Dell latitude 5591 not power on
  • lapfix
    • Mar 2020
    • 2742
    • my workshop
    Hello friends
    Got this mtherboard not power on
    Dell latitude 5591 , LA-F711P.
    No short , no suspicion area , all is clean.
    All voltage at S5 are present .
    PM TABLE =
    +5V_ALW
    +3.3V_ALW
    +3.3V_ALW_DSW
    +3.3V_ALW_PCH
    +RTC_CELL
    +1.8V_PRIM
    +1.0V_PRIM
    +1.0V_PRIM_CORE
    +5V_ALW2
    +3.3V_ALW2
    +3.3V_RTC_LDO
    +1.0V_MPHYGT
    Timing Diagram for S5 to S0 mode =
    All is Ok until step 8
    8 = SIO_PWRBTN# = 3.3v
    PCH_RSMRST#_AND = 3.3v
    But the PCH don't send SIO_SLP_S5#
    All the power supply for PCH are present , when power button is triggered , POWER_SW#_MB 3v becomes 0 than 3 and that's the normal but SIO_PWRBTN# the signal send from io to pch to tell the PCH to get out of S5, and then go to S4-S3-S0 stay at 3V
    did i miss something to chek !
  • mon2
    • Dec 2019
    • 14355
    Re: Dell latitude 5591 not power on
    Remove all power. Meter in resistance mode.
    Check the resistance to ground of SIO_PWRBTN#.
    Actually, it should be ok since it is high...
    Check for the existence of the cap @ cc269.
    • lapfix
      • Mar 2020
      • 2742
      • my workshop
      Thank you my friend
      Resistance to ground of SIO_PWRBTN# taken at CC269 = 2.123mohm so it's good.
      Yes cap is populated , not RC241.
      i think when power button is trigged than SIO_PWRBTN must be 0v than 3v !
      • mcplslg123
        • Jun 2015
        • 7262
        • india
        RTCRST#/SRTCRST# and LIDSW# checked?? Bios flashed??
        Not gone thru scheme yet but just reminder to see if u missed these points.
        • lapfix
          • Mar 2020
          • 2742
          • my workshop
          Thank you mcplslg
          PCH_RTCRST# = RH200 =3v at 2 sides
          SRTCRST# = RH201 = 3v at 2 sides
          LID_CL_SIO# = RE26 = 3v at 2 sides
          Try another bios version still the same
          • mcplslg123
            • Jun 2015
            • 7262
            • india
            PCH_PWROK/PCH_DPWROK/PCH_BATLOW#/AC_PRESENT-Status??
            • lapfix
              • Mar 2020
              • 2742
              • my workshop
              Ok , but i think that this step are not reached ! i m stuck at step 8
              PCH_PWROK = step 14 not reached yet
              PCH_DPWROK = RE536 = not populated = 3.3v at the 2 points
              PCH_BATLOW# = RH94 = 3v from 2 sides
              AC_PRESENT = RH243= 3v from 2 sides
              • sikocan
                • Oct 2019
                • 344
                Can you check resistance of all caps on the PCH module. As well as measure V of CMOS battery outside board and in the board.
                • lapfix
                  • Mar 2020
                  • 2742
                  • my workshop
                  thank you sikocan
                  V of CMOS battery outside board and in the board. = 3v
                  all caps on the PCH module = more precision please !
                  • sikocan
                    • Oct 2019
                    • 344
                    I'm trying to identify if PCH has an issue. Any low resistance on caps on the PCH chip itself? This method saved me many hrs of work before.
                    • sikocan
                      • Oct 2019
                      • 344
                      I feel like this looks like a XPS 15 motherboards. Physically board looks good? Check around TPM module, any caps with corrosion? I've had TPM_VDD power had issues on similar model.
                      • lapfix
                        • Mar 2020
                        • 2742
                        • my workshop
                        Thank you
                        Nothing unusual around pch or UZ12
                        • sikocan
                          • Oct 2019
                          • 344
                          Did you check resistance of all these rails attached?
                          Also, a dangerous method, but I end up using this in last case scenarios, inject V to each power rail according to their specs and see what happens. Components like CPU GPU ram etc will get power etc but your looking for abnormalities in amp consumption.
                          • lapfix
                            • Mar 2020
                            • 2742
                            • my workshop
                            Thanks again.
                            i can't reach S3 , as i mention before SIO_PWRBTN# the signal send from io to pch to tell the PCH to get out of S5, and then go to S4-S3-S0 stay at 3V and not go to 0v than 3 V.
                            at page 47 i just reach the step n8 , step 9 = SIO_SLP_S5# it's not generated .
                            Yes maybe i will try this dangerous method
                            • sikocan
                              • Oct 2019
                              • 344
                              Something in the board knows there maybe an jssue down the line of power rails hence it's not allowing it to turn on, brute force it baby.
                              • lapfix
                                • Mar 2020
                                • 2742
                                • my workshop
                                Back for this Laptop.
                                With charger consumption = 0.028amp..and not trigger on.
                                All the voltages that i mention before are present.
                                I started from the beginning ..PQ9 and PQ4.
                                PQ9 = S 19.5v / G 9.31v / D 19.5v So good
                                PQ4 = D 19..5v / G 18.5 v / S 13.21v..this is my issue .
                                So gate of this PQ4 must be low and there's a voltage divider = must be 1.75V
                                no high voltage on PQ7 = voltage divider not woking
                                As mon2 mention at his post , the voltage of VBUS2_ECOK must be a high enough voltage to enable the mosfet @ PQ4.
                                #48
                                https://www.badcaps.net/forum/troubl...e3#post1729109.
                                So.The GATE pin must be lower to enable.
                                I Attach a ground wire to the bottom pin of the bottom resistor PR16 Test and it replaced mosfet enables.
                                So why VBUS2_ECOK is not high !...there's no short , all resistrances values are correct !
                                I try to power on my motherboard via a type-c charger and i didn't find my oridinary voltages!
                                PQ1206 =votage not stable swing between 0.600v to 1.5v
                                Diode mode = Drain to S = 0.549v ok
                                resistance mode = D to S = 2.677 mohm ok
                                PQ 1213 = Same behaviour of voltage swing
                                PQ 1202 = same behaviour of voltage swing.
                                So what to check else
                                • lapfix
                                  • Mar 2020
                                  • 2742
                                  • my workshop
                                  Update
                                  I verify some measurements at P48 :
                                  PQ1B is High ( turned on ) so PQ1A is Low (turned off)
                                  Wich cause at the gate of PQ5 same as source so is turned off.
                                  But PQ7 is OFF due to the absence of VBUS2_ECOK at his gate.
                                  UT5 = PD controller
                                  +TBTA_Vbus_1 = must be 20v in normal condtion..or 5v/ nothing in case of issue..but i got a non stable voltage , swinging between 0.6--1.2 v..PQ1206 is not shorted .​
                                  • lapfix
                                    • Mar 2020
                                    • 2742
                                    • my workshop
                                    Update 2
                                    I try with another original charger ( lenovo ) PD controller is OK
                                    all voltage are present...But same as with charger ...no VBUS1_ECOK
                                    same too : no power light indicator , no caps light
                                    • lapfix
                                      • Mar 2020
                                      • 2742
                                      • my workshop
                                      ue1
                                      VBAT 3.1v
                                      VTR_ANALOG 3.3v
                                      VTR_PLL 3.3v
                                      VTR_REG 3.3v
                                      VTR1 3.3v
                                      VTR3 RE340 pin 2 = 1.8v
                                      SIO_SLP_SUS# 3.3
                                      AC_PRESENT 3.3v
                                      LID_CL_SIO# 3.3v
                                      PS_ID 3.3v
                                      RESET_IN# 3.3v
                                      SYSPWR_PRES at RE57 not populated : only side 2 = 3.3v but
                                      POWER_SW_IN# 3.1v
                                      ALWON 3.1v
                                      ACAV_IN 3v
                                      RTCRST_ON 0v ok
                                      SIO_PWRBTN# 3v
                                      • mon2
                                        • Dec 2019
                                        • 14355
                                        Test the crystal / clock @ MEC_XTAL1 / MEC_XTAL2_R.
