Dell latitude 5591 not power on
  • lapfix
    • Mar 2020
    • 2764
    • my workshop
    Hello friends
    Got this mtherboard not power on
    Dell latitude 5591 , LA-F711P.
    No short , no suspicion area , all is clean.
    All voltage at S5 are present .
    PM TABLE =
    +5V_ALW
    +3.3V_ALW
    +3.3V_ALW_DSW
    +3.3V_ALW_PCH
    +RTC_CELL
    +1.8V_PRIM
    +1.0V_PRIM
    +1.0V_PRIM_CORE
    +5V_ALW2
    +3.3V_ALW2
    +3.3V_RTC_LDO
    +1.0V_MPHYGT
    Timing Diagram for S5 to S0 mode =
    All is Ok until step 8
    8 = SIO_PWRBTN# = 3.3v
    PCH_RSMRST#_AND = 3.3v
    But the PCH don't send SIO_SLP_S5#
    All the power supply for PCH are present , when power button is triggered , POWER_SW#_MB 3v becomes 0 than 3 and that's the normal but SIO_PWRBTN# the signal send from io to pch to tell the PCH to get out of S5, and then go to S4-S3-S0 stay at 3V
    did i miss something to chek !
  • mon2
    • Dec 2019
    • 14659
    Re: Dell latitude 5591 not power on
    Remove all power. Meter in resistance mode.
    Check the resistance to ground of SIO_PWRBTN#.
    Actually, it should be ok since it is high...
    Check for the existence of the cap @ cc269.
    • lapfix
      • Mar 2020
      • 2764
      • my workshop
      Thank you my friend
      Resistance to ground of SIO_PWRBTN# taken at CC269 = 2.123mohm so it's good.
      Yes cap is populated , not RC241.
      i think when power button is trigged than SIO_PWRBTN must be 0v than 3v !
      • mcplslg123
        • Jun 2015
        • 7262
        • india
        RTCRST#/SRTCRST# and LIDSW# checked?? Bios flashed??
        Not gone thru scheme yet but just reminder to see if u missed these points.
        • lapfix
          • Mar 2020
          • 2764
          • my workshop
          Thank you mcplslg
          PCH_RTCRST# = RH200 =3v at 2 sides
          SRTCRST# = RH201 = 3v at 2 sides
          LID_CL_SIO# = RE26 = 3v at 2 sides
          Try another bios version still the same
          • mcplslg123
            • Jun 2015
            • 7262
            • india
            PCH_PWROK/PCH_DPWROK/PCH_BATLOW#/AC_PRESENT-Status??
            • lapfix
              • Mar 2020
              • 2764
              • my workshop
              Ok , but i think that this step are not reached ! i m stuck at step 8
              PCH_PWROK = step 14 not reached yet
              PCH_DPWROK = RE536 = not populated = 3.3v at the 2 points
              PCH_BATLOW# = RH94 = 3v from 2 sides
              AC_PRESENT = RH243= 3v from 2 sides
              • sikocan
                • Oct 2019
                • 344
                Can you check resistance of all caps on the PCH module. As well as measure V of CMOS battery outside board and in the board.
                • lapfix
                  • Mar 2020
                  • 2764
                  • my workshop
                  thank you sikocan
                  V of CMOS battery outside board and in the board. = 3v
                  all caps on the PCH module = more precision please !
                  • sikocan
                    • Oct 2019
                    • 344
                    I'm trying to identify if PCH has an issue. Any low resistance on caps on the PCH chip itself? This method saved me many hrs of work before.
                    • sikocan
                      • Oct 2019
                      • 344
                      I feel like this looks like a XPS 15 motherboards. Physically board looks good? Check around TPM module, any caps with corrosion? I've had TPM_VDD power had issues on similar model.
                      • lapfix
                        • Mar 2020
                        • 2764
                        • my workshop
                        Thank you
                        Nothing unusual around pch or UZ12
                        • sikocan
                          • Oct 2019
                          • 344
                          Did you check resistance of all these rails attached?
                          Also, a dangerous method, but I end up using this in last case scenarios, inject V to each power rail according to their specs and see what happens. Components like CPU GPU ram etc will get power etc but your looking for abnormalities in amp consumption.
                          • lapfix
                            • Mar 2020
                            • 2764
                            • my workshop
                            Thanks again.
                            i can't reach S3 , as i mention before SIO_PWRBTN# the signal send from io to pch to tell the PCH to get out of S5, and then go to S4-S3-S0 stay at 3V and not go to 0v than 3 V.
                            at page 47 i just reach the step n8 , step 9 = SIO_SLP_S5# it's not generated .
                            Yes maybe i will try this dangerous method
                            • sikocan
                              • Oct 2019
                              • 344
                              Something in the board knows there maybe an jssue down the line of power rails hence it's not allowing it to turn on, brute force it baby.
                              • lapfix
                                • Mar 2020
                                • 2764
                                • my workshop
                                Back for this Laptop.
                                With charger consumption = 0.028amp..and not trigger on.
                                All the voltages that i mention before are present.
                                I started from the beginning ..PQ9 and PQ4.
                                PQ9 = S 19.5v / G 9.31v / D 19.5v So good
                                PQ4 = D 19..5v / G 18.5 v / S 13.21v..this is my issue .
                                So gate of this PQ4 must be low and there's a voltage divider = must be 1.75V
                                no high voltage on PQ7 = voltage divider not woking
                                As mon2 mention at his post , the voltage of VBUS2_ECOK must be a high enough voltage to enable the mosfet @ PQ4.
                                #48
                                https://www.badcaps.net/forum/troubl...e3#post1729109.
                                So.The GATE pin must be lower to enable.
                                I Attach a ground wire to the bottom pin of the bottom resistor PR16 Test and it replaced mosfet enables.
                                So why VBUS2_ECOK is not high !...there's no short , all resistrances values are correct !
                                I try to power on my motherboard via a type-c charger and i didn't find my oridinary voltages!
                                PQ1206 =votage not stable swing between 0.600v to 1.5v
                                Diode mode = Drain to S = 0.549v ok
                                resistance mode = D to S = 2.677 mohm ok
                                PQ 1213 = Same behaviour of voltage swing
                                PQ 1202 = same behaviour of voltage swing.
                                So what to check else
                                • lapfix
                                  • Mar 2020
                                  • 2764
                                  • my workshop
                                  Update
                                  I verify some measurements at P48 :
                                  PQ1B is High ( turned on ) so PQ1A is Low (turned off)
                                  Wich cause at the gate of PQ5 same as source so is turned off.
                                  But PQ7 is OFF due to the absence of VBUS2_ECOK at his gate.
                                  UT5 = PD controller
                                  +TBTA_Vbus_1 = must be 20v in normal condtion..or 5v/ nothing in case of issue..but i got a non stable voltage , swinging between 0.6--1.2 v..PQ1206 is not shorted .​
                                  • lapfix
                                    • Mar 2020
                                    • 2764
                                    • my workshop
                                    Update 2
                                    I try with another original charger ( lenovo ) PD controller is OK
                                    all voltage are present...But same as with charger ...no VBUS1_ECOK
                                    same too : no power light indicator , no caps light
                                    • lapfix
                                      • Mar 2020
                                      • 2764
                                      • my workshop
                                      ue1
                                      VBAT 3.1v
                                      VTR_ANALOG 3.3v
                                      VTR_PLL 3.3v
                                      VTR_REG 3.3v
                                      VTR1 3.3v
                                      VTR3 RE340 pin 2 = 1.8v
                                      SIO_SLP_SUS# 3.3
                                      AC_PRESENT 3.3v
                                      LID_CL_SIO# 3.3v
                                      PS_ID 3.3v
                                      RESET_IN# 3.3v
                                      SYSPWR_PRES at RE57 not populated : only side 2 = 3.3v but
                                      POWER_SW_IN# 3.1v
                                      ALWON 3.1v
                                      ACAV_IN 3v
                                      RTCRST_ON 0v ok
                                      SIO_PWRBTN# 3v
                                      • mon2
                                        • Dec 2019
                                        • 14659
                                        Test the crystal / clock @ MEC_XTAL1 / MEC_XTAL2_R.
                                        • dlonely94
                                          Dell Latitude 5591 not power on
                                          by dlonely94
                                          Hi everyone!
                                          I have a Dell Latitude 5591. It has a strange problem:
                                          First, when the WLAN card is plug in, it will not power on when press power button, even all voltage is up (19v, 3v, 5v, 3valw, 5valw)
                                          When I remove the WLAN card, it will start nomarlly. Then I power off and re-insert the WLAN card, it still work normally.
                                          But, if I left it for 3 or 4 days without the battery and adapter plugged in, it will not power on, and I have to repeat the above sequence.
                                          Sometime, when it not power on, I just unplugged the battery and adapter, wait...
                                          10-13-2024, 10:29 AM
                                        • hoarderteks_kyriakos
                                          Dell Latitude E5570 - No display, turns off after a minute of pressing the power button.
                                          by hoarderteks_kyriakos
                                          Hello.
                                          Yesterday my mother encountered a problem with her laptop, which led to it not turning on and expressing the behaviour mentioned in the title (you press the power button and then it turns off after a minute)
                                          Here is what happened:
                                          At one point i was fixing a setting on the laptop to make the laptop properly recognize the NVMe drive i put in months ago. All worked until all of a sudden the computer blue screened. The screen said it would reboot, but it never did. So she held down the power button, powering it off. Pressing it again, the screen briefly turned...
                                          10-08-2025, 07:33 AM
                                        • imedbox
                                          Dell Latitude 5440 no power on
                                          by imedbox
                                          ihave the same probleme the labtop want charge with the power supply! my bat is decharged then i can test it with battry it power on!
                                          i got this after flash bios "XM25QH256C" for removing admin password,i revert to the original then not charge or power on, befor it power on and chargin!
                                          Any Help !
                                          her link for Boardview and the Schematic
                                          Dell Latitude 5440
                                          bios version : 1.12.20
                                          MTHERBOARD : IDB40 LA-M401P Rev:1.0(A00) 2023-11-10
                                          https://www.transfernow.net/dl/20250721QpvcJ0UG
                                          07-21-2025, 03:03 AM
                                        • NADJIB
                                          Dell Latitude 7390 _DAZ20 LA-F312P 1.0 - all power rails up except VCC_CORE and VCC_GT
                                          by NADJIB
                                          I need help please​
                                          I have Dell Latitude 7390, LA-F312P 1.0
                                          - power LED turns on a few one second or two withe power supply or battery
                                          - the power supply indicate current 0.16 A While laptop is powered
                                          I checked:
                                          While laptop is powered from battery/barrel plug AND power LED is on, all voltage rails show up, except +VCC_CORE and +VCC_GT.
                                          * COIL
                                          PL612
                                          - Output resistance to ground is 14.7 ohm.
                                          PL613 AND PL610
                                          - Output resistance to ground is 9.8 ohm.
                                          01-23-2024, 04:31 PM
