G752vy and cmos battery
  • jasko_jacker
    • Oct 2014
    • 1140
    • italy
    I can't find the schematic or the boardview. This model even if it has a non-removable battery also has a 3v cr2032 battery. Randomly the bios gets corrupted and needs to be reprogrammed. I noticed that even if the cr2032 is ok it doesn't work, removing the main battery and inserting the power supply the board turns on even if the 3v battery is present. I could also take the cmos battery out but I think the problem is somewhere else.
  • jasko_jacker
    • Oct 2014
    • 1140
    • italy
    Re: G752vy and cmos battery
    Often to restart a motherboard we remove the ram (it is not always necessary) and remove the cmos battery, press the power button (to discharge any residual voltage) and reconnecting the power supply the system restarts. On some boards (asus) the system reboots twice and then loads the operating system. Has anyone studied the reason for this behavior and (in case the bios needs to be reprogrammed) analyzed how to identify the module responsible for the bios block (especially in uefi systems)?
    • questore
      XPS 13 9370 CMOS battery voltage always low
      by questore
      Hi Everyone,
      I have brought you a mistery item
      This laptop have come with some strange faults.
      1. CMOS battery was flat 0v
      Symptoms:
      - After using the laptop and shutting down and removing the AC adapter for at least 1 minute, the laptop never turned on until EC reset (either shorting RTC or removing battery and long pressing power button)
      Amp drawing was stuck at 0.005 milliamps.
      - Laptop cannot really be turned off because it autostarts about 5 sec-1 or 2 minute. (lid sw is not the problem)
      After inverstigation RTCD1 diode had a low value...
      09-30-2025, 05:47 AM
    • Bowline
      by Bowline
      06-11-2025, 10:13 AM
    • mkdj
      by mkdj
      Mark and model: ASUS X571
      Tests already made:
      - I have removed...
      07-14-2025, 09:16 AM
    • techfreak9356
      Vostro 3400 (LA-K033P) won't charge battery, everything else ok
      by techfreak9356
      09-14-2023, 11:10 PM
    • magistertc
      CMOS battery drains quickly
      by magistertc
      This problem is based on my experience with an ASUS Z390 Prime motherboard, but it appears to affect other motherboards
      as well Install a new CMOS battery, configure computer, turn off computer and disconnect from AC power or switch off SMPS.
      Return somewhat later and find that battery is drained, dead, or weak. Clock is wrong, other settings lost, etc.
      Examine the power 'sharing' circuit -- when the ATX 3V supply is on, the computer will function normally. The computer is also
      configured to support the RTC and some volatile RAM (when SMPS is on). What you may...
      07-06-2024, 09:55 AM
