Dead ASUS ROG G14 (GA401)
  • jacobtc
    • Apr 2016
    • 274
    • Denmark
    #41
    Re: Dead ASUS ROG G14 (GA401)
    Originally posted by mon2
    Sorry, I meant to measure the voltage to ground of each pin. Post the list again.
    Need to check if the charger IC has the conditions to spit out the boosted voltage on ACDRV. Be sure that the part is well fluxed and well heated to swim but settle down on the PCB pads, naturally. Low air pressure but enough heat to make it swim. Just in case there are any shorts, this process will correct the hidden shorts.
    Alright, I will remove and resolder the BQ IC and get new measurements tomorrow, it's bedtime for me
    Thank you for your support!
    EDIT: I also find it weird that the second mosfet did output 20V when I first replaced the BQ IC, but when I had it in the case, with display etc plugged in, nothing happened, and afterwards the mosfet measured 4V again.
    • mon2
      • 14577
      Perhaps some other component is causing the main power rail to tank.
      You can check the resistance to ground of the main power rail but without power of course.
      Check it without the display -> then with the display. If the current sense by the charger IC is that there is an excessive current draw, the DCin mosfets will be instructed to shut off.
      Do not connect the battery at this stage of testing - only the power adapter. Need to be sure that the video and normal boot cycle is working.
      • jacobtc
        • Apr 2016
        • 274
        • Denmark
        #43
        Sorry, actually the display was not connected. The laptop was purchased with a broken display as well, so I only connected the display cable to the motherboard, the other end was not connected to a display.
        • jacobtc
          • Apr 2016
          • 274
          • Denmark
          #44
          Got some voltages for ya'
          Wouldn't the voltage only tank if something was connected? I have everything disconnected when doing the measurements...
          • mon2
            • 14577
            Pin 10 voltage on the charger IC is of concern.
            See attached.
            Can you remove the 2nd DCin mosfet? Then measure the resistance of the removed part while it is on your work table.
            Intered in the resistance readings of the removed mosfet between:
            source (1-2-3) & drain (5-6-7-8)
            source (1-2-3) & gate (4)
            gate (4) & drain (5-6-7-8)
            • jacobtc
              • Apr 2016
              • 274
              • Denmark
              #46
              See attached.
              Just did S-D, and that measures a dead short... Jesus, these are hard to find. I did voltage injection, although only 1V1A, but still, that did not show up on the thermal image...
              • mon2
                • 14577
                What are the topside markings of this mosfet?
                Being n-channel, you can probably replace it with many others on donor boards, etc.
                First, need to be sure there is a physical match.
                2nd - the mosfet is N-channel.
                3rd - current / voltage support.
                If you have donor boards around - check if the charger IC is any of the BQ series. The BQ charger ICs use N-channel mosfets.
                • jacobtc
                  • Apr 2016
                  • 274
                  • Denmark
                  #48
                  It is a M3058M, I have a couple of those laying around as well
                  • mon2
                    • 14577
                    Before you proceed..check that there are no shorts on the source, gate or drain pins on the PCB pads.
                    • jacobtc
                      • Apr 2016
                      • 274
                      • Denmark
                      #50
                      No shorts on pads. Soldered new mosfet, no change. Still same 4V out, and 0V on Pin 10.
                      • mon2
                        • 14577
                        Measure the voltage to ground readings of the first mosfet.
                        Post each measurement.
                        • mon2
                          • 14577
                          I also missed the low voltage on pin # 3 (CMSRC). Mosfet # 1 is a suspect.
                          Attached is a typical hookup of this charger IC.
                          • jacobtc
                            • Apr 2016
                            • 274
                            • Denmark
                            #53
                            So with AC connected?
                            • mon2
                              • 14577
                              Yes, with the adapter connected.
                              After the voltage check, remove all power.
                              Measure the resistance of the same mosfet:
                              • jacobtc
                                • Apr 2016
                                • 274
                                • Denmark
                                #55
                                Here you go.
                                • mon2
                                  • 14577
                                  What is the gate voltage to ground on this mosfet with the adapter connected?
                                  • jacobtc
                                    • Apr 2016
                                    • 274
                                    • Denmark
                                    #57
                                    what is the gate voltage to ground on this mosfet with the adapter connected?
                                    0.58v
                                    • mon2
                                      • 14577
                                      What is the voltage to ground of +RTCBAT ?
                                      • Sephir0th
                                        • Oct 2020
                                        • 1283
                                        At the risk of being the bad guy again, I can not ignore how much effort people like mon2 and others already invested here.
                                        In the picture of Post #34, the Charging controller is in my opinion not aligned properly.
                                        Another example is the measurement at the low-side Mosfet for GPU_Core in Post #1 where a resistance of 200 Ohms between Source and Drain was shared although the Core resistance to GND was only 22 Ohms to GND. These values are mutually exclusive.
                                        Just a few examples if someone wonders why here is almost no progress at all.
                                        FairRepair on YouTube
                                        • jacobtc
                                          • Apr 2016
                                          • 274
                                          • Denmark
                                          #60
                                          I appreciate all the help I can get, I'm still very much a newbie and do this occasionally in my spare time.
                                          The charging IC has since been aligned properly, but rest assured, I did check all the pins for bridges and connection before posting any readings.
                                          In regards to the 200 Ohm mosfet, I did point it out to see if this could be a culprit, but honestly have no clue on how to troubleshoot it, other than thinking "This seems wrong" and posting it.
                                          • Mabot17
                                            ASUS gaming laptop GL704GV GPU DEAD SHORT
                                            by Mabot17
                                            Hello i need help to fix this laptop,at least a discrete to UMA conversion if it's possible.
                                            i took a photo of what i found,NVIDIA gpu side is 100% shorted as i desoldered power line coils and mosfet side is ok.
                                            Even without coils laptop still not power on.Main power rails,bios,1v,3,3v and 5v are present...
                                            05-10-2025, 11:04 AM
                                          • ktmmotocross
                                            Asus UX433FAC - batery dead after short on VIN rail
                                            by ktmmotocross
                                            Hello.
                                            Have this Asus UX433FAC that came with shorted mosfet on main power rail. After replace laptop works ok, but battery is dead. Laptop show charging but voltage on battery is 0.2V. when remove battery voltage on battery connector goes to 8.5V, but when connect battery again it goes down to 0.2V.
                                            can that short shorted battery? batmon show that battery is full at 80%
                                            12-29-2022, 12:06 PM
                                          • OOF DIO
                                            ASUS FX505DV no power shorted at PWM controller Pin 3 VREG3 TPS51225C, need pinpointing of the short.
                                            by OOF DIO
                                            (If anyone has a functional boardview file of FX505DV/DU that would be helpful)
                                            (Had 3 problems, now just 1)
                                            I have no experience or knowledge and usage of tools to repair devices besides the entire past 12-10 days of researching, watching YouTube repair videos and troubleshooting this laptop motherboard. ChatGPT was used as a guide to ask questions.
                                            I used boardviews of mostly FX505GD-M, and some FX505DU, FX505DD. Used schematics of FX505DU.
                                            I had originally intended to replace the BQ24780s first (due to previous battery removal while benchmarking) but I...
                                            04-19-2025, 05:03 PM
                                          • jkucukov
                                            Asus ZenBook 13 UX333F External Short - Fast Battery Drain - Need Help
                                            by jkucukov
                                            I'm trying to see if someone could help me with my Asus Zenbook 13 UX 333F with given symptoms that I've experience during a recent external short.
                                            During last laptop charge, as I was moving the DC power supply, I caused the two leads (+ -) to touch. After that event the laptop stopped charging and pulling amps form the power supply. The only way the laptop will come on is with the power supply connected and the battery having some charge to it, battery drains immediately after short operation (it gets to Windows log in screen before it shuts off). The laptop would power on, show...
                                            02-05-2025, 09:27 PM
                                          • Beton
                                            Finding a dead short component
                                            by Beton
                                            Hi guys!
                                            I searched for the term "dead short" in the forum but no specific thread came up however if I'm just blind and couldn't see the thread talking about this please forward me to that direction.
                                            So my problem is I don't know how to find the source of a dead shorted voltage rail. Dead short = ~0 ohm resistance.
                                            I have two VGAs (HD 4850 and HD 4870), both dead shorted to ground on the memory rail. I have the boardview file for the 4870 and the memory rail consists around ~7892346 capacitors...
                                            I have a bench PSU and if I try to inject voltage the voltage...
                                            12-10-2021, 01:05 PM
