A1990 MacBook Pro boot looping
  • Stephen
    Meow Meow MEOW!
    • Apr 2020
    • 674
    Did a T2 restore. Boot loops constantly then eventually loads the OS.
    Did a T2 Restore and revive and OS reinstall. Same issue. Downgraded OS as well nothing.
    No visible water damage seen. No burn chips and MacBook has never been worked on.
    Once the OS is fully loaded seems good. For a while.
    No kernel panic info shows up so definitely curious what’s going on.
    It does boot fully into safe mode without issue.
    sigpic
    MEOWING IN THE IMPOSSIBLE UNIVERSE!
  • mon2
    • 14671
    Re: A1990 MacBook Pro boot looping
    Check each and every SMBUS line.
    • smzlwan223
      • Mar 2022
      • 20
      • 中国
      205/2000
      Good News and bad news! This kind of problem in my past maintenance experience, encountered a lot of similar models of similar failures, are a problem, CPU bad, BAD CPU! BGA CPU replacement perfect solution! If the appearance of the test, no problem, other measurements, are redundant!
      • mon2
        • 14671
        Good to know. From where do you source a replacement CPU? Donor board or can you share the details of a good vendor with reballed CPUs?
        • smzlwan223
          • Mar 2022
          • 20
          • 中国
          We generally recycle chips from customers who scrap their motherboards, but we also get them from our peers. Buying them online requires a certain element of luck, which involves, sellers and buyers, IC dismantling, manual problems, and temperature control, if you don't handle it well, it will break!
          • Stephen
            Meow Meow MEOW!
            • Apr 2020
            • 674
            Sigh it’s a i9 32GB board. Sucks this is a bad CPU or GPU.
            sigpic
            • smzlwan223
              • Mar 2022
              • 20
              • 中国
              There is another solution to this problem, which is to modify the circuitry, to solve the reboot problem, but the researchers have not yet published this solution, and friends around me have learned that it is partially solved by modifying the temperature control, you can go into safe mode, view the system error log, find the corresponding point to modify the circuit! You can try... !
              • Flasman90
                Macbook Pro DFU Restore Issues
                by Flasman90
                I have a 2020 Macbook Pro A2289 and after many attempts managed to get it into DFU mode, using my older 2017 A1706 Macbook Pro (Running Ventura 13.7.8). However, when attempting 'Restore', it fails at step 4 of 4, showing the following error:
                - "The operation couldn’t be completed. (AMRestoreErrorDomain error -1 - Failed to handle message type StatusMsg (Generic error)) [AMRestoreErrorDomain – 0xA (10)]
                - "The system cannot be restored on this device. Failed to create new state machine for restore [com.apple.MobileDevice.MobileRestore - 0xFB1 (4017)]
                08-30-2025, 10:27 AM
              • netboy69
                Macbook Pro 15, A1990 2018, showing recovery not dfu, error 9 when restore, HELP
                by netboy69
                Hi to all i have a faulty a1990 from 2018, no liquid damage, died during update, now on configurator i see recovery not dfu, and i get error 9. caps around u7701 show short after removing u7701 and shorted caps still short. can any help....
                02-07-2024, 04:34 PM
              • alfredodinolfo
                MacBook Pro 2019 (A1990)
                by alfredodinolfo
                mb code:820-01827-A;
                sn:C02Z349ALVDR;
                i9 32GB Ram 1TB
                Hi, I found short on one of 6 black nand (total 1TB).
                i removed all 6 nand ( voltages all ok) and now i want to program with JC P15 but for A1990 2019 there is only 512GB configuration.
                I try A2141 1TB configurazion with TSB4228 but the position on pcb is different ( U9300 and U9400 is no stuff on A1990 but present on A2141 and U8800 and U8900 is no stuff on A2141 but present on A1990 )
                macbook with A2141 configuration run on recovery but don't complete it.​
                anyone can help me?
                05-26-2025, 09:27 AM
              • No Lan
                [Macbook pro A1708] [Boot loop] [Trackpad ?]
                by No Lan
                Hey everyone,
                Usually, I'm not the type to ask for help, but this time, I'm calling on your wisdom and expertise I've seen what this community can do, so I'm pretty sure you guys can help me out.
                Here's the deal: I noticed my MacBook got stuck in a boot loop. After opening it up and doing some initial troubleshooting, I found that the boot loop stops only when the trackpad is unplugged.
                Now, just so you know, the trackpad actually works — I tested it with another motherboard and it's all good. Same for the cable, no issues there. The problem is only...
                05-24-2025, 03:09 PM
              • twonk9098
                Macbook Pro mid 2015 battery required to boot?
                by twonk9098
                I have read many forums that state the Macbook Pro 2015 needs / does not need a battery to boot. I'm not convinced as yet which is correct.
                The Macbook Pro mid 2015 I have has no battery and do not really want to buy one just to test.
                This model has the newer trackpad which is not clickable when turned off.
                At the moment, without battery it does turn on with no display (with backlight), no chime and then turns off after 13 seconds. I see this from the power draw on my DTPS.
                If I hold the power button whilst connecting the magsafe 2 charger it turns on, again no image but...
                12-10-2024, 06:51 PM
