MacBook 16" A2141 no display
  • vasild9
    • Dec 2022
    • Соединенные Шта&
    Hello, I have a MacBook that had coffee spilled on it. Screen is black no backlight or Images on screen. I replaced the screen and flex cable and still same thing. External monitor works fine nothing else seems to be broken, Just screen not working. What do you think the problem might be? Thanks.
  • rediii
    h???, spurrrn
    • Mar 2018
    • 501
    • somewhere in europe
    Re: MacBook 16" A2141 no display
    where was the water damage exactly? j8500? which pins where shorted?
    • howardc64
      by howardc64
      Problem
      08-04-2024, 10:36 PM
    • sofles
      Macbook Pro 16" A2141 screen artefacts, kernel panic
      by sofles
      Hi there.
      I have Macbook Pro 16" 2019, model number A2141, motherboard number 820-01700. I have some problem with dedicated graphic card. When Macbook switches to dedicated GPU it is getting instantly hot and starts to show glitches on screen, then it freezes (trackpad is not clicking anymore) and shuts down.
      I tried to reinstall MacOS But it was a pain, it started to show glitches in middle of installation and I could not finish it. I only was able to reinstall MacOS when I put Macbook outside (it is winter and -2 Celcius).
      Now situation looks like this, If...
      02-05-2025, 05:05 AM
    • reformatt
      by reformatt
      07-31-2025, 08:37 PM
    • Ado02
      MacBook Pro A2159 - No Display / Works on External Screen
      by Ado02
      I am working on a MacBook that came in for a screen replacement. The MacBook powers on and works on the external screen. However, the screen stays black. The replacement screen made no difference. On further investigation, I found small amounts of corrosion.
      Please see the attached image.
      I ordered a refurbished logicboard, but the problem didn't go away with the old or replacement screen.
      Can anyone suggest where to go from here?...
      01-12-2023, 03:35 AM
    • ledbylight
      M1 A2337 Macbook - No Display, likely due to logic board
      by ledbylight
      Hi all!
      This is my first post and also one of my first "deep dives" into electronic repair. I'm used to doing basic tasks with computers, like SSD/CPU replacement, thermal past re-application, etc. So here's the story...
      I have a MacBook Air M1 that I bought to repair (I know, I'm weird; though I'm a CompSci major and want to learn more , and it will not display anything on the internal display. I have verified that there's no backlight, as I booted the laptop and shined a flashlight on it and there's no display; it does completely boot up, and shows fine on an external...
      11-04-2024, 06:36 PM
