-like to my friend.
                                            I tried using the built-in tool to restore the MacBook (Settings > General > Transfer or restore > Delete) but it got stuck when trying to remove the Find Device configuration (it asked me for the password for my old Apple ID -now I use the same account but...
                                            06-27-2025, 08:54 AM
                                          • Jamey021
                                            Yep...I broke it MOAR after fixing it. a2681 MacBook Air
                                            by Jamey021
                                            So, what are the odds I shorted the M2 CPU? I got in an a2681 MacBook Air. Liquid damage. Ordered from China and replaced a chip (APL109D 343S00555) cleaned corosion and ultrasonic..The whole 9 yards.
                                            Last night I put it all together and it came on beautifully. 20V- Apple Logo. I celebrated and knocked the LCD connector loose right away while holding the laptop. Now, it wont boot and it cycles on the volt meter.
                                            Cycle 20v - .02a then volt meter goes off, then it comes on and rinse and repeat. Classic sign of a MacBook short. I looked at the board with my thermal camera and I can...
                                            01-22-2025, 05:22 AM
                                          • Flasman90
                                            Macbook Pro DFU Restore Issues
                                            by Flasman90
                                            I have a 2020 Macbook Pro A2289 and after many attempts managed to get it into DFU mode, using my older 2017 A1706 Macbook Pro (Running Ventura 13.7.8). However, when attempting 'Restore', it fails at step 4 of 4, showing the following error:
                                            - "The operation couldn’t be completed. (AMRestoreErrorDomain error -1 - Failed to handle message type StatusMsg (Generic error)) [AMRestoreErrorDomain – 0xA (10)]
                                            - "The system cannot be restored on this device. Failed to create new state machine for restore [com.apple.MobileDevice.MobileRestore - 0xFB1 (4017)]
                                            08-30-2025, 10:27 AM
                                          • tobeend
                                            Bypass mdm macbook m2 ventura
                                            by tobeend
                                            1. RESET MACOS WITH IPSW
                                            a. Power off MacBook, press and hold the power button to enter Recovery
                                            b. Open Disk Utility, remove Macintosh HD
                                            c. Reboot, connect to the network to Activate Mac.
                                            d. Plug the C cord in the first port of the MacBook into the other Mac, then power off the MacBook
                                            d. Hold down the Control (L) + Option (L) + Shift (R) + Power key combination for 10 seconds
                                            e. Release the other keys, but keep holding the Power key for another 10 seconds
                                            f. MacBook is returned to DFU, open Apple Configurator 2 on the other Mac, right-click...
                                            05-26-2023, 07:18 AM
                                          • SarcasticOP
                                            General question about MacBook power rails for repair.
                                            by SarcasticOP
                                            I am looking at an A2337 and found this for the order of power rails and what they do. Can this be confirmed before I dive into hunting down power rails that do not exist or are not neccisary?
                                            • PPBUS_G3H (12.6V-12.8V)
                                              • This is the main power rail that supplies power to the entire system. Check this rail first, as it must be present for other power rails to work.
                                            • PP3V42_G3H (3.42V)
                                              • This power rail is derived from PPBUS_G3H and is used to power the SMC (System Management Controller) and other essential circuits. It should be present if PPBUS_G3H is working correctly.
                                            • PPVRTC_G3H (3.3V)
                                              • This
                                            12-12-2024, 05:50 PM
